Question about Amana NAV5800A Top Load Washer
Waher maytag my washer spins slow and makes a kind of grinding noise and does not drain
  • Anonymous Mar 19, 2014
  • 246 Answers
Pull your washer forward then tilt the top backwards until it sits at about a 45 degree angle. There should be a belt and 3 pulleys underneath. Remove the belt (one of the pulleys will move to allow slack) Ignore the moving pulley and the large pulley in the center. The third pulley is your pump. Try to turn it by hand, it should move freely. Presumably, it wont and will need to be replaced.
Posted on Jun 17, 2008
Waher works fine but when it gets to the spin cycle it starts making a horrendous noise like a bearing or something
the most common probelm is the drain pump. tilt the machine back so you can see underneath then grab the belt and push or pull it by hand and you should here the grinding noise you may aslo be able to see a silver ribbed disc stick up from the drain pump touching the bottom of the washer replace the drain pump
Aug 25, 2010 | Magic Chef CAV2000AWW Top Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Admiral aav-1 makes loud grinding will not spin or drain
Hi, the drain pump impeller is damaged. you will need to replace the entire pump(drain) in this case.
You will hear this noise when the impeller become separated from the actual drive stud or, shaft.
Jul 13, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Washer loud grinding noise spin stop
if its brand new it shouldnt be making a loud grinding noise id get it checked make sure they removed all shipping bolts
May 17, 2009 | Maytag Washing Machines
Roper RAS7233KQ0 NO SPIN
chek the water elctrovalvles and replace it , this most be 1 solution another will the hyperstatic hose or sensor of load size
Mar 04, 2009 | Roper RAS8244KQ Top Load Washer
Agitator now moving VERY slow one way, making loud grinding noise
Hi, this is a bad transmission gear box that is stripped at the moment. i recommend purchasing a agitator kit and a new transmission Assembly and clutch as well. this will fix your issues
Jan 28, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Washing machine will not spin
If this is a Whirlpool washer, you have a broken motor coupler
Jan 23, 2009 | Washing Machines
Amana NAV5800A Top Load Washer Logo
59 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
