My BenQ G610HDA lcd monitor power does'nt open
myob247
  • 1342 Answers
SOURCE: how to get audio from a benq fp767 lcd monitor
You have to plug the audio wire from the monitor into your speaker jack on your computer.
Posted on Jun 13, 2008
SOURCE: BenQ FP731 17" LCD Monitor Problem
Had the compete dark screen problem. Green/amber power light was coming on and off as expected but no image would appear on the screen.
Found PF751 to be open.
Thnaks for the help people.
Posted on Oct 08, 2008
SOURCE: Benq T701 LCD monitor
I had a similar problem: the backlight on my Benq T701 only functioned for a couple of seconds every time a turned the monitor on and then the backlight switched off (sometimes in two stages). An electronics guru at work said with those symptoms the transistors rarely were the problem and I just needed to resolder the connections of the high voltage coils onto the PCB. On visual inspection those solder connections seemed ok, but when I tried to reflow the existing solder at one connection I spotted the problem: just a thin surface layer of solder was present and I had to add solder to fix the problem. The 4 coils each have 6 leads on one side and 2 on the other. I only soldered the connections on the side with 2 leads. In just 30 minutes and without buying parts the monitor is now up and running again.
Posted on Jan 22, 2009
  • 732 Answers
SOURCE: how to open the BENQ G2400W LCD monitor to repair
Even if you watch 10 video clips of LCD monitor disassembly at YOUTUBE, you will not find it very easy to do!! Do not use ANY sharp cutting instruments to "PART" the rear cover from the front bezel. One carless slip and it's a trip to local hospital "ER" to be sewed back together!!! Protect the GLASS lcd panel at ALL COSTS. YOU CRACK-IT, YOU BOUGHT IT, YOU OWN-IT, TOYOTA!!! 12fixlouie
Posted on Sep 14, 2010
SOURCE: Benq FP71G LCD Monitor - Can't keep POWER ON / Button Problem?
benq fp71g no display what can i do
Posted on Jul 01, 2011
Benq lcd fp0537s on for just 2 second
There are one or two capacitors in the power supply that open," leaving a slight puff at the top" in some cases.
Mar 16, 2012 | BenQ FP92W LCD Monitor
BenQ Q24W5 LCD monitor circuit diagram
HI.............
Repairing BenQ 17′ LCD Monitor
I came across a common fault problem in BenQ 17′ LCD Monitor. The problem is have power but no display. Once you has opened the LCD cover, check the pico fuse for open circuit (very common), the push pull transistors C5707 for short circuit and the Buck royer circuit p-channel fet FQU11P06 also for short circuit too. For your information, if you can't get the FQU11p06 you can always use FU9024N as a replacement. Resolder all the high voltage transformer pins and replace the components above and I'm sure you will bring back the life of this BenQ 17′ LCD Monitor.
You may go to this fairchild semiconductor website to download the spec of the FQU11P06 P-channel FET.
http://www.fairchildsemi.com/ds/FQ/FQU11P06.pdf
GOOD LUCK.............
Sep 23, 2011 | Computers & Internet
Repair BenQ Q24W5 monitor
HIIIIIIIII...................
My benq lcd fp767 have power but no display,,,i want have a troubleshooting guide about the lcd,,,pls help me
First check the vga cable, video cards of your pc.if all of these are ok open your LCD monitor check the power board for boated capacitor, open secondary pico fuse or fuseble resistor, replace it with the same value. The defective lcd panel can cause of dim dispaly but the power is ok.
Oct 03, 2010 | BenQ FP767-v2 - 17" LCD Monitor
How to open the BENQ G2400W LCD monitor to repair the power button that got pushed into the opening
Sep 14, 2010 | BenQ FP731 17" LCD Monitor
Do you know how to open a benq fp91g+ monitor?
Here is the service manual: http://elektrotanya.com/?q=showresult&megnev=BENQ&megnev2=FP91&kategoria=&kat2=all
Most of the time you will use flat blade screw driver, starting at the bottom edge to pry open the case then work your way around, also look at YOUTUBE, just search for HOW TO OPEN LCD MONITOR.
BenQ makes monitors for DELL and HP.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | BenQ FP91G+ Monitor
No display
BenQ made a lot of monitors for Dell. You may want to look at Dell pictures.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Apr 11, 2010 | BenQ FP757-v2 - 17" LCD Monitor
Sudden Shutdown of the unit, I Cannot use my FP72E BenQ LCD monitor Properly because at the middle of using it, it suddenly shutdown, open, shutdown again, open again. is this unit is capable for long...
For the monitor that is more than 2 years old, first place to look will be the power supply, look for bad caps with bulging top first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps; http://s807.photobucket.com/home/budm/allalbums
Feb 16, 2010 | BenQ FP72E 17" LCD Monitor
Benq FP731 LCD not start up, only green power lamp
Opening it will not likely solve your problem. Have you tried another monitor on the computer to see if the problem may be with the computer itself?
Mar 04, 2009 | BenQ FP731 - 17" LCD Monitor
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
