Question about Nokia E71 Smartphone
Am using nokia e71, my network signal is very low with e71 compared to other phones, how to increase the signal strength in my nokia e71, plz help
E71 network is very low but our area is also good network pls solved it
Posted on Jun 15, 2013
5 Suggested Answers
SOURCE: Nokia 6100 network problemmy phone was not found a signal..no network!...
You press '#' and then press 'call' key and then wait for the network signal to load. Be sure your sim will work also in your area.
Posted on May 27, 2009
freetek
  • 5568 Answers
SOURCE: e71 nokia fell in water..no signal..all ok otherwise
If your (bad) luck is holding, low-level circuits have been damaged by current from elsewhere, especially if trying to connect since this uses circuits capable of much higher power than the low-level ICs were intended to deal with.
Since it isn't working anyhow, try this:
Add a drop (not more) of dish detergent to a couple of quarts of warm distilled water - no product that has anything added to the water. Remove the battery from your phone, dunk it into the solution and swirl it a bit to ensure penetration of the solution.
Rinse it in distilled water only, shake out whatever you can without slamming against anything. Allow it to dry (battery compartment open) in any warm place such as a sunny railing, window sill, etc. for at least two days.
I have used this method successfully on a number of electronic items with good success.  The most extreme incident was a word processor I serviced (many moons ago) belonging to an author who had weeks of work stored in the unit when his tom-cat decided it was a good place to urinate.
Good luck-
Posted on May 23, 2009
SOURCE: how to increase sound in nokia6600
is there any fm radio software for nokia 6600
Posted on Feb 23, 2008
creative_fix
  • 395 Answers
SOURCE: deleted my contacts while updating the NOKIA E71 software
This is a pretty messy situation we've got, I'm really sorry but you'll need to start compiling your contacts all over again.
They're lost and that's the hard truth.
Sorry about that.
Regards
Posted on Aug 20, 2009
Nokia e71 no signal
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jul 22, 2012 | Nokia E71 Smartphone
My samsung phone has a low signal strength, how do I increase it. I have turned the phone on and off, removed the battery. Can I use those antenna boosters that go behind the batteries tp increase it.
Usually when devices have low signal strength it is either as a result of the network IC or the signal at the particular location is just low. Although you can attempt to use signal boosters but often times they have side effects if the phone usage is quite heavy as the attract more microwaves than recommended for human body contact. You can attempt the use of signal boosters and see how the performance becomes.
Hope this ssolution has been helpful?
May 01, 2011 | Cell Phones
How to remove the master security code for nokia mobile model No:1209 plz tel me
On the main screen type
*#06# for checking the IMEI
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Code (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Code activation.
*#4720* - Half Rate Code deactivation. The phone will automatically restart
May 01, 2011 | Nokia 1209 Cell Phone
Its very slow in processing any thing
Try these codes:
*#3370*
Nov 09, 2010 | Nokia 5800 XpressMusic Smartphone
Battery Rundown Easily
try this *#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though. hope it'l help u (plz vote me) thank you.
Mar 31, 2010 | Nokia 1100
Singals are not stable when inside the house
try this out
Sep 22, 2009 | Nokia 6300 Cellular Phone
Net work problem
- make sure your phone is open line, so all sim you insert can be use,
- make sure you are using your phone in the area with a network signal
- try to check with celphone technician, some nokia phones have problems with their network when its coming of age.
Aug 25, 2009 | Nokia 6600
Nokia 6300 reception is now weak
1)try this out this may be usefull for you
2)there might be the problem with service provider try to change your service provider and check it out.
Aug 25, 2009 | Nokia 6300 Cellular Phone
Nokia 1600 is dead how to repair it
If your phone appears to have problems with power, the problem may be with the phone, the battery, or the charger.
  • The first thing to try is to connect the phone to its charger. Connect the charger to a power source, wait for a few moments, and then try to turn the phone on.
If the phone still won't power on, please perform the following checks:
  • Fully charge the battery according to the instructions presented in the user guide.
  • Remove and re-insert the battery according to the instructions presented in the user guide.
  • Check that you are using a Nokia battery and charger compatible with your phone model. You can check compatibility from the Battery Compatibility Chart and Charger Compatibility Chart.
  • If you have access to another battery and charger of the same type as yours, try substituting them to determine if the issue is with the phone, the battery, or the charger.
If you are unable to test your phone or it still won't power on, please bring it to the nearest Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
My phone is always low on power
If your phone appears to have problems retaining power, the problem may be with the phone, the battery, or the charger.
  • Check that you are using an original Nokia battery and charger compatible with your phone model from the Battery Compatibility Chart and Charger Compatibility Chart. If your battery features a hologram label, you can authenticate that the battery is an original Nokia product with our Check Your Battery service.
  • Even high-quality batteries like Nokia's will eventually lose power retention capacity. If it is time to replace your battery with a new one, be sure to purchase an original Nokia battery from an authorized Nokia dealer.
If you are unable to test your phone, charger, or battery or need further assistance, please bring them to a Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
My calls break up/are dropped
Dropped calls or low sound quality during calls can result from low signal strength or momentary gaps in network coverage, either at your end or the other end of the connection.
In most cases, your operator or service provider is the best source of assistance with issues regarding signal strength.
  • Signal strength is indicated by the signal indicators at the left side of the phone's display, these indicators move up as the strength of the signal increases and down as the signal decreases.
  • To increase your phone's signal strength, try moving your phone slightly, or move towards a window if you're calling from inside a building.
If you continuously experience low signal strength in a certain area, it may be that network coverage is insufficient there. Your operator or service provider can provide you with more information on network coverage.
If you believe that the problem may be with your phone instead of the network, please bring your phone to a Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
My phone won't ring
Please try the following troubleshooting tips:
  • Ensure that you phone is on and that there is sufficient signal strength.
  • For some phone models, if there is a headset attached to the phone, it will not ring through the speaker, only through the headset. Detach the headset and retest the phone to determine if that resolves the issue.
  • If the phone's profile is set as "Silent", "Flight", "Online", or any other profile where ringing is silenced, it will not ring. Change the profile to the "General" or "Normal" profile and retest. Instructions for checking and changing your profile are included in your user guide.
  • Ensure that a ring tone has been enabled and the volume is not too low. Instructions for adjusting volume and selecting a ring tone are included in your user guide.
  • If call divert is activated, your calls may be going straight to voice mail without your phone ringing. Instructions for activating and inactivating call divert are included in your user guide. For assistance with voice mail, please contact your operator or service provider.
If your phone still won't ring, please bring it to a Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
My phone won't send/receive messages
Email, text messaging, and multimedia/picture messaging must be supported by your contract with your operator or service provider. In addition, your phone must support these features and have the correct settings.
  • Check the types of messaging supported by your phone model. You can find this information in the user guide. Look for the terms SMS for text messaging and MMS for multimedia (picture/audio) messaging.
  • Contact your operator or service provider to check that email, text messaging, and/or multimedia (picture) messaging are included in your service contract. Also verify that roaming is supported when you are not within your home network.
  • Install messaging settings for your phone. You can download settings for free from our Setting service.
If you are still unable to send or receive messages, please bring your phone to a Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
I want to recycle my phone and accessories
Just drop of your old mobile phone and accessories at any Nokia Care point. Nokia will send the old products to closest Nokia approved recycling company. Mobile phone recycling leads to both material and energy recovery from old devices, and helps ensure the proper disposal of harmful substances.
Apr 24, 2009 | Nokia 1600 Cellular Phone
Nokia E71 Smartphone Logo
615 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
