Question about CAD Microphones GXL2200 Professional Microphone
Hey, Just wondering how to connect the CAD GXL2200 mic to a mac computer ? and if it can be used on garageband?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 24 Answers
You need to buy a USB interface (I use an M-Audio M-Track interface on my Mac) that plugs into your computer and the preamp will supply the 48 volts for the microphone. There are lots of different models of interfaces to choose from. Just make sure the description says it is able to supply 'phantom power'.
Once you have the mic plugged into the interface, and the interface plugged into a USB port on your computer, then you need to startup your favorite recoding program (I use Sound Studio on my Apple Macintosh) and open the Preferences and select the USB interface as your sound source.
Since I don't use Garage Band I'm not sure how you select the USB interface. A left-handed guess is that you may have to go to System Preferences - Sound - Input and select the USB interface.
Posted on Jun 02, 2016
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 71 Answers
You'll need an interface or a mixer.
Posted on Feb 06, 2014
5 Suggested Answers
djxtreme979
  • 151 Answers
SOURCE: my microphone sounds muffled
Check wind screen. Make sure output level is not higher than volume level.
Posted on Dec 28, 2008
SOURCE: Samson G Track USB Mic
To get sound in both channels in Garageband for a podcast using the G-Track Microphone:    select a voice track to record into    make sure the Track Info window is open (blue i button in lower right region of screen)    at the bottom of the Track Info window you will find Input Source:    Change the default setting of Stereo to Mono 1 (USB Audio CODEC)
This assumes you have gone to Garageband preferences and changed the Audio/Midi settings for audio input to USB Audio CODEC which appears when you plug in the G-Track Mike
Posted on Jun 25, 2009
SOURCE: gxl 2400 wiring connections
I need to take apart a shure pg58 wireless mic how do I do that
Posted on Oct 24, 2009
cjsound
  • 26 Answers
SOURCE: can I connect a CAD GXL2200SP Condenser Mic to a
Technically, you can plug any microphone into a computer via an audio interface or USB(if applicable) With this mic it will require an audio interface just remember that since you are using a condenser you will need an interface that can supply phantom power. Good Luck, Cody J.
Posted on Dec 17, 2010
What USB adapter is best to use with the GXL2200?
If you're going to use a mixer anyway, it'd probably be better to run the mixer into the line-in of the computer. Even better would be to just get a USB recording interface, and do the mixing in the software.
Otherwise, Behringer, Alesis, Yamaha, and probably other all make USB mixers that should be of similar quality (i.e., very low).
Mar 20, 2014 | CAD Microphones GXL2200 Professional...
How do I connect my CAD GXL2200 mic to my apple laptop?
You need a USB interface such as an M-Audio M-Track and a standard XLR male to female audio cable.
You use the cable to connect the microphone to the interface using the XLR cable, then you plug the USB cable on the interface to a USB port on your laptop. Finally, you go to System Preferences - Sound - Input and select the USB interface as the input source.
Depending on the software you you use for recording sound (I use Sound Studio from Felt Tip Software) you may need to go into the Preferences for the program and select the USB interface.
Dec 25, 2013 | CAD Microphones GXL2200 Professional...
What is the best way to run the mic on desktop
Your condensor mic requires special electrical handling usually reserved for proffesional audio equipment, not a PC. You will need two pieces of equipment, a short XLR cable and an adapter cable.
1) Behringer PS400 Ultra-Compact Phantom Power Supply.
This will supply the mic with necessary Phantom Power.
2) Rapco Horizon ISOBLOX Transformer Isolation 1:1 BLOX Device
This will isolate the Phantom Power from your computer, allowing it to work as necessary.
The adaptor connector cable you need will be a female XLR (with pins 1 and 3 shorted, pin 2 hot), through a cable connect to a 1/8" mini plug. They connect in that order with a short XLR cable between 1) and 2). .
I’m happy to assist further over the phone at https://www.6ya.com/expert/stanley_d05f392d8fafa669
Aug 23, 2012 | CAD Microphones GXL2200 Professional...
How to work EMU 0204 with CAD GXL2200
Turn on phantom power for mic? Try a different cable.
Aug 01, 2012 | CAD Microphones GXL2200 Professional...
On the CAD GXL2200SP Where is the the power switch for the mic located at? Im not getting anything i have the phantom power and everything plugged up right. But i knw there has to be a power switch...
I don't believe the GXL2200 has a power switch directly on the microphone itself. Would you be able to tell me how you are supplying phantom power to the microphone?
Feb 18, 2011 | CAD Microphones GXL2200 Professional...
Son wants to buy CAD GXL2200sp studio microphone package and wants to plug into laptop.Will that work?
for purposes of recording quality, I would recomend getting and external sound card. M-audio make a good range. You would need to have a +48v phantom power supply for this unit to work. The sound card you buy should have this. A Pc or laptop won't
Jan 16, 2011 | CAD Microphones GXL2200 Professional...
Can I connect a CAD GXL2200SP Condenser Mic to a computer?
Dec 15, 2010 | CAD Microphones GXL2200 Professional...
I have a gxl 2200 mic and my computer acknowledges the mic but i cant record anything because when i play it back there is no sound
You'll need a phantom power source, like an interface or mixer. Otherwise, the mic is likely in need of repair.
Sep 19, 2010 | CAD Microphones GXL2200 Professional...
Imac-samson-gtrack mic compatability
From the Samson Audio website...
"Ideal for the traveling musician or the project studio, the G-Track ships with a desktop mic stand, swivel stand mount, USB cable and all the cables needed to connect any musical instrument with a standard 1/4" or RCA output. The G-Track ships with Cakewalk's Sonar LE and works brilliantly with Apple's GarageBand."
If it states that it works with GarageBand, I would say that it would work on a mac.
Nov 29, 2008 | Apple iMac 24" Desktop
CAD Microphones GXL2200 Professional Microphone Logo
519 people viewed this question
Top CAD Microphones Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Miguel Luiz Martins
Are you a CAD Microphones Audio Player and Recorder Expert? Answer questions, earn points and help others
