Question about HP Compaq Presario SR1250NX (PJ534AA) PC Desktop
Where Can I Get A Compaq Presario SR1250NX motherboard? Mine Just Gave Up And Nothing Comes Up On The Monitor> (no Signal)
4 Suggested Answers
  • 90 Answers
SOURCE: dont have the disc
You can order the recovery disks from HP here:
https://warp2.external.hp.com/driver/dr_country_select.asp?Product=5069-7837〈=en&cc=us
If this helps please rate my solution.  Thanks
Posted on Dec 12, 2008
  • 17 Answers
SOURCE: sr1720nx compaq presario no signal to monitor
Try changing the VGA cable or the other cable you are using.......
If that does not resolve your problem and that the monitor is good it means that your desktop's graphic card is damaged.....
Try replacing the graphic card or if it is an internal one..... add one in your agp or pcie slot
Regards :)
Posted on Jan 22, 2010
  • 8909 Answers
SOURCE: Compaq Presario SR1650 had a virus, so the HD was
Clean the virus from the original drive would have been the easiest answer.
If you fitted a replacement drive, have you got as far as the BIOS menu? If not probably something is not happy.
Put it back as it was and trace your steps.
Posted on Jan 20, 2011
Why won't my compaq presario 1250 load windows?
1 - You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose safe mode).
Win 7 - Start > Search type System Restore
XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
2 - Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 11, 2012 | HP Compaq Presario SR1250NX (PJ534AA) PC...
I have a presario SR1250NX and it won't come out
if you are not an technician i'd suggest to take it to the service center.
i think it might be the psu/memory related issue and as an user you are not able to remedy the situation yourself
Mar 09, 2012 | Compaq Computers & Internet
MY COMPAQ SR1250NX CD WRITER WILL NOT OPEN WHEN I PRESS THE BUTTON IT DOESN'T OPEN
Dear friend as your problem is not a big issue....... its a problem with elastic rubber .... its look like a hair band but thinner than hair band...... so please change it.......your cd writer will be all right..............
Nov 28, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
My computer want power up the green led light is on
if the green light is on then the computer is powered up, i suspect u have a defective monitor, not that uncommon, the olny way to check it is have a computer repair shop hook it up to another working system and see if the monitor turns on, if it is the monitor just replace it, monitors are very cheap right now, just bought a 19" for $89.00, mine did the same thing, green light nothing on screen.
Jun 09, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
HP Compaq Presario SR1250NX PC , will not turn
If no lgihts, sounds or anything at all, more than likely power supply.
Dec 30, 2009 | Compaq Computers & Internet
Green light comes on and the fan but monitor will not
Hello.
Could be the monitor or your Presario's VGA card. Swap the monitor with another system to see where the problem lies. If another monitor works on your system , it's your monitor. If another monitor doesn't work, then the problem is the VGA card.
Hope this helps.
Nov 10, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
My sr1250nx won't power up. blinking green light in back right below power cord
generally in dese cases its a HW problem> open up the side panel> disconnect the thickest bunch of power cable on the motherboard(ATX connector) it either has a 20-24 pin connector> then turn on the PC> if the Light at th back is steady> the motherboard has gone bad> if its off> the power supply has gone bad
Oct 05, 2009 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Computer wont turn on or off
power unit PSU dead is there a fan motion ? beware of PSU that sleep in the night ... mine did it and destroyed the syste, also the auto safety may have dumped out and it will not resume unless the system is repaired, could be power or maybe an internal chip Memory short, processor dead, fan stopped inside ... never run without it there may be a loose connection stopped fan . Mike
Jun 13, 2009 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Dont have the disc
Dec 12, 2008 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Compaq Presario V2000 fails to boot up
3 beeps is the Beep code for "Base 64KB RAM Failure". Lets hope that you are lucky and the problem is your memory. If you have two memory sticks in the computer, then try to take one of them out. Try different combinations such as swapping between the memory slots that are available. If you still getting the same error code, then your motherboard is shot.
Aug 16, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario SR1250NX (PJ534AA) PC Desktop Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
