Question about Panasonic TH-50PHW6B 50 in. Plasma Television
ON SWITCH ONN THE PLASMA POWERS UP,BUT AS SOON AS A SIGNAL IS PUT IN IT SHOWS THE PICTURE FOR ABOUT 5sec & SWITCHES OFF & THE RED LED BLINKS TWICE.MODEL IS A TH-50PHW6
SOURCE: my panasonic plasma tv has some error! the red led
Panasonic sent a repairman out with the correct part after telling them about the seven blinks. The unit was out of warranty. They rock. Call 800-211-7262 or 800-524-1448 1
Posted on Oct 06, 2009
freelance-au
  • 131 Answers
SOURCE: my panasonic model #TH-50PX75U wont turn on, it
I would suspect faulty capacitors in your power supply, Take the back of and look on the power supply board for capacitors that have domed shaped tops, they may also have a brown liquid like substance leaking from them.
Replace these and this should cure your problem if it is capacitor related.
Posted on Mar 05, 2010
  • 380 Answers
SOURCE: panasonic model #TH-50PX75U wont turn on, it
Usually seven blinks indicates a Y sustain problem. Its either the Y sustain pcb and/or the buffer boards. I would highly recommend calling an authorized service center for this if you don't know what you are doing.
Posted on Mar 09, 2010
walesarumi
  • 6993 Answers
SOURCE: My Panasonic TH-50PZ800U plasma TV
This is not video board problem. It is actually a power supply problem.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Feb 02, 2011
  • 378 Answers
Unplug the power cord. Press and hold the power button for 30 seconds, repeat. Plug it back in and try to turn it on.
If this doesn't work, it would be time to call in a repair tech. Is the TV still under warranty? Extended warranty?
Posted on Apr 13, 2011
Panasonic plasma tv led blinks 12
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 24, 2016 | Panasonic TC-P46G15 Plasma TV
Panasonic Plasma TV TX-P50G10-B
May 19, 2016 | Panasonic Televison & Video
TH 42PV8H A MY TV POWER NOT ON RED LED 2 TIME BLINKS
Mar 16, 2016 | Panasonic TH-42PV8H 42 inch MultiSystem...
LG 50PC5D-UL plasma tv not getting a picture.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Jan 07, 2016 | LG Televison & Video
Why does my Panasonic Viera VT50 have no picture and red led blinks 3 times
First thing, check the HDMI input and make sure it is firmly connected, same for the power cable, obviously. My Samsung goes similarly nuts if it detects no signal from the currently selected input but after 1-2 minutes it eventually stops and I can change the input source.
Aug 13, 2014 | Panasonic Smart VIERA TC-P55VT50 55" Class...
HL-T6176S red and green flashing
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
Nov 27, 2017 | Televison & Video
Panasonic Plasma - turns on, but stays blank.
Your TV probably has power supply trouble.
Jan 16, 2014 | Panasonic Televison & Video
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Seven red blinking led
Check the link below to find the parts that are causing the LED to blink 7 times and replace them to fix the plasma.
http://www.fixya.com/support/t5048641-easy_replace_capacitors
Jun 14, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Panasonic TH-58px600u
I have the same problem, no picture or sound, just a flashing red led. Has anyone found a solution?
Feb 12, 2008 | Panasonic TH58PX600U 58 in. Plasma HDTV
Panasonic TH-50PHW6B 50 in. Plasma Television Logo
23 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
