Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Insinkerator works but doesn't drain - Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
  • 377 Answers
A clog in the ISE. UNPLUG and look inside the top via the sink. If possible, run a small cleaning snake into the ISE drain and do what you can to clear the drain.
Count your sponges, etc to see if anything might have ended up in the ISE by mistake.
Posted on Oct 02, 2010
My Badger 5 is just humming and I smell a bad burning smell.
Either the Shredding Plate or the motor has burned out. In your case, it sounds like the latter. The motor is not repairable, you have to buy a new unit complete.
Insinkerator Garbage Disposal Hums But Doesn Work
Insinkerator Garbage Disposer BADGER 5Troubleshooting Repair Help
Badger 5 Garbage Disposal InSinkErator
Dec 09, 2017 | Electrical Supplies
Insinkerator badger 1 leaking from the bottom
check to be sure water is not leaking down the side from d/w drain or sink drain if not look inside with flashlight to check for rust if rusted trough time for a new one
Aug 10, 2015 | In-Sink-Erator InSinkErator Badger 1, 1/3...
Insinkerator disposer causes water to drain slowly from sink
The pipe from the disposer outlet to the sink drain Tee is partially plugged. Remove the drain pipe from the disposer to clear the obstruction.
Apr 11, 2014 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water does not flow, it flows very slowly. even the motor does not work.
You need to use a plumbing snake to clean the drain from the output of the InSinkErator, just as you would clean a sink drain. On the bottom of the InSinkErator there will be a small button that will actually be a circuit breaker. This needs to be re-set by pushing it in. I would also get an appropriate size Allen wrench and insert it into the bottom of the ISE at the center. This will allow you to turn the ISE by hand and perhaps break up any debris that might be in the unit. DO ALL THIS WORK WITH THE UNIT UNPLUGGED!!!
Aug 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator badger 5 runs sink wont drain
Properly piped, your arrangment should look similar to this picture so that there is a separate trap for the disposal and the other sink basin.
Mar 05, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Badger insinkerator model 5Plus-7 which will not drain.
You have a glog in the p-pipe / drain pipe that is not allowing the water to pass and drain.
Jan 24, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator is not draining. used the tool and still doesn't work
the problem is probably,at the drain pipe's,or further down the line.try some drain opener or,use a snake
Dec 26, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
UNsermount sink with waste disposal
The easy mount disposal has a ring the (sort of) screws onto the insinkerator sink drain - the thing that is labeled insinkerator when you look down into the sink.
If this is a new install on a new sink, I recommend the EZ mount model. If there is already the sink drain (thing mentioned above) labeled insinkerator, you may be able to simply attach the new disposal to the existing drain ring.
Also: If you have a dishwasher to connect, this is a great time to install the "air gap valve" (available for almost free at any hardware store.)
May 05, 2009 | Dishwashers
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
231 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
