Question about Google Chrome
When downloading i get error 3 - Google Chrome
    President:
  • 1,216 Answers
Error 3 is a failure to communicate with Google Update. There are two known reasons for this:
  1. You're running Vista and you have configured Google Chrome to always run as administrator. This is a known issue with the Google Chrome auto-updating mechanism and can be avoided by simply running Google Chrome as a normal user. Additionally, keep in mind that for security reasons we recommend that you don't elevate the privilege of Google Chrome to administrator.
  2. Google Update isn't registered properly. To fix this, verify that GoogleUpdate.exe exists in the location specified in the Windows Registry Editor.
    The instructions below involve viewing your registry. If you're uncomfortable or unfamiliar with this, you may want to consult your local computer guru before following these steps.
    1. Go to the Start menu > Run.
    2. Enter regedit.
    3. Click OK. The Registry Editor should appear.
    4. In the tree view on the left, navigate to the following directory:
      HKEY_CLASSES_ROOT\CLSID\{2F0E2680-9FF5-43C0-B76E-114A56E93598}\LocalServer32
    5. The "Default" value should correspond to the location of your GoogleUpdate.exe file. Verify that GoogleUpdate.exe exists at the given path.
      • If GoogleUpdate.exe doesn't exist in this location, try uninstalling and reinstalling Google Chrome.
      • If GoogleUpdate.exe exists at a different location, right-click the 'Default' value and select Modify. Enter the correct file path and make sure you use double-quotation marks, e.g. "C:\Documents and Settings\%USERNAME%\Local Settings\Application Data\Google\Update\GoogleUpdate.exe"
Posted on Oct 01, 2010
  • Aviral Saxena
    Aviral Saxena Oct 01, 2010
    This is really th most updated soln.
    Thanks for your help U are truely an expert
I hv error 6266 in tally and m not able to fix his error pls suggest me the way tom resolve this error
Causes of the error:
Windows Tally Error 6266 are caused by misconfigured system files.
So, from my experience, If you received a Tally Error 6266 message then there is a 97.5% chance that your computer has registry problems.
The Windows Tally Error 6266 are easy to repair. By downloading and running the registry repair tool RegCure Pro, you can quickly and effectively fix this problem and prevent others from occuring. Simply click the links below for your free download.
To Fix the problem you need to follow the 3 steps :
STEP 1:
Download & Install RegCure Pro for Free.
NOTE: If the download link doesn't work you may need to Download it Directly from a Mirror Here.
STEP 2:
Click "Quick Scan" Button to Scan Your Computer.
STEP 3:
Click the "Repair All" Button to Repair Your PC!
Nov 05, 2015 | Computers & Internet
What does it mean when I receive error code 1102?
To Repair (Error Code 1102 Kyocera) error you need to follow these steps:
Step 1:
Download the (Error Code 1102 Kyocera) Repair Tool
http://www.almuseo.com/download-repair?Error%20Code%201102%20Kyocera
Step 2:
Click on the "Scan Now" link
Step 3:
Then click on 'Fix'. The Fix is complete.
*File size: 1MB
Download time: <45 Secs
Aug 01, 2014 | Kyocera Office Equipment & Supplies
GETTING ERROR 19 ON MY HL-DT ST DVDRAM GSA-T40N ATA PLEASE HELP
Windows Error 19 are caused by misconfigured system files.
So, from my experience, If you got Windows Error 19 then there is a 96% chance that your computer has registry problems.
The Windows Error 19 are easy to repair. By downloading and running the registry repair tool WiseFixer, you can quickly and effectively fix this problem and prevent others from occuring. Simply click the links below for your free download.
STEP 1: Download & Install WiseFixer for Free using the link below. http://download.wisefixer.com/download/bestlens/WiseFixer.exe
STEP 2: Click "Quick Scan" Button to Scan Your Computer.
STEP 3: Click the "Repair All" Button to Repair Your PC! Then restart and try again
Jun 20, 2011 | Computers & Internet
I have ir4570 error code e00007
It is my pleasure to guide you.
Your Canon iR 4570 All in One Printer Manual iR4570
User's Guide can be downloaded at http://download.canon.it/manuali_operatore/files/iR4570_USR_ENG.pdf
Look at Chapter 3 Troubleshooting
List of Error Messages ..3-6
List of Error Codes without Messages. . 3-6
You will find the list of error codes.
Also, http://servisfc.blogspot.com/2010/12/detecting-error-e007-for.html
gives the following;
QUOTE
Detecting Error E007 at canon copier iR2270, iR2870, iR3570, iR4570, iR3530.
As part of its protective mechanism, the machine checks for the following error conditions.
Error Code: E007
Detail: 0000
Sympton: The fixing film rotates in an abnormal way.
Description: The reading of the main thermistor is in excess of 100 deg C with the fixing motor in a locked state and in addition, the machine fails to detect the marker signal for 6 second.
UNQUOTE
Good luck and please post back that you are successful, giving thumbs up, or that I can be more helpful.
Jun 09, 2011 | Office Equipment & Supplies
PS3 error code 8002F1F9
this error code is due to internal error caused by us ............
ERROR CODE 8002f1f9
has a solution you can download the repair guide to fix this.. your problem can be solved to do so ...... Click Here to Get Solution .......
Jan 20, 2010 | Sony Playstation 3 (PS3) Console
Ringtone download error on iphone
retap the button to try downloading again and once you see the pause button to pause the download press it and it downloads trust me
Jan 02, 2010 | Apple iPhone 3G Black Smartphone
Installation Error
For a download to download without any errors the ps3 has to stay on until the download has finished.
If you turn the ps3 off part way through a download and then turn it back on at a later date the download appears to just carry on from where it was, but it actually will give you an error message when you try to use the download.
I hope that makes sense and helps.
Apr 02, 2009 | Activision Call of Duty 4 Modern Warfare...
Error
DOWNLOAD THIS BOOK FOR FREE AND SOLVE ANY PC HARDWARE, SOFTWARE OR OPERATING SYSTEM PROBLEMS.
DOWNLOAD NOW......
Download mirror 1 ( Hosted by HostingDude)
Download mirror 2 ( Hosted by Softpedia )
Download mirror 3 ( Hosted by Soft32 )
Download mirror 4 ( Hosted by fileflyer )
Download mirror 5 ( Hosted by Rapid Share
373
Jul 29, 2008 | Computers & Internet
Google Chrome Logo
278 people viewed this question
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
