Question about RCA RP5010 Digital Voice Recorder
About your answer ...
It helped a lot actually. But when I plugged it into my computer, there isn't a SETUP folder. There are only A-D folder and a Playlist folder. help?? again??
thank you!!!
  • Anonymous Jun 11, 2008
    i have the rca RP5120 and for some reason we dont have the setup. is there anyway you can email it to me? my email address is shana27_2007@yahoo.com thanks.
Hmmm, it may have been deleted. I can send you a copy of the setup program for the 5120 through e-mail if you wish.
Send me a valid address and I'll have the file on it's way.
Posted on May 26, 2008
Question ashbassili asked on Office 2007 setup.exe can't find setup controller file - either network error, error reading DVD or problem with the package. This is a fresh install off a DVD. Onto a
Sounds like it's a compatability issue. Try right clicking the .exe setup file and choosing run in compatability mode. Or you could try right clicking the .exe setup file and going into property's, run in, and choose run this file in Windows xp service pack 2 mode. Apply the changes and try again. If that still won't work make sure your PC is fully upto date and has all net framework packages installed. A lot of programs refuse to install unless you have all the necessary updates and frameworks and Java installed. It doesn't specifically tell you the problem. Just gives you an error on install.
Apr 26, 2017 | Microsoft Office PowerPoint 2007 Upgrade:...
Tip
How to do Fast and unattended Setup of OS in multiple machines
<span> <p><span>Here I have an Idea for primary setup of a large lab quickly. Suppose you have to setup a lab where have more than twenty or thirty system but must setup it quickly. At that time if you don't have enough CD Rom drive or not enough OS installer CD then the task will take a long time. To save time at the same moment I like to prepare an unattendent operating system installation. Before this task I must check for presence of some requirement.</SPAN><br> <p><span> </SPAN><br> <p><span>Verify for unattended Installation:</SPAN><br> <p><span><span> </SPAN>To perform an unattended installation from a CD-ROM, the following conditions must be met:</SPAN><br> <p><span>The computer must support booting from a CD Rom<span> </SPAN>The unattended answer file must be renamed to Winnt.sif and copied to a floppy disk so Setup can access it. So must need a floppy disk drive.</SPAN><br> <p><span>The answer file must contain a valid [Data] section. This is explained later in this article.</SPAN><br> <p><span> </SPAN><br> <p><span>Before installation it has some conditions:</SPAN><br> <p><span><span> </SPAN>1&gt; the installation is limited to a single partition.</SPAN><br> <p><span><span> </SPAN>2&gt; you cannot specify third-party drivers during Setup </SPAN><br> <p><span> </SPAN><br> <p><span>Prepare For an Unattended Installation:</SPAN><br> <p><span><span> </SPAN>To prepare your computer for an unattended installation from a CD-ROM, I've followed these steps</SPAN><br> <p><span>First I've created a Folder in local drive & shared it. Then I create setup manager.</SPAN><br> <p><span>I install Setup Manager by following these steps:</SPAN><br> <p><span>I Open My Computer, and then open the Support\Tools folder on the Windows XP CD-ROM.</SPAN><br> <p><span>Double-click the DEPLOY.CAB file to open it </SPAN><br> <p><span>On the Edit menu, click Select All.</SPAN><br> <p><span>On the Edit menu, click Copy to Folder.</SPAN><br> <p><span>Click Make New Folder. Type the name that you want for the Setup Manager folder, and then press ENTER. For example, type setup manager, and then press ENTER.</SPAN><br> <p><span>Click Copy.</SPAN><br> <p><span>Open the new folder that you created, and then double-click the setupmgr.exe file. The Windows Setup Manager Wizard starts.</SPAN><br> <p><span></SPAN> <br> <p><span></SPAN></SPAN> <br> <img src="alokerdas_9.jpg"> <br> <p><span>Then I Use Setup Manager to Create an Answer File.</SPAN><br> <p><span>I open the setup manager & go to create a new answer file.</SPAN><br> <p><span>Then I go to the unattended installation & windows version option.</SPAN><br> <p><span>I have selected the fully automated option & create an answer file.</SPAN><br> <br> <br> <img src="alokerdas_10.jpg"> <br> <p><span>If you want Windows Setup to delete all partitions on the hard disk and to create a new partition, you must include the Repartition command in the Winnt.sif file. Under [Unattended], insert a new line, and then type "Repartition=Yes"</SPAN><br> <p><span>If you omit this line, you are prompted for the installation partition.</SPAN><br> <p><span> </SPAN><br> <p><span>Add a [Data] section with the following entries to the unattended answer file:</SPAN><br> <p><span>Unattended Install=Yes - Value must be set to "yes"</SPAN><br> <p><span>MSDos Initiated=No - Value must be set to "no" or Setup stops during the graphical portion of Setup<span> </SPAN></SPAN><br> <p><span>Auto Partition=1 - If the value is set to 1, the installation partition is automatically selected. If the value is set to 0 (zero) you are prompted for the installation partition during the text portion of Setup.</SPAN><br> <p><span>Save the unattended answer file as Winnt.sif on a floppy disk.</SPAN><br> <p><span>Insert the Windows CD-ROM into the CD-ROM drive, and then insert the floppy disk into the floppy disk drive.</SPAN><br> <p><span>Change the boot order in the CMOS so that the CD-ROM is first in the list.</SPAN><br> <p><span>Restart your computer. When Setup is started from the CD-ROM, the Winnt.sif file located on the floppy disk will be used to complete the unattended installation.</SPAN><br> <p><span> </SPAN><br> <p><span>This is an easy process to save time & effort.</SPAN>
on Feb 15, 2011 | Computers & Internet
Tip
How to do Fast and unattended setup of OS
Here I have an Idea for primary setup of a large lab quickly. Suppose you have to setup a lab where have more than twenty or thirty system but must setup it quickly. At that time if you don't have enough CD Rom drive or not enough OS installer CD then the task will take a long time. To save time at the same moment I like to prepare an unattendent operating system installation. Before this task I must check for presence of some requirement. Verify for unattended Installation: To perform an unattended installation from a CD-ROM, the following conditions must be met:The computer must support booting from a CD Rom The unattended answer file must be renamed to Winnt.sif and copied to a floppy disk so Setup can access it. So must need a floppy disk drive.The answer file must contain a valid [Data] section. This is explained later in this article. Before installation it has some conditions:
1> the installation is limited to a single partition.
2> you cannot specify third-party drivers during Setup Prepare For an Unattended Installation:
To prepare your computer for an unattended installation from a CD-ROM, I've followed these stepsFirst I've created a Folder in local drive & shared it. Then I create setup manager.I install Setup Manager by following these steps:I Open My Computer, and then open the SupportTools folder on the Windows XP CD-ROM.Double-click the DEPLOY.CAB file to open it On the Edit menu, click Select All.On the Edit menu, click Copy to Folder.Click Make New Folder. Type the name that you want for the Setup Manager folder, and then press ENTER. For example, type setup manager, and then press ENTER.Click Copy. Open the new folder that you created, and then double-click the setupmgr.exe file. The Windows
Setup Manager Wizard starts: alokerdas_2.jpg
<SPAN style="FONT-FAMILY: 'Courier New
I have a wireless router (WNDR3400) connected to a switch (about 10 computer connected to switch), and the switch is connected to the modem. For the network, all the wired computers can see and share...
Make sure all the computers wired and wireless are in the same workgroup.
To share files across all the computers and laptops on your network then -
All the computer and laptop in this network group must have their hard drive or folder/s set to SHARED (a hand symbol will be placed on these folders that are shared).
If there isn't a secutity problem then these folders and easy of file sharing then do not setup users and passwords on these folders.
Apr 18, 2012 | NetGear WNDR3400 N600 Wireless Dual Band...
Transfer pictures from tablet to computer
The simplest way is to use a usb flash drive or an external drive. Simply plug it into the tablet and open it once the computer recognizes it. Create a folder on the USB Flash or External and call it TabletPics for example. Then go to where the pictures on the tablet (probably in my documents or my pictures). You can copy the one picture from the tablet by highlighting it then right clicking on it and select copy or you can select Edit then copy at the top of the window where the pictures are. Then go to the usb flash drive or external drive and paste them by selecting Edit Paste or by right clicking anywhere within the Folder we created called TabletPics and select Past.. If you have a lot of pictures you want to copy you can try clicking on the first one you want to highlight it then go down to the last one you want and press the Shift Key and hold it while you Click on the last picture you want. It will highlight every thing you selected then you can copy them as we did before with the one picture and go paste them on the usb Flash Drive or External Drive in the Folder we created called Tablet Pics.
When you are done copying the pictures to the usb flash drive or external drive from the tablet, remove it and go plug it into the computer you want to put them on. It's the same process you will be copying pictures from folder TabletPics on the usb or external to a folder on the computer. Actually you can just copy the whole tabletpics folder by clicking on it and then Paste the whole folder on to the computer in the My Pictures folder.
Mar 21, 2012 | IBM Computers & Internet
My toshiba flash drive folders con not be seen in my PC but when i insert it in my DVD player folders shown up..please give me a best answer to solve this problem.
Perhaps this is a PC problem, ya think? If you have multiple USB ports, try them all. If the Flash Drive isn't discovered right away, using Device Manager scan for hardware changes after you plug it in.
Jun 13, 2011 | Cycling
How do I download videos from my Panasonic SDR-H80 to my Mac? I have the CD (VideoCam Suite 2.0) that came with the video camera but when I insert it and the icon shows up on my desktop it does not pop up...
I had similar problem. Could not see the files in the DCIM folder. But when I opened iMovie I see the files and can upload them to iMovie just fine. Unfortunately, the Panasonic manual sucks when it comes to instructions for Mac users. All they talk about is using the VideoCam Suite 2.0 but that is only for PC users. Mac users just use iMovie.
Aug 23, 2009 | Video Cameras
It wont show up on my computer when i plug it in.
hi buddy ,
actually first u have to go to
My computer-> refresh page 1or 2 times->u will c ur phone name there-> setup-> open folders to view the files/explore-> and then go on with what you wanna do.
Thats it!!!
Thank you giving me chance to help you out:):)
Plz rate/vote me so that I can improve myself and be more helpful:):)
Have a great time:):)
Prasanth83:):)
May 25, 2009 | Samsung SCH-U470 Juke Cellular Phone
Setup assistant won't appear
they is no setup assistant in itunes.
when your ipod mounts to itunes the first thin you will see is the summary page which shows an ipod and allows you to change the name.
on the left you will see your ipod and folders appear in the blue shaded column.
so hook it up and enjoy.
Warning: if you sync the ipod to your computer it will delete everything except what actually came from your computer.
May 19, 2009 | Apple iPod nano
Language change
This happened to me too!
I just moved my EPSON CX4200 printer to another computer in my house and when I installed the software, it installed it in French!
This makes no sense, as it didn't do that the first time I installed it on the other computer.
I have e-mailed Epson Support about the problem, but who knows if I will actually get an answer. I will post it here if I do.
Frustrated-TOO!
Apr 30, 2008 | Epson Stylus CX4200 All-In-One InkJet...
RCA RP5010 Digital Voice Recorder Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
