Question about Hayden Industries SuperVac 2400 Central System Vacuum
The unit has no power to it. The plug in which the unit is plugged has been tested and is fine. Unfortunately I'm not at the property as it's a rental. Is there something obvious that we are missing?
No power at all. No lights. just dead
Try plug it into a wall outlet that you know is good. If that's not the problem turn the power switch to on, then test the power cord plug for continuity, if none the power is not getting to the unit, could be the switch is bad, or wire broken/disconnected inside unit.
Mar 07, 2015 | Vacuums
10 September 2011 I have a Denon clock radio in the kitchen, but it's not working. In fact, it hasn't worked in a long time. Help me. Serial # 71101100576
Hello there,
First you need to check if it is receiving power, try to connect the cord to another device to see if it will power it up. If it does, then it means the power cable is okay and does not need replacement, but if it does not power it up, then it means the power cord is bad and need to be replaced.
If the power cord works perfectly fine, check if the outlet is supplying current by plugging some other device to it to test if it is working.
If the power outlet is okay, then it means the problem is from the power board inside the unit of the denon clock radio. Have the power board checked for bad capacitors. If none found, replace the power board.
This time it should work.
Would be glad to know if this information was helpful to you. All the best Elect_Comp
Sep 10, 2011 | Vacuums
I had my bosch 1400 W 12 amp vacuum plugged in and it blew a fuze so I reset the home fuze box and went to plug it in and it sparked and blew the fuze right away. The plug was very hot to touch. I am...
Often if the plug or cord is a problem, it can be seen. Look carefully at the plug, are the prongs straight? Is the cord damaged where it enters the plug? Is the cord damaged where it enters the vacuum? If the plug was rotated, it is possible that the wires inside the cord may have frayed insulation and are making contact with each other.
If it is the plug or the plug end of the cord, you can get a new plug at Home Depot and replace your old one.
Also, if you have a switched outlet or switched multi outlet extension, you can shut the power to the outlets off, plug in the vacuum and turn on the switch so you are not near the plug when you plug it in to test it.
Gary
Jun 23, 2011 | Bosch 12-Amp Formula Canister Vacuum with...
Hooked everything up per directions. I plugged it in to the closest electrical outlet and nothing happened. The lights did not light up, the connected wall control and sensors leds do not light up. It...
Dear Davehibshman,
Firstly; dismantle the plug and replace the fuse with the same rating as the one you have just taken out. Replace the plug cover, put the plug into the socket and try again. If this doesnt work, there may be a problem with the internal fuse (if one is fitted). Two choices here, either refer this unit to a qualified service personnel/ the place where you got it from, or do the job yourself (which will save you a whole bunch of cash). In your circumstances, I would take it back to the place you got it and ask them to put the fault right, or replace the unit completely; if it is past its warranty or guarantee time, then get back to me with a make and model number of the unit, and I will give you step-by-step instructions on how to solve this.
Yours sincerely
Oz
Feb 27, 2011 | Vacuums
My vacuum stopped working. If it is plugged in and not connected to the power nozzle and you turn it on nothing happens. If you plug in the power nozzle it turns and works fine but no suction.
depending on your unit, and how old it might be, it could be the motor, wiring, or even a fuse next to or on the motor. The power is working fine you have said because the power nozzle works, but because there is no suction I am leaning towards a suction motor in this case.
Nov 05, 2010 | Vacuums
Vacuum won't turn on when plugged in and switch is turned on
The easy answer to this problem is you need a new cord. Any fit all 20 to 35 foot two wire cord will work. However, you will need to take disassemble the almost the entire vacuum to test the current cord to see if it is bad. There are a lot of pieces to take off to get to the inside of the vacuum where the cord enters from the back. You could also have a bad motor.
Nov 18, 2009 | Hoover U6311-930 Power Drive Bagged...
I have a Bissell Upright Proheat 2x and the dual power brushes wont rotate. I went to replace the drive belt and noticed the drive shaft does not turn when power is turned on. What shall I check next?
Is there a light that comes on when you "turn the power on." If there is no light, and the unit is plugged in, how do you know there is current going to the motor? Sounds like there might be a break in the cord. Examine the cord near the plug end to see if one of the internal wires is broken. If you cannot tell, then you need to try taking the unit apart where the cord enters the unit and testing continuity with a meter.
Aug 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Was vacuuming fine and suddenly the thing won't turn on. Tried another plug.
Same thing happened to my Wertheim 4030. It turned out to be a broken connection in the retractable cord plug, no doubt due to continual shock upon retraction. How did I find it? By pulling the top off and first checking the internal switch was working with an ohmmeter (definitely no power for this test) Then plugged in, powered up & checked if any power to switch with AC voltage tester(be careful and have unit RCD protected for your safety) None showing, so checked if power at internal reel. None, so switched off power and checked continuity of cord for active and neutral continuity. None in one so cut off plug and checked again OK so new plug fitted and reassembled. If I had power to the switch originally, the motherboard/rheostat or motor may have been the problem. Hot wiring the motor would have determined which(unlikely to be both but a possibility) Repair or replace faulty item, obviously checking motor brushes first. Electrical is simply a matter of isolation and elimination.
rjjs
May 16, 2008 | Hoover Vacuums
Hayden Industries SuperVac 2400 Central System Vacuum Logo
20 people viewed this question
Top Hayden Industries Vacuums Experts
JoeVacs
Are you a Hayden Industries Vacuum Expert? Answer questions, earn points and help others
