Question about Microwave Ovens
KENWOOD A760 Bean Slicer and Pea Huller. Instructions
Where to download the kenwood mw786 owner manual
I think this microwave with grill used to be marketed by Kenwood in the middle east markets.
The website that will be helpful for downloaded the manual is currently not working. But you can try to select the model number and see if it is available. You can also find something similar to your model as the instructions will be similar.
Instruction Manuals
Aug 13, 2014 | Kenwood Microwave Ovens
I have a Kitchen Selectives meat slicer Model SL-50 and the dial on the back that determines the thickness of whatever is being slices is not working. I see that underneath there are two white plastic...
I have the exact same meat slicer & I would love to know what those plastic scescrews are for. Did you ever figure it out? The instruction book doesn't even mention them.
Aug 11, 2011 | Microwave Ovens
I need an instruction manual for Ronson Food slicer model 87003 please
Bronte,
Did you ever get a manual for your Ronson food slicer, model 87003?
I have 1 of these slicers & am needing a manual as well.
Apr 19, 2011 | Microwave Ovens
Where can a get a manual for the v slicer mandoline? there wasn't one in the box it came in?
hello you can find your slicer manual at this link click here http://www.zylissusa.com/v1/PDF/Instructions_Mandoline.pdf if you have any further questions please message me back and please remember to also rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 21, 2011 | Microwave Ovens
Cobart Automatic Meat Slicer is not working on Automatic mode
To operate the slicer in Automatic mode . . . Rotate the Speed Selector Knob to the desired speed; make sure the Carriage is in HOME position (all the way forward); make sure the Lever is on the Manual position (pointing down); turn the slicer on; start the carriage drive unit by rotating the Lever to the Automatic position (up and to the right). Either of the two speed selections can be used to begin Automatic mode. The speed can be adjusted at any time by rotating the Speed Selector Knob. To stop the drive unit, rotate the Lever down and to the left - to the Manual position. ------------ If you slicer is set on proper automatic mode and still not running on automatic mode then the problem relates to internal motor or the selector knob. But try reset before this. Push the reset button underneath the slicer near the right-front foot if the carriage motor overloads. The reset helps in some problems.But if its not helping then internal connections of selector knob has to be checked.Of the same with motor,the connections of motor to the selector for automatic mode has to be checked.---------------- This will help.Thanks.Helpmech.'
Dec 15, 2010 | Microwave Ovens
I am Trying to locate instructions for a Philips HR 2700/b Slicer
Hey, I emailed Philips and had a link to a pdf manual within 3 hours (good products and great service apparrently!)
Here's the link they gave me:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=HR2700/00&slg=en&scy=AU
Nov 23, 2010 | Microwave Ovens
I am looking for a part to my chefmate slicer model #GC510. Is there antwhere that just sells parts?
Globe Food Equipment has a website that gives a parts catalog and a pricelist for the slicers: www.globeslicers.com The parts catalog for your slicer is at : http://www.globeslicers.com/Editor/assets/globe_docs/gc510%20catalog%204.15.8.pdf
If you get your part number from there, you can price compare at some other parts houses (such as onesharpstore.com ) by running it through google.
Hope this helps
Jul 04, 2010 | Microwave Ovens
Farberware v-blade mandoline slicer instructions - nothng in or on box - how do I use and put together
I bought a faberware V-blade Mandoline slicer and I would like to have an instruction manual for the blade usage please
Jun 21, 2010 | Microwave Ovens
Microwave Ovens Logo
90 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
