Question about SkyGolf SkyCaddie SGX GPS Receiver
Hi. I have a "comm initialization failed" and now I can't turn it of and restart it. What do I do?
Just turn on notebook and got error message configuration system fail to initialize
Problem with you operating system, restart you notebook, and press f8 to choise a safe mode, wait about 2 minute when you os recovery then restart again.
Oct 27, 2016 | Computers & Internet
No comm
I had the same problem and resetting the system at the pool panel and remote (as per manual instructions) did not work. I found a solution on an online forum that suggested that the main power panel at the house be turned off, wait a few minutes, turn back on, then go out to the pool panel and restart the system.....it worked!
Jul 05, 2012 | Pentair Easy Touch Indoor Control Panel...
We are having xerox 1038 model usa made . we are getting the error u6 when we switch on our machine . so plz suggest us the best possible way to fix up the problem ...`````
U6-1 The main PWB failed checking the ROM.
Shut down and restart the copier. If it appears again U6-1, replace the main PWB.
U6-2 The main PWB failed checking the RAM.
Shut down and restart the copier. If it appears again U6-2, replace the main PWB.
U6-3 and U6-4 The main PWB failed to check the battery MNV (U6-3). Or the main PWB does not properly initialize the NVM (U6-4).
Follow the procedure in the development of memory to initialize the NVM, code 20-96. Shut down and restart the copier.
Jul 20, 2011 | Office Equipment & Supplies
When i try to start the webcam application a message pops up saying that the webcam initialization failed. please check your camera device and restart application or computer
Hi, Did you try restarting your computer? It may be that something is blocking the application such as firewall or anti-virus. etc... If you are computer savy look in to firewall settings. Then restart and try webcam again. Good luck.
Jun 13, 2011 | Toshiba Computers & Internet
SIR I WANT TO OPEN THE SIM LOCK OF HAIER HC-C2076 TO USE OTHER OPERATES SIM
unlock-c2076mv03c
but vahi unlock hoga jo *#0000# karne par version show kar
Selected Model...C2076
Asking Server Access Take Few Seconds...
Successed to connect server
User name...xxxxxxxxxxxxxx
Searching Phone Please Wait :
Your Phone Version:= Dec 09 200914:17:22May 06 200807:00:00SCNGZ355*
Found Inside Version = QSC6010-SCNGZ-3550®?~
Phone Is In Boot Mode.
Prepairing Phone For Opration.
Phone Ready To Unlock..
DATE CONFIRM HC2076MT03C...
SEARCHING INTERNAL VERSION...
Found...HA2076MV03C
SEARCHING LOCKS...
LOCKS DISABLED...
Haier C2076 Unlocking Finish Restarted Phone...
error 0 in comm
error 1 in comm
error 2 in comm
error 3 in comm
Total Time Take...00:00:34
Log Saved To...C:\Advance Cdma\C2076log_5_1_2010_3_08_49 PM.txt
HOPE THIS WOULD BE HELP FULL .
PLEASE DO RATE ME.
HAPPY NEW YEAR
THANK YOU
Jan 01, 2011 | Alcatel Virgin Mobile ?£30 Text Cellular...
My fax can receive but is unable to send. Message is COMM ERROR 2
Your machine failed to communicate diring the initial protocol. This is the handshake that tells the receiving fax that you are what you are. IMPORTANT Check that your fax ID is entered in the fax, as some countries require that if it is not present to reject it. This can also be set on any receiving fax to reject junk fax. So Both the TTI and the CSI must be entered in your fax to work.
Oct 06, 2010 | Sharp FO 760 Plain Paper Thermal transfer...
SkyGolf SkyCaddie SGX GPS Receiver Logo
323 people viewed this question
Top SkyGolf GPS Experts
Steve
Steve
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
