Question about Olevia LT32HVM 32 in. LCD Television
Olevia monitor and compatibility with IBM Think Pad T40
Whether I connect with VGA or S Video, the monitor doesn't show the same picture as the lap top. Please assist.
    Problem Solver:
  • 4 Answers
Do you need to change the Source on the TV?
Posted on Sep 14, 2008
After changing out fan IBM think pad t40 screen goes black after windows xp screen finishes losding up
Wait Black Screen? AFTER you changed the fan... hmmm... I think I know what the problem is. Okay solution one; You might of hit a wire or cord in the computer when you changed out the fan. Two: You might have the virus 223, get it fixed and it should be going again! Hoped this helped! :D
Mar 25, 2013 | IBM ThinkPad T40 2373 Notebook
most common causes are the frequency of the 42" monitor its not compatible with your vga card. ex: if your monitor only suports 100Mhz but your graphic card just have 80Mhz then you will have a blured, fuzzy or no image at all and the resolution is not a problem at all. you can have 640 x 480 res but if your card and monitor both support the same frequency then you will have a crystal clear image. the only solution is to upgrade your graphic card to one compatible with your monitor. i kow this will not solve your problem but hope it will help you to understand the problem.
Aug 27, 2012 | Computers & Internet
I need vga drive to think pad t40 in win 7
GOOD LUCK!!!!!!!!!!!!!!!
Dec 10, 2010 | IBM ThinkPad T40 2373 Notebook
I have 2 ibm thinkpads t40, on one of the systems the lcd inverter and screen get no power but when i take the lcd and connect it to the 2nd ibm tkpad it works fine, What would be wrong with the one lap...
On the second Thinkpad laptop, that doesn't show a display with an LCD screen.
Plug a VGA monitor into the VGA port on the back of the laptop.
Hold the Fn key down, tap once on the F7 key (Toggle your display over to an external monitor)
Give the VGA monitor a few seconds to come on. (It's a VGA monitor)
Do you have a display on the external monitor? No? You May have a bad GPU then. (Graphics Processing Unit, )
Fix? Change out the motherboard. Possibly Ebay has one, dunno.
VGA monitor has a display? Then you may have a bad Inverter. The Inverter provides power for the LCD screen. Inverters go bad.
Are both Inverters the same? (Laptop to laptop)
BE SURE. The Inverter MUST match the LCD screen!
Check the numbers on both Inverters. If they are the same, switch the good one over to the 2nd laptop. See if you have display now.
Then it's the GPU.
Service Manual for IBM Thinkpad T40,
Copy and paste the above link into your Address bar. Press the Enter key. (I don't post direct links that you just click on. I want the asker to be able to see where the link takes them, by looking at the link. I feel it helps make the asker more comfortable with my solution, knowing I have their best interest in mind.
(If this link doesn't work for you, come back, and let me know)
Nov 20, 2009 | IBM ThinkPad T40 2373 Notebook
IBM think pad t40...the screen stays black. Shows
Are the activity lights blinking like the computer is doing something? If so the monitor may be disconnected from the unit or damaged. If so this is a pc repair issue, and a little tricky to do on your own.
Jul 03, 2009 | Battery Technology IBM ThinkPad T40, R50
I am unable to connect my IBM Think Pad Laptop to samsung 37lcd
you should be configure the display option , as extended monitor (2nd) output ,
Feb 24, 2009 | InFocus VGA Cable - 15 pin male-male, 4...
T40 ibm think pad connections
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Jan 25, 2009 | Visioneer OneTouch 5600 Flatbed Scanner
Need Wireless Card on my T40 23734NU
if u ve usb slot and pci slot in ur laptop u can use wireless, there are may brands available in market like belkin , netgear , u can connect install the drivers come along with the wireless card install it and u ll go online wireless
Nov 18, 2008 | IBM ThinkPad T40 2373 Notebook
Enhanced video/TV missing in Device configuration
After looking at the specs of the think pad T43 i think you need a new laptop. The port you need to transfer video from a computer is called S-video. Your laptop don't have it. Srry.
You could look into some sort of breakout box that you could plug into your VGA out port and from there to a TV. The VGA out port is for adding a stand alone monitor and is not compatible with most TV's.
Jan 25, 2008 | IBM ThinkPad T43 Notebook
Key Pad Quandry
Follow this link and it will tell you about anything that you would ever want to know about this laptop. (You may have to copy it and then paste it into you search/address bar)
Have a good day!
Nov 06, 2007 | IBM ThinkPad T40 2373 Notebook
Olevia LT32HVM 32 in. LCD Television Logo
52 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
