Question about Gigabyte GA-8I845GVM-RZ Motherboard
How to connect a front panel audio connectors,pls provide me a pin diagram
  • 13433 Answers
SOURCE: MOTHERBOARD AUDIO PIN CONNECTIONS
The pins are pretty much universal, I'm 90% certan that the other one of these is correct for you.
Posted on Feb 11, 2008
map9966
  • 2351 Answers
SOURCE: No sound from front panel of GIGABYTE GA-MA69G-S3H
Aloke,
It does mention in your manual (top of pg. 28 -notes), that in order to use the HD Front Panel Audio connector the pin configuration are different than the AC97 connections. Your current case is set up for AC97. You will have to contact Mfg. for the case click the link for Gladiator support:
http://www.a-top.com/jsp/info.jsp?number=3
You can try this, open up your control panel, look for an icon that's named Sound Effects Manager. Open it. Click speaker configuration.
This is part of Realtec's software. This is where you can setup & check both front & back ports (Audio & Mic).
If this part of Realtec did not install goto Gigabyte & down load your audio software & re-install it. (Just a suggestion).
http://www.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2554
Hope this helps. If you make the call it will be a fix.
Good luck.
Posted on Mar 14, 2008
  • 7 Answers
SOURCE: I need a pin diagram.
pin diagram of motherboard....?which model...
Posted on Jan 07, 2009
joecoolvette
  • 5660 Answers
SOURCE: Since I have been unable to find a User Manual for
I found the Motherboard Manual for it. It comes as a Zip file.
At first my zip extractor seemed to have problems with it. Unzipped it anyway.
Comes as 8 small files. (Sheesh!)
I'll give you the link to the download website. I'll also tell you how to connect up the Front Panel header, just in case you have problems unzipping the files like I did!
Download website for the Motherboard Manual for the Chaintech 9JBA.
http://www.elhvb.com/mobokive/Archive/Chaintech/manuals/index.html
Scroll down the list on the left. In blue it's -> 9jba0 <- (No, I don't know what the zero is for)
Takes you to another page. Under -> Filename, click on -> 9jba0.exe <- It's 4624KB in size.
(That's about 4.6MB's. Not very big)
It will ask "Do you want to save this file?" Click on Save.
Then the Extraction Wizard will come up. Click on unzip.
If you don't have your downloads going to your My Documents folder, it will pop up these 8 files on your desktop. They're PDF files, and you have Adobe Acrobat Reader on your computer, so it will open these files.
Now, in case you can't download these.
Not to offend, but the manual is a piece of junk. Good thing I've got years of experience with computer motherboards, and reading crappy motherboard manuals.
Hardware setup is in file -> 9bja0-2.pdf (By the way. You can enter the CMOS Setup utility by pressing the Delete key, right after the Chaintech 'splash screen'. { Logo screen)
I am looking at file -> 9bja0-1.pdf now.
I had to expand the PDF file by 800% to see the Front Panel Header. IT IS ->16 pins. 2 x 8
Orient the motherboard, so we're on the 'same page'. Processor is up towards the top, expansion slots, (PCI) are to the left. The Front Panel header is down to the very bottom right corner.
It has -> FTP under it. To the left of it is another header. It has Smark Card under it. (No I didn't misspell it. That's what the mobo manual states) Do Not connect anything to the pins in the Smark Card area.
The Front panel header going lengthwise, there are 7 pins on top, 8 on bottom. Across the top there are 3 pins, NO pin, then 4 more pins.
Pin 1 is on the Bottom all the way to the Left. It doesn't state if it goes Pin 1, 3, 5, 7, 9, 11, 13, and 15,
for the Bottom row of pins, or 1, 2, 3, 4, 5, 6, 7, and 8.
I'm going to number the pins across the Top as Pins, 2, 4, 6, NO Pin, 10, 12, 14, and 16.
Bottom row of pins is Pins 1, 3, 5, 7, 9, 11, 13, and 15.
Top Row
Pins 2, 4, and 6 are for the Power On LED light. The Positive attaches to Pin 2.
There is No Pin 8.
Pins 10 and 12 are for the Green Power switch. Suggest you DON'T connect anything here.
Pins 14 and 16 are for the Override Power Button. Suggest you DON'T connect anything here.
Bottom Row
Pins 1, 3, 5, and 7 are for the internal speaker. Pin 1 is for the Positive connection.
Pins 9 and 11 are for the Power On switch.
Pins 13, and 15 are for the HarDDrive activity light. Pin 13 is for the Positive wire.
More info:
This Chaintech motherboard uses Pentium 4 processors, that use a Socket 478. The processor FSB is 400MHz. (You can't use P4's with a 533MHz FSB, nor ones that use a 800MHz FSB. Go to Wikipedia.org
In Wikipedia's search bar, type -> List of Intel Pentium 4 Microprocessors <-
Look through it, and you'll see P4's that use the Socket 478, and have a 400MHz Front Side Bus)
Has the Intel i845 Northbridge chip, and the ICH2 Southbridge chip. This is the 'motherboard chipset'.
Actual name is Northbridge/Southbridge chipset.
Has 3 ram slots. Maximum TOTAL Amount of ram is 3GB. Maximum Amount for EACH ram slot is 1GB. Uses PC133 ram. (SDR Sdram. Commonly just known as Sdram. ALL ram from Single Data Rate Sdram up to DDR3 Sdram, IS Sdram. That's why just stating just ->Sdram is a misnomer!)
Has to be Low Density ram, and Non-ECC.
The AGP graphics slot is a Universal AGP slot. BUT, it only uses AGP 2X or AGP 4X graphics cards.
They must be able to turn down to 1.5 volts. Using a 3.3 volt AGP graphics card, will result in System Boot up failure, malfunction, etc.
Uses IDE harddrives. (IDE is also referred to as EIDE, ATA, and PATA)
It's an ATX form factor motherboard.
Posted on Apr 18, 2009
bad_theta
  • 31 Answers
SOURCE: asus p5pe-vm front panel audio connector (10-1 pin FP_audio)
Look this picture below, this is ASUS P4VM front panel.
Hpe its solve your problem....
Posted on Jun 01, 2009
I am looking for a wiring diagram for the mic in, mic power and mic ground on a gigabyte motherboard 8vm533m-rz
"The front panel audio header on an Intel® Desktop Board lets you connect to a front panel audio module built into a system chassis. This document describes the header pin-out configuration for connecting a chassis with Intel® High Definition Audio (HD Audio) or AC'97 audio.
Note HD Audio headers are pin-compatible with AC'97 chassis and connectors. "
-intel Desktop Boards Front Panel Audio Header Pinouts
Sep 22, 2014 | Computers & Internet
Need a wiring diagram for a rs780m03g1
http://www.ebay.com/itm/FOXCONN-RS780M03G1-8EKRS2HM0D-DDR2-HDMI-PCI-MOTHERBOARD-/250896178535
1) http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
2) Product Views;
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rtc.shtml
B - Processor Core Power Connector;
is the connector on the motherboard for the 4-pin ATX +12 Volt power cable.
Located close the motherboard top edge, left side. Yellowish 4-socket hole square connector.
General example of connector, and power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
2) D - CPU Fan Connector,
The Processor fan connector is white in color, 3-pin, and above the processor socket.
3) F - Main Power Connector,
The 24-pin ATX main power cable connector on the motherboard, is to the Right of the Ram Memory slots
4) N - Front Audio Connector, (Front Panel audio ports)
Red in color, 9-pin header, and is located below the white No.2 PCI slot, at the bottom of the motherboard.
5) P - System Fan Connector, (System Fan = Computer case fan)
White in color, 3-pin header, located below the No.2 PCI slot, at the bottom of the motherboard.
6) Q - IEEE 1394 Connector,
For the front panel Firewire (1394) ports.
Black in color, 9-pin header, located at the bottom right corner, of the white No.2 PCI slot
7) R - USB Connectors, ( Front Panel USB ports )
F_USB 1 through F_USB4.
Located at the bottom of the motherboard, and these four separate headers support TWO USB ports each. Yellow in color.
8) S - Front Panel Connector,
located at Bottom/Right corner of motherboard.
Pin 9 is N/C also.
Not Connected. Used for +5 Volt power for the factory.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 27, 2012 | Gateway E-4300 PC Desktop
Front panel connection to mother board Power switch pin
Hi careyfraser,
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
Hopefully this information helps.
Thank you for using FixYa.
Sep 23, 2011 | Asrock G31M-S Motherboard
I have an Asus P5QL PRO Motherboard and I'm trying to connect the FP audio and I need some help on how to connect it up properly. On the heaphones lead I have 4 connectors: EAR R EAR L RETURN...
Hi
Pin arrangement for Front panel Audio is usually:
Pin 1 Left MIC-IN Pin 1 right GROUND
Pin 2 Left MIC VVC (or MIC Power, or MIC BIAS) Pin 2 Right empty
Pin 3 Left R EAR (or R OUT) Pin 3 Right R RETURN
Pin 4 Ground or Empty Pin 4 Right empty
Pin 5 Left L EAR (or L OUT) Pin 5 Right L RETURN
This arrangement should apply to both the HD AA/FP or the Standard AC'97 Headers.
I hope this helps
Aug 28, 2011 | ASUS P5QL PRO Motherboard
I lost the connection's posisition of front power switch on my MS 7309, can you please send me a diagram of connections. thanks...
2. Just plug the front panel switch headers to the JFP1 main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note: The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
Thank you for using Fixya.
Aug 05, 2011 | Computers & Internet
I want to know where the connection points are on the motherboard for the front mic and audio jacks. I have a epox ep-5pdaj motherboard. Will you send me a diagram please.
close to the back panel of the mainboard, below the back i/o connectors and 3.5mm audio jacks.
You need to remove the two jumpers from the pins, this is where you connect the front panel audio connector, if your case has each wire separate. then please look at this webpage http://www.intel.com/support/motherboards/desktop/sb/cs-015851.htm look at the part "For AC97 Front Panel Audio" PIN 1 should read MIC. If not, then scroll down, you are reading the wrong part of the page.
Aug 07, 2010 | EPoX EP-5PDAJ Motherboard
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
I want to connect front pannal audio port what are the avialble extra audio connector in d845 epi m/board
Front panel 9-pin audio connection is located at "A" on the diagram. There will probably be two jumpers there - remove them and plug in the audio connector It can only fit one way.170eb7d.jpg
Nov 27, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Pls, need to attach front panel connectors to VTE
Diagonally opposite(diagonally opposite corner) to where you connect your mouse and keyboard, there will be pins on the motherboard to connect the front panel connectors. You can identify it by names written near it like SPK or Speaker, on/off and so on. The connectors on the front panel will also have names written on them. Just match and connect them. Reset switch, Power and speaker will not be a problem connecting. But hard disk light connector will be a little tricky. you have to connect to the correct polarity. USB connectors will be near these pins and will be labled as USB5 or USB4 and so on, on the motherboard. You will be able to insert the USB connector in one direction, so connecting it is not a problem.
Aug 21, 2009 | Soyo Computers & Internet
Case only has AC97 front audio connectors. The motherboard (790i ultra sli) only supports HD audio. How can I connect my front panel audio?
If you can get a pin out diagram of both the HD audio connector and the AC97 connector you can build an adapter to connect them.
Howevet the price of Midlevel Soundcards is relatively cheap( I think you could buy a Creative XFi card for less than the cost of the adapter mentioned above) Which would give you the connector you desire plus Surround sound and EAX support.
Hope this helps
Dave
Nov 06, 2008 | Computers & Internet
Gigabyte GA-8I845GVM-RZ Motherboard Logo
589 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
