Question about Panasonic KX-T7630 Corded Phone
I'm using Panasonic KX-T7630. My line is busy even if I'm not using it. I tried to forward all calls to my mobile number and it didn't work too.
How do you put a panasonic KX-T6730 on voicemail instantly if you need to leave the office early?
Press
Dial 50(forwarding program number) on the keypad
Press or
Dial one of the following single digits for the condition you want
0-off
1-DND(Do Not Disturb)
2-All calls forwarded
3-Busy calls forwarded
4-No answer calls forwarded
5-Busy/No answer calls forwarded
Dial the voicemail access code(default is usually 500; this is the number that will ring voicemail)
Press or
Lift handset or press to end
Dec 10, 2010 | Panasonic KX-T7630 Corded Phone
How to forward calls to another extension with panasonic kx-t7630
From the intercom dial *710x ext and # where X is 2/3/4/5 for All,Busy,No Answer,Busy/No Answer. There are some other conditions and Do Not Disturb in the dialing string (and 0 cancels) but that's the basic.
You might want to review the Operations Manual (OM) under Call Forwarding to see the complete instructions.
Carl
Sep 16, 2010 | Panasonic KX-T7630 Corded Phone
How do I divert calls to a mobile number and then undivert calls
pickup the handset (phone... watever) and press the FWD/DND button then press #2 then type in the number of the mobile (or number you want to forward to...), and hang up the phone... then when your finished with the call forwarding function, press FWD/DND again and this time press #0
What 2 does it turn on the call forwarding feature
. and 0 turns off forwarding/do not disturb functions
theres 5 different functions after you press FWD/DND
0: turns FWD/DND off
1: put the phone into Do Not Disturb Mode
2: call forwarding
3: Busy-Forwarding.. which means if your on the phone and someone rings, it forwards them to the number you specify
4: No Answer- when you don't answer the phone if forwards the caller onto the number you type in
and lastly 5: Busy/No Answer- does both function 3 & 4
i hope i've helped
, Cameron
Jan 22, 2010 | Panasonic KX-T7630 Corded Phone
Kx-tg5632 how do i forward call to my cell
you need to call your carrier and get a forwarding code and then a cancell code.
good luck
s
Jun 11, 2009 | Panasonic KX-T7630 Corded Phone
Instruction on how to divert incoming calls to a mobile.
hey c'mon please let the receptionist go after you have finished , why you want her with you?
May 20, 2009 | Panasonic KX-T7630 Corded Phone
Voicemail box not set up
I have seen the same problem with some users (I look after the PABX) so I just go into the maintenance console and set up the foreward to the default voice mail number. Or you can try the following:
CALL FORWARDING HANDSET 1. Press the Speaker Phone Key on your handset 2. Then Press the FWD/DND Key 3. Then select the Forward type you desire - Key 2 - Immediate Key 5 - Busy/No Answer 4. Then dial the internal extension number (eg.444) or voicemail pilot (201) 4a. If forwarding to external number dial 0 then dial outside telephone number 5. Dial # then press the Speaker Phone key
Use the voice mail that is set for your system.
Hope this helps
Jan 08, 2009 | Panasonic KX-T7630 Corded Phone
How do I divert calls from Console to mobile KX-T7636
Press the Program button. enter 50 for call forwarding and press Enter. enter 2 and the number (ie 25551234) to forward ALL calls to the specified number. enter 3 and the number to forward when busy, 4 and the number to forward when there is no answer, and 5 and the number for when you're either busy or there is no answer. Hit Enter and then the Program button again.
Line connection
try this;
press sp-phone enter *71029, then enter the outside number, then #, you will hear a tone that means call forwarding is activated.
to cancel press sp-phone *7100# or simply dial 790 for extension data clear
Aug 07, 2008 | Panasonic KX-T7630 Corded Phone
UN Forwarding calls
Pick up handset, dial 710 then #, hang up.
May 29, 2008 | Panasonic KX-T7630 Corded Phone
CALL DIVERT- TO MOBILES
Type * 71029 then your mobile number and end with a #
thats the code.
Dec 13, 2007 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
203 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
