Question about Maytag M7Y15F2A Air Conditioner
Kenmore Window unit 15,100 btu, Model 25372156200
Hi Fix Ya,
I would appreciate your help. Can you give me some sugguestions why the fan will not come on. The unit has been sitting up for two years and my central air has gone out so I decided to put it in for temporary. I pressure washed the unit and dryed it out and put it in. It comes on with a hum, not blowing or the fan turning. I turn it off, and back on it might not come on,,,then wait, then it might hum again. Darn it! It's not a very old unit,,,is there a way to open it up and move the fan? Sugguestions?
Jackie
  • Jacass1 May 26, 2008
    I do still need assistance but its a Kenmore AC unit, not Matag
  • mnski Jul 19, 2008
    Kenmore 8000 btu window unit has the same problem. It worked a couple of weeks ago just fine. Now, when I turn it on it just hums... no matter what "Mode" it's in.
  • 31 Answers
With the hum noise sounds like you have a bad fan motor
Posted on Nov 17, 2008
Fan wont stop when off
sensor not working, its bridge.
May 21, 2016 | Frigidaire 15,100 BTU Window/Wall...
Squeaking noise
check how level a/c is in window. you want it level side to side and a slight pitch to the back. styrofoam is present for insulation in evaporator area could be squirrel cage rubbing on it.
Jul 07, 2014 | Kenmore 70151 Window Air Conditioner...
How to stop my Frigidaire 15,100 BTU from beeping
Hello Naomi - Thank you for your question. When the air conditioner is beeping, it may be a warning sign that the filter needs to be clean or that you need to reset the unit. The LED (light) will illuminate and beep after 250 hours of operation. After cleaning the filter, you may reset the "FILTER RESET" option by simply pressing and holding down the button for approximately twenty seconds and the light/beeping will go off. However, if you have done this, try pressing the "RESET" button on the GFI plug of the unit. Wait approximately 2-3 minutes and then turn on the air conditioner. If issue persists, then at this point I would suggest reaching out to the manufacturer directly to see if you have any limited warranty on the appliance or you may alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area.
Jun 14, 2013 | Frigidaire 15,100 BTU Heavy Duty Window...
I HAVE A HEIL 5000 A/C CONDENSING UNIT.\r\nCAN YOU TELL ME WHAT SIZE IT IS (TON)? MODEL # CA5560 VKD2 STYLE # 60MCE-000095ZR SERIAL # L9811 50209MANF # NCA5560 VKD2 I APPRECIATE YOUR HELP. THANK YOU VERY...
It looks like you have a 60,000 BTU unit or a 5 ton unit...12,000 BTU/ton is how you figure that...
The 60 in the model number indicates the nominal btu's of the unit... the exact output could be a bit more or less depending on the air handler...
heatman101
Aug 04, 2010 | Honeywell International Heil Quaker...
My ac is not blowing cold air. the fan will only blow warm air. It seems like the compressor is not working.
The unit may be low on refrigerant. There is probably a low pressure switch in the unit to protect the compressor so it wont turn on and get damaged beyond repair. You can take it to your local appliance repair shop and have it looked at. I would get a quote on repair first. Most of the time it is cheaper to buy a new unit than it is to pay just the labor to have it repaired.
Jun 06, 2010 | Frigidaire 15,100 BTU Heavy Duty Window...
Water doens't drain properly and sitting there,
that's fairly common for window units, it's ok to drill a small hole in the underside of the case to drain the water, just be sure you don't puncture the condenser in the process.
Aug 18, 2009 | Frigidaire Heating & Cooling
Broken AC window unit Kenmore
starting capacitor is bad (THE STARTING CAPACITOR IS A BIG METAL BLOCK MOUNTED ON OR NEAR FAN MOTOR)
Jan 17, 2008 | Heating & Cooling
Maytag M7Y15F2A Air Conditioner Logo
609 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
