Question about Polaroid Cameras
GOOD AFTERNOON...I HAVE A PROBLEM WITH MY DIGITAL POLAROID CAM..CAUSE THE LENCE OF MY CAM IT DOESN'T WORK PROPERLY..IF I SWITCH OFF MY CAM THE LENCE IS NOT BACK PROPERLY..WHAT I AM GOING TO DO?I HOPE YOU CAN RESOLVE MY PROBLEM SOON..THANKS
    Brigadier General:
  • 3,006 Answers
Your camera has a lens error. This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the manufacturer's service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Posted on Oct 01, 2010
My polaroid i1037 digital camera saying card locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If that doesn't do it, try a different card.
Aug 01, 2011 | Polaroid I1037 Digital Camera
Comes up with card error
Your memory card is either write protected or corrupted.
  • If it's write protected, it can be very easily fixed.
  1. Turn off cam.
  2. Take out the mem. card. (it's probably located near the battery. press down on it and release it. Then it will pop out.)
  3. Slide the small switch on the side of the card to the position marked with an unlocked padlock.
  4. Put card back in and turn on cam.
  • If that doesn't seem to be the problem, then it's likely that the memory card is corrupted. This is common with Flash memory that has been used extensively for a long time and this problem is likely not caused by any fault in the camera. You might not be able to access any pictures that were stored on your cam, but you can try using a data recovery software like Recuva if you want to recover pictures ( click name to download ). If you want to use the card again, You can try formatting it (differs from cam to cam, check instructions manual for specific instructions) If this doesn't work, You will have to buy a new card. Make sure you buy a good brand like Lexar or SanDisk.
That's it. hope that helped.
May 02, 2011 | Fuji FinePix A345 Digital Camera
Nikon d40x error saying "error: press shutter release button again"
check the lence is working properly then the focusin option is auto or manual the auto focus 18-55 lence is properly fixed on mount or not
Oct 18, 2009 | Nikon D40x Digital Camera
Needs help
hi,if your leance could not open when you turn on camera so may be you must cheak the lence assembly breckeg , if the lence is open then servise lence unit and fix it properly,and the easy way is remove the lence unit and first remove moter from it and rolling well as possible.it must be smoth rolling between beralls of lence,then roll the moter alone well by using adapter about 5 volts,now fix it by aqurat ,you find a magic
Aug 25, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lance alignment is disturbed
hi,if you are a tecnition then open yor camera and remove the lence assembly,then remove the motor and clean the lence unit properly ,and check that smothness between lence beralls, it must be rolling smothly ,and roll the moter by using adapter of 5 volts ,roll motor both side ,after that fix it properly ,now you can check it by put suply on motor and see what has be done,if lence responce smothly in and out then fix it with camera,and see the magic
Aug 25, 2009 | Nikon COOLPIX L10 Digital Camera
Panasonic DMC-FX07. Dropped and died
this cam slip from my hand and the lence was open thats why lence one side down position and not working, i took this cam from saudi arabia 2 month before so pls give the suggest what i will do and where solve the problem
Nov 01, 2008 | Panasonic DMC-FX07 Digital Camera
Polaroid Digital Camera 3x optical zoom lens 8.0 Megapixal
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Oct 16, 2008 | Polaroid a300 Digital Camera
Camera lense wont close
I had a problem this week when i tried to close my camera and the lence would not close but the camers would
I took the batterys out, then a couple of days later when i replaced the batteries and switched the camera on the lence closed properly, so i guess my solution was to remove the batteries and see what happens it did the trick.
Maria
Jun 22, 2008 | Kodak Cameras
Cameras Logo
44 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
