Question about Zoom G1x Guitar Multi Effects Pedal with EXpression Pedal
How can i get a preset patch restored in my g1 effect pedal?or where can i get a patch description for a preset patch,i need the specs for b6 fuzz face it was a preset one that was on it that changed by mistake
  • 94 Answers
GO TO ASK.CM
Posted on Oct 25, 2010
Circuit diagram of zoom g1x
G1X circuit diagram is the same as the G1. They differ only on the pedal circuits.
circuit-diagram-zoom-g1x-shyexoo0xcste5eq310zs3ot-4-0.jpgcircuit-diagram-zoom-g1x-shyexoo0xcste5eq310zs3ot-4-1.jpg
Give your email,and I'll send the circuit diagram.
Jun 24, 2012 | Zoom G1x Guitar Multi Effects Pedal with...
What type of voltage regulator ic used in g1x?
2933BD or 29M33. It is used in g1, g1x,g1xn,g2,g2iu etc.
This is 3.3 volts regulator ic.
Feb 09, 2012 | Zoom G1x Guitar Multi Effects Pedal with...
When i turn over my fender fuzz wah i hear something rattle or clunk. Is something loose inside? I just got it yesterday.
It is probably the battery or the battery connector. Not to worry or look for the battery compartment and put your mind at rest.
Aug 06, 2011 | Fender Fuzz Wah Guitar Effects Pedal...
Fuzzed sound when two effects is turned on
That is normal depending on which effects are being used. Some effects just cannot be used together without creating mush...
Jul 27, 2011 | Visual Sound V2 Route 66 Pedal Guitar
My Voodoo Lab Super Fuzz stop working. The led doesnt light, and the effect sound doesnt work, but the bypass signal is unaffected... I opened it, and test the resistences they seem to be OK... I don't...
If you are using battery, replace it. If you are not using battery, check your pqwer adapter. Internally, the pwer connectors and soldering around it are chronic problem,
Feb 19, 2011 | Voodoo Lab Super Fuzz Guitar Pedal...
How to reset my Zoom G1 Guitar multi effects pedal
Here is a link:http://s3.amazonaws.com/samsontech/related_docs/G1_G1X.pdf Pay attention to page 25 Restoring Factory Defaults.
Jul 16, 2010 | Zoom G1x Guitar Multi Effects Pedal with...
When i press the harmony effect i have to hold it
Well i hope the latching mechanism isn't busted!
Check/review your parameter settings for your programs. Especially in the Expression Pedal Control areas.
From their site:
--Harmony Footswitch
This footswitch turns the harmonies on or off. While multiple harmonies can be selected within a preset, the HARMONY footswitch activates or deactivates any selected harmonies simultaneously.
When the LED above the HARMONY footswitch is illuminated, the harmonies are on. When the LED is turned off, the harmonies are turned off.
--Note: The settings for FX Footswitch Control, Harmony Footswitch Control and Guitar Sensitivity apply to ALL presets. The setting for the Expression Pedal Control applies to the current preset only. If you modify the Expression Pedal setting and wish to store it you must Store the preset (see page 11 ). When you load another preset, its setting for Expression Pedal Control will take effect.
--To perform a Factory Reset procedure
If you are editing a preset, press the Up or Down footswitch to exit edit mode.
Press and hold the Major/Minor button and then press and release the Store button. The display will read FAC RESET- WILL ERASE ALL YOUR PRESETS... , then STORE=RST.
Press the Store button again to continue with the factory reset. If you don’t want to do the factory reset, just wait 5 seconds, or press almost any other button, to cancel.
Mar 27, 2010 | Digi-Tech Digitech Vocalist Live 4...
Static Noise from guitar amp.
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Jan 22, 2009 | Epiphone Les Paul Studio Electric Guitar
Zoom G1x Guitar Multi Effects Pedal with EXpression Pedal Logo
161 people viewed this question
Top Zoom Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Barry Webster
Level 1 Expert
Are you a Zoom Music Expert? Answer questions, earn points and help others
