SIWAMAT XB 861, how can i set the washing machine into wash, rince and spin in one time?
  • 209 Answers
SOURCE: my washing machine is full of water!!!
check pump for open circuit electrically, if that is fine and the pump works but just doesn't drain then its a blockage somewhere between the drum and the waste outlet, strip the pipes and clean out, taking care to note original position of any parts and wires etc
Posted on Oct 14, 2007
  • 1294 Answers
SOURCE: frigidaire washing machine no spin cycle
Check your exit hose spigot, it may be clogged. This is if your filter is all clean.(Refer manual) There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 11, 2008
SOURCE: lg intello wash wd 8013f
The front panel is flasing when i press play
Posted on Sep 16, 2008
  • 326 Answers
SOURCE: Machine wash but wont rince or spin
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on May 06, 2009
SOURCE: Siemens Siwamat 2105 washing machine leaking
Ater beeing switched on the machine does not fill with water.
Posted on Jun 22, 2010
Siwamat xb 1060
Could be the transformer inside the machine..
Mar 31, 2014 | Siemens Washing Machines
Will not rince at end of wash cycle
If ur machine have additives cycle, check whether the solenoid valve (for opening water inlet to the additives' tray) is working or not. You can check this by listening to the sound of water during additive cycle. If it is not working, you have to replace the water inlet valve unit.
Nov 19, 2012 | Bosch Washing Machines
Washer skips spin cycle
You have an issue with the controller on your machine. Needs replacement.
Sep 17, 2017 | Maytag Legacy Series Top Load Washer
I have a broken door catch for a Siemens Siwamat XB 1061. Can I get a replacement part
I feel for you because we have exactly the same problem : our door broke, the handle in fact. Everything else works wonder but the screw driver trick is bound to give in one day eventually and we'll be left with no washing machine at all. Has anyone found any infor on the door anywhere? thanks guys
Mar 19, 2011 | Siemens Washing Machines
Doesn't change cycles, first spin and rince cycle doesn't work at all
Sounds like you have a bad timer Does it spin on final cycle? (Spin Cycle)
May 11, 2009 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
668 people viewed this question
Top Washing Machines Experts
