Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
My router will work as a 4 port connect but no software to config for my xp pro sp3. help w dsl.?
    Master:
  • 397 Answers
You do NOT need software to configure the Westell- it is configured through a web-browser interface. Here's how to access the westell: Go to start > run> type cmd. Press enter. That will bring up a command prompt. Type IPCONFIG /ALL and press enter. What you are looking for is the default gateway. Normally it should be 192.168.1.1
Next open a web browser (internet explorer, firefox, chrome, safari, etc) and in the address bar (NOT THE SEARCH BAR!) type 192.168.1.1 (or whatever you saw for Default Gateway when you ran IPCONFIG)
You should get a box asking for user name and password- by default those are "admin" and "password" respectively.
That should log you into the Versalink, where you can modify how it connects (for instance, setting the DSL username and password, or DHCP, or static IP routing information), the wireless features, etc.
Posted on Oct 01, 2010
Dsl-2640b always hang
Just download and install free open-source Router Commander program, that fully compatible with your router. This program designed to prevent router to hang. Very recommend. I solved my hangs problem with this software.
Apr 21, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
Dlink DSL-2640B LAN & Internet keep disconnecting , very random and it's painful
There are many reasons why this might be happening.. You could try the following steps..
1) Disconnect the power from router for a minute and reconnect and check. 2) Try changing the wireless channel and Network name and try re-connecting and in change LAN slots at the back of the router. 3) Check if there is an firmware update for your product and update if any update is available. 4) If none of the above steps work you will need to reset and re-config your router. ( For that you need the CD given with the router and you will need the ISP settings.)
Hope this helped
Feb 15, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
No internet connectivity after upgrade firmware
1,there is a reset button
2,press this using any pin with power
3,automatically restart
4,connect your router with pc
5,type 192.168.1.1 on the browser
username:admin
password:admin12 or admin
configure router
enable dhcp
Oct 29, 2009 | D-Link DSL-G604T Wireless Router
Utorrent doesnt work with Huawei e220
Well, you could always try using Vuze ( formerly Azerus ) as a new bittorrent program, as it work very nicely. Though, you may have the same problem as you're having with uTorrent.
What you have to do is go into your router's settings and open port 25320 so the bittorrent program can get a connection.
Jul 05, 2009 | Enterasys Distributed Forwarding Engine...
Problem with BSNL Broadband with XP 2 Operating System
Of note, XP does not support USB internet connection; so, try out connecting with LAN cable. Hope this helps.
Dec 22, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Cannot Connect to the Internet Using a New D-Link DSL-2640B
1. Make sure you have the latest firmware
2. Restore to factory settings first. This helped me with stacked ppp session.
3. Setup your connection according to ISP
4. If you have problem, install Router Commander from www.routercommander.com
5. Setup router to send syslog to your PC
6. Check syslog messages about the clue what's going on
Dec 17, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
DSL (2wire modem) and LAN conflict
You can actually try accessing the interface of your gateway and put it on DMZ mode. That way it will open the ports on your gateway to ensure passage of all data from your gateway to all your computers even when the dsl is on. But make sure tat you have security software installed on all your computer workstations bec. putting your 2WIRE gateway on DMZ mode will expose your connection.
Aug 15, 2008 | 2wire 2700HG-B Router (2700HGB)
Wont connect and software cd
To connect a router or a dsl modem to a switch you either have to use port 4 or use a utp crossover cable. As you can see on the Netgear FS605 the modem/router has to be connected to port 4.
The correct way to connect these devices is:
Modem > Router > Switch > Computers
Jan 14, 2008 | NetGear FS605 (FS605SE) Networking Switch
Please help
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
config your router by running the setup cd and that would fix your problem..
let me no know in case if you have any problems ...
Dec 02, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
63 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
arnold balmaceda
arnold balmaceda
Level 1 Expert
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
