Question about Ulead Videostudio 8 for PC
Jumping pictures when capturing video. When I transfer my Hi8 Video from the camera via EasyCap, i get, most of the time, the problem that the pictures is "jumping". Sometimes I can record/capture for a long time without any problems, then it starts and disturb the video quality. Also it might start right away when I begin capturing, so there is no pattern in when or how much. I have a good quality PC, good space on disks, and close down all unnescessary programs without any change. The video plays fine from the camera. Also I have tried to adjust whet is possible in the Option button.
5 Suggested Answers
smokintdi
  • 7 Answers
SOURCE: EasyCAP Video Adapter with no video
Ok, here is what is going on. The default video setting in control panel> scanners and cameras> syntek 1160 is pal-b it should be NTSC_M. Right click on the Syntek 1160 and click Video Decoder Property. Change it to NTSC_M from Pal. Do this with the unit plugged in or it wont be displayed in the Scanners/Cameras options box. Right away the signal line should rear 1 from 0 with video hooked up. Keeping that setting to stay is my issue right now. I was so excited to figure it out, I had to post. I was about ready to throw the unit away. Its a program driver error. Hope this helps!!!
Posted on May 20, 2009
SOURCE: Have EasyCap video capture device and vista x86
I have windows vista and my drivers load fine. Plug in the unit and the drivers load. I have the 4 camera easycap and the VCR easycap. Install drivers first before plugging in the unit. Restart computer, plug in unit, check device manager if there is a stk1150 loaded under image. My problem is getting small files from the recordings. I converted 2 mins of my daughters dance solo and it turned out 1.7gb AVI file without sound. Changing the options to mpeg or WV files will crash the program becuase something doesn't match. I need to play with it more to understand it better.
Posted on Jun 08, 2009
SOURCE: easycap
I had the same problem and found that if I went into the options and chnged the format from NTSC to PAL and then back to NTSC it would bring in my camera. Thanks to snrobby for the hint on the options idea.
Posted on Jun 11, 2009
  • 2340 Answers
SOURCE: Trying to use the Easycap capture device to transfer video tapes.
Maybe these will help you Videos
Posted on Jul 13, 2010
Want to transfer Hi8 video from cassette my PC sharp 8mm camcorder vl-420 with no battery or adapter
Not sure if that camera works just with a power adapter, some of them need the battery. If you look on Ebay you may find both. If you get them and the camera works ok then you will need a video capture card or USB video capture adapter to connect the camera to the PC. Then you will need to know what type of output lead you need from the camera to the video card/adapter. Usually with older cameras it will have a socket for a lead to allow for showing on TV. It should have the red/yellow/white RCA/Phono connectors on one end and the plug for the camera on the other. Then you will need video capture software. It may come supplied with the capture device.
Dec 14, 2014 | Sharp Video Cameras
HI There I have an old camcorder the Model is a JVC GR-DVL 150E i have some very old footage on the camcorder tapes, i never ever got around to transfering the footage on to vhs video tapes! but now i...
You need to buy USB 2.0 Video Capture Adapter Card to do this action..
Pls visit the URL below as an example..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
EasyCap USB 2.0 Video Capture Adapter Card TV VHS DVD Capture high quality audio and video through your PC's USB port. Capture playback from VHS, Camcorders, TV, etc; capture audio without a sound card! Supports NTSC, PAL, Video format. NTSC: 720 x 480 @ 30 fps PAL: 720 x 576 @ 25 fps.
http://cgi.ebay.com/EasyCap-USB-2-0-Video-Capture-Adapter-Card-TV-VHS-DVD-/360339776240?pt=LH_DefaultDomain_0&hash=item53e5eca2f0
Jun 27, 2011 | Cameras
Hi There! I have an old camcorder, model is a JVC GR-DVL150E . I would like to know if its possible to transfer my footage from the tapes on to my PC and save it to discs! if so how do i do this and what...
Thanks
Jun 26, 2011 | JVC Video Cameras
Six years ago, I purchased my Sony Handycam CCD_TRV308 Hi-8. Now I want to download some old videos. Will this cam corder allow me to transfer videos to my computer?
You likely need a video capture card that will accept analog video (several makers like Pinnacle--not a recommend);
...alternatively, if you have a digital video camera, better ones have an analog video input jack by which you can use the digital camcorder as an interface (with analog to digital conversion), and thence to the computer via the firewire cable.
...This technique can also be used to transfer VHS from your old VHS player from its analog output, via the digital camcorder to the PC.
..This way you can transfer into a NLE (non-linear editor) like Adobe Premier, Final Cut, Sony Vegas, AVID, etc ; and edit your video now that it has been digitized. And the Hi8 as you know will have much better resolution potential than the VHS.
Aug 08, 2009 | Sony Handycam CCD-TRV308 Camcorder
Get video off Sony Handycam DCR-TRV118 Hi8 to PC or Mac
Hi There,
MisterSony is quite correct about the Capture card.
While most computers have the built-in ability to capture sound via the 'Line In' port, digitally recording the Video signal is a totally different aspect.
Certain TV Tuner cards also have Video Capture abilities (in addition to the tuner they have a VCR input). They often work in tandem with your Video Display card via the 'Feature' connector.
Both types allow the incoming signal to be displayed and recorded digitally at your choice of speeds, resolutions and formats.
My preferences in the past have been the VideoBlaster line by Creative Labs. There are many others.
I'll do a little research as to what's currently out there and post my findings directly.
Mike
Nov 01, 2008 | Sony Handycam DCR-TRV118 Camcorder
Easycap
Sep 04, 2008 | Ulead Videostudio 8 for PC
EasyCAP USB video capture device problem
Did you disbale your FIREWALL whilst you installed the driver, I found this most important. After installation enable your firewall again. I had alsorts of problems till I did this. Even so I feel these devices are somewhat unstable
Hope this helps
Jul 06, 2008 | Video Cameras
Can't use my Sony TRV22 miniDV camcorder to pass through and record Hi8 analog signal to my PC
Just below, they noted you don't put a tape in the TRV... Otherwise it outsmarts you.
Sep 13, 2005 | Sony Handycam DCR-TRV22 Mini DV Digital...
Ulead Videostudio 8 for PC Logo
182 people viewed this question
Top Ulead Computers & Internet Experts
d3yavu3
Alun Cox
Karan Sethi
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
