Question about HP 530 Notebook PC
After powering on the following message appears: Non-system disk or disk error replace and trike any key when ready. Trying to press F10 or F9 when powering on doesn not give any result. Does it mean that HDD tottaly broken? HP laptop model 530
    Master:
  • 397 Answers
First, check if you have any usb memory keys or other removable media in your system. That error used to show up when you'd leave a non-bootable floppy in your pc. If you don't have anything in your system other than your hard drive- listen. If you are hearing clicking, grinding noises- then yes, your hard drive has mechanically failed. If you don't- then the chances the drive is about to fail since the boot sector was corrupted. Try to make certain the drive is seated correctly in your system- if that doesn't help- you will need to contact the technical support for your system to get a replacement hard drive if your system is in warranty- or you can purchase one, and replace it yourself.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Posted on Oct 01, 2010
Message appears : Non system disk or disk error replace and strike any key when ready during start up.
a) You have a disk in the floppy drive or CD and the computer is trying to boot from that drive. Remove disk and reboot computer. Or ...
b) Your hard disk has failed
Or ...
c) Your operating system is damaged.
Apr 05, 2010 | HP Compaq 6720s Notebook
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
MY LAP TOP MESSAGE SAYS... 1782 DISK CONTROLLER
You are getting this mess because the system is not able to detect a boot partition on the hdd or may be it is not able to detect the HDD itself.
Try to remove the HDD(hard disk) and re-seat it, Also make sure that there is no disk in the CD drive (in case the first boot device in the BIOS is set as CD drive).
Go to BIOS by pressing F10 (system setup) and check if the HDD is detected in BIOS.
Try to run a recovery by pressing F11 on first screen after power on.
Please get back for any further assistance.
Thank you for choosing Fixya
Feb 24, 2010 | Compaq Armada E500 Notebook
When trying to do a Sytem recovery, I get an Error Message.
Recovering the system without using Windows
  1. Disconnect all peripherals and internal non preinstalled devices from the PC, except the monitor, keyboard, and mouse.
  2. Turn on the computer.
  3. When the initial blue HP screen appears, press the F10 key repeatedly until a recovery menu appears. The progress indicator that first appears does not indicate that a recovery is taking place. The progress indicator represents the time before the recovery process is started.
  4. When the Recovery screen appears, click Next, and then click Yes to perform a normal, non-destructive recovery.
  5. To perform a destructive recovery, click Advanced, and then click Yes.
  6. After the System Recovery is complete, and the computer starts successfully, update the computer software as follows:
this link is to order disk (from HP) if the 6 step do not work http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=1843604
Jun 20, 2009 | HP Pavilion a1253w Notebook
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
Non System disk
a) remove any external devices and reboot.
or
b) boot from Windows XP setup-cd into rescue-terminal, execute: fdisk /mbr
or
c) do a hdd self-test in bios (restart, press F10, tools --> hdd self-test option --> notebookharddrive) to check the integrity of your harddrive
Sep 21, 2008 | Compaq tc4400 Tablet PC
I cant reach the bios setting
It should be the F10 or F11 key.
Check HERE for more help.
May 31, 2008 | Compaq Armada 1592DMT Notebook
"Non-system disk or disk error replace and strike any key when ready".
If this error occurs you open the cabinet disconnected the harddisk data cable for few seconds and reconnected the harddisk data cable and bot it will work.
Apr 10, 2008 | Compaq Evo N610C Notebook
Non System Disk or Disk error Replace and strike any key when ready
while switching on your system press F10 and the go to the Advanced setup. There you select and press Enter key on change boot order and then change the order by using Page up or page down key. Alternatively you may use Esc key while showing the compaq logo on boot, you will be able to change the Boot Order.
Feb 08, 2008 | Compaq Armada 7770DMT Notebook
My compaq Armada E500 wont come on
Replace hdd couse the pc dont recognize hdd..First go to the bios and load optimal default or optimized default and pres F10 and restart
If it wont work just buy NEW HDD
Oct 19, 2007 | Compaq Armada E500 Notebook
HP 530 Notebook PC Logo
128 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
