Question about Mitsubishi CS-40503 TV
No power at all.
Came home ready to relax and sit down with the old girl and no power at all. Tried both the remote and the power switch on the front of the unit, no picture or sound. I know the outlets are working due to sound system and X-box power up. Any ideas?
  • Jimmer08 May 26, 2008
    What kind of range are we looking at for worst case?
HI,IM JOHN FROM PHILIPPINES IM A TECHNICIAN,the problem with your tv is ethier the power ic,,fuse..capacitor,,or the circuit protector diode R2KY,,R2KS
Posted on May 26, 2008
Does anyone have the code for sky remote to tune it in to the sa-ht880 Home theatre I did have it on old remote and the volume button worked but can't find code now :-(
Step 1:
You can set up your old remote very simple.
your old remote should have a "Setup" button.
Step 2:
Next you have to have your T.V/Home Theater on.
Step 3:
While the T.V is on press and hold the "setup" button for 3 seconds on your old remote.
a light should indicate that its on "setup" mode.
Step 4:
while your remote is on setup mode point it to the T.V and press the "Power" button until the device turns off.
Step 5:
Once your T.V turns off you can press "Enter" on your remote will be setup and ready for that T.V.
Feb 06, 2013 | Televison & Video
I turned tv off with remote, now it will not turn back on. i have tried remote and button on front of tv.
Check the remote with new batteries. If it do not work, remote control has the trouble. You can't switch the set ON by its front panel power switch, as it has been shut down by remote command.
Mar 31, 2012 | Symphonic WF20D4 TV
RCA Home Theater RT2906 doesn't respond to Remote
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Have you tried new batteries?
May 16, 2011 | RCA Audio Players & Recorders
Just had a power outage and now my TV will not come back on. Just flashes 3 consecutive flashes then a pause and then 3 more flashes. Tried unplugging and letting it sit, tried power button on remote and...
I hate to tell you that this happened to me last week and mine is 18 months old. after calling toshiba and going through all troubleshooting, nothing worked. they referred me to a service center near me and the repair is $466!!!!! I have lots of power outages so they can seriously damage a tv (the motherboard to be specific). Mine is the 42 inch 535U. get a surge protector for your cable and ask your electric company to install a power shield on the meter or a surge arrester.. good luck.
Nov 08, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Tv wont turn on
You have already try basic troubleshooting, just to be sure before having service call, check the out let just to be sure. Otherwise get it repair ASAP under warranty, this is not a good sign.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 07, 2010 | Sony KDL46EX400 46 in. HD-Ready TV
I have an older RCA home theater proformer amp has a model # of PA4500 I cannot get any remote to program to use it, it has no volume dials and you cannot control the volume without a remote and we have...
The PA-4500-M does not have a wireless remote control. The amp turns on when there is an audio signal present at one of the inputs. The power button on the front is the master power, when the amp is ready the front LED will continuously glow RED, when the audio signal is sensed, the LED will glow GREEN. The audio signals must be variable otherwise you cannot control the volume.
Jan 19, 2010 | RCA Audio Players & Recorders
Sony Trinitron KV-1975R TV won't turn... Relay problem ?
O'boy do you have it bad-
normally I would say get a new T.V. but in this case I would surggest you find a very good tv.repair MAN,in your area- where he would clean the inside of your t.v.(I knew 1 who use to do this with a toothbrush),and he should also replace/spray your relay switch which sounds like its on its way out. the old ones are the best ones I have an old b&w tv myself that belong to my graddad still working even do its slowy getting out of date with all the digatil now.but I'll find some use for it - best of luck with the old girl..P.
Aug 07, 2009 | Televison & Video
20 year old Quasar colour TV (no remote)
That is because the switches of the front panel buttons are stuck or defective.
Try first unplugging power for ten minutes, this probably wont work.
To fix this the TV must be taken apart from an expert, and front panel replaced.
You can enquiry here for parts.
What you can do at home, is getting a replacement remote and using TV with a remote, or buying a freeview box, and watching and changing channels through the box.
You can get a replacement remote here: Replacement Remote Control orReplacement Remotes
My suggestion, if it is supported in your area, get a set top box with 30 channels : Freeview - digital TV from Argos.
Oct 11, 2008 | Quasar SP-2723 27" TV
TV acts like a timer is controling the power...comes on only at night
How old is this set? If any age, might be time for a replacement, you can get a 50" for under $1000 now. Dont know about your issue, I have never heard of one not turning on because of a timer, suspect you may have a micro issue, the power cord unplug would be advisable, but sounds like you tried it, have you tried the buttons on the front? Do you clean the screen with something liquid? Some of these the buttons go bad and confuse the micro if you use liquids on the screen and let some dribble down the frame. Might pull the speaker grill off and there should be 2 1/4" screws on 2 brackets loosen and the brackets will drop, the screen can come out and there is a long connector that goes from the front to just behind the middle tube and if you unplug it it will kill the buttons on the front and if it is your problem will allow the remote to function, reassemble reverse of disassembly.
Jun 18, 2007 | GE 46GW945 46" Rear Projection Television
Televison & Video Logo
185 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
