Question about HP PSC 2110 All-In-One InkJet Printer
Ink Cartridge Alignment
My HP PSC 2110 All-In-One needed a new black ink cartridge. I put in the right one, and printed the alignment sheets and all. When I face the alignment sheet face down on the scan glass and press "Enter", the "Aligning...Please Wait..." NEVER disappears. I have pressed "Start Scan" instead of "Enter" or turned off the printer and restarted it. I have tried almost 6 times and still it refuses to print any of my documents. What should I do?
  • Anonymous Jul 04, 2008
    printer was making a loud noise when it started printing or during printer alignment; now it prints the instruction sheet, but it won't print the page to be scanned.
    When I try to print a test page it just sits there and does nothing.
On alignment sheet, do you see a line of yellow blocks?
And on next line do you see alternate block and yellow blocks?
(Without these, alignment fails)
If not, change the colour cartridge, re-print the page and repeat alignment.
Good luck...
Posted on May 27, 2008
Ink cartridge doesnt any help
  1. Make sure the HP All-in-One is on. Press the On button to turn on the HP All-in-One. The On button is lit when the HP All-in-One is on.Figure 1: Press the On button to turn the product onc00442142.gif1 - On buttoncaution.pngCAUTION:If the HP All-in-One is off when you open the print-carriage access door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by pulling it forward. The print carriage moves to the far right side of the HP All-in-One.Figure 2: Open the access doorc00442143.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it.Figure 3: The print carriagec00316910.gif
    • If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: The print cartridges in the proper positionc00442144.gif1 - Print cartridge slot for the tri-color print cartridge2 - Print cartridge slot for the black and photo print cartridges
  4. Pull the print cartridge toward you out of its slot.
Step two: Install the new print cartridgeBack to top
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.Figure 5: Remove the tapec00442146.gif1 - Copper-colored contacts2 - Plastic tape with pink pull tab (must be removed before installing)3 - Ink nozzles under tapecaution.pngCAUTION:Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Insert the print cartridgec00442148.gif
  3. Close the print-carriage access door.Figure 7: Close the access doorc00442149.gif
Step three: Align the print cartridgesThe HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. Use the following steps to align the print cartridges from the control panel.
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray, and then press OK .
  2. The HP All-in-One prints a print cartridge alignment sheet.note.pngNOTE:If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
  3. Lift the lid. Place the top of the alignment page face down in the left front corner of the scanner glass. Close the lid.Figure 8: Load the alignment sheet on the glassc00443602.gif
  4. Press OK to begin the alignment.
  5. The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Oct 28, 2011 | HP Officejet 5610 All-In-One InkJet...
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Office Equipment & Supplies
Installed new black ink cartridge in HP PSC 2110 color printer, scanner, copier. Followed instructions to align cartridges. Printer printed paper that had additional instructions. Placed second printed...
hello, machine will need to finish calibration so it will not come back, so if machine failes it could be that the color cartridge is not printing, because this machine uses yellow to calibrate with.
Oct 06, 2010 | HP PSC 2110 Color Printer
Print cartridge will not align
This could be an issue from remanufacturing. Try a new cartridge from HP.
Many manufacturers have hardware in the cartridge and the printer that tell the printer "new cartridge". When a cartridge is refilled, you can have that giving a "bad" message.
I wish that I could be of more help.
Feb 18, 2010 | HP PSC 2110 Color Printer
How do you install an ink cartridge on an HP Officejet 4315 All in one Printer that I have had given me, with everything but the instruction book. Can you also confirm that the cartridge numbers are 27...
Working with print cartridges
To ensure the best print quality from HP All-In-One, you will need to perform some simple maintenance procedures and when prompted by a message on the display replace the print cartridges.
A) Handle the print cartridges
Hold the print cartridges by their black plastic sides, with the label on top. Do not touch the copper-colored contacts or the ink nozzles.
Note : Handle the print cartridges carefully. Dropping or jarring cartridges can cause temporary printing problems or even permanent damage.
B) To replace the print cartridges
1) Make sure the HP All-In-One is off whenyou open the print cartridge door to access the print cartridges, the Hp A-ll-In-One will not release the cartridges for changing. You might damage the HP All-In -One. If the print cartridges are not docked safely on the right side when you try to remove them.
2) Open the print cartridge door.
The print carriage should now move to the far right side of the HP All-In-One. If the print cartridge does not move to the right side, close the door. Then trun the HP-All-In-One offm and then on again.
3) Wait until the print carriage is idle and silent, and then lightly press down in a print cartridge to release it.
If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
4)Pull the print cartridge toward you out of its slot.
5. If you are removing the print cartridge because it is low or out of ink, recycle the print cartridge.
6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
Caution Do not touch the copper-colored contacts or ink nozzles.
7. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
If you are installing a black print cartridge, slide it into the right slot.
8. Close the print cartridge door.
9. If you installed a new print cartridge, the print cartridge alignment process begins.
10. Make sure you have plain paper loaded in the input tray, and then press OK.
11. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print
cartridges ensures high-quality output.
To align the print cartridges from the control panel when prompted
1. Load letter, A4, or legal unused plain white paper into the input tray.
Note If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support. Go to www.hp.com/support. If prompted, choose your country/region, and then click Contact HP for information on calling for technical support.
2. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
To align the cartridges from the control panel at any time
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge.
4. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
Black Cartrige no . :27/21
Tricolor Cartridge no . 22
Hope this helps.
have a good day.
Dec 04, 2009 | HP Officejet 4315 All-in-One Printer
Installed new ink cartridge and it won't work
HI
did you check if the printer printed a cartridge alignment sheet.
you can try power flee initially
take out the cartridge
unplug the power cord
press the power button for 30 seconds
and then replug the cable
when it asks for putting the cartridge
put the cartrige in its respective slot
also make sure that you keep t least one paper on the tray so thst the printer prints an alignment sheet
,it shjould work fine
Hope this helps
Take Care
Jun 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
Will not print black , HP PSC 1610 All-in-One
Is it a new genuine cart? If so, I have had this problem. Run multiple copies of black only text, Run 50 copies, will still spit out blank pages.Then head clean. If no black repeat. I did this for around 200-250 copies then Volia! black. Hope this helps
Apr 28, 2009 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1300 All in one Printer
  1. Turn on the HP PSC and lower the print-carriage access door.
    The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
      NOTE: The black cartridge is on the right side of the print carriage.
    Figure 2: Removing the print cartridge
      NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
      CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
    Figure 3: Removing the plastic tape
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
      CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
    Figure 4: Inserting the print cartridge
  5. Close the print-carriage access door.
Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
c00034854.jpg 1 - Inserting the print cartridge
2 - Removing the print cartridge
Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
  1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  2. Press Scan .
    The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
Printer color problem
The ink cartridge cleaning process can be performed even with the alignment message showing in the display. Follow the steps below to perform an ink cartridge cleaning process from the front panel:
  1. On the front panel, press Menu or Setup (depending on the model).
  2. Press the Right Arrow (>) until Maintenance or Tools appears, and then press the Enter or OK .
  3. Clean ink Cartridges should appear in the display. Press Enter or OK to begin the cartridge cleaning process. A page will be printed during the cleaning process with all of the colors on it. If any of the colors or the black are missing, faded, or streaked on the alignment page, there is a ink cartridge problem.
Nov 30, 2007 | HP PSC 2110 All-In-One InkJet Printer
Hp 2110 All in One Printer
Does the machine ask you to "align" the print cartridges when you turn the machine back on? If the alignment page when finished printing is missing a key color (say yellow), then the alignment will not succeed.
Jul 29, 2007 | HP PSC 2110 All-In-One InkJet Printer
HP PSC 2110 All-In-One InkJet Printer Logo
297 people viewed this question
Seeker5211
Seeker5211
