Question about Yamaha RX-V361 Home Theater Receiver
A/V reciever + Computer
Is it possible to connect my computers sound card to the receiver?
    Novelist:
    Scholar:
  • 100 Answers
Greetings tad1073,
Its more then possible to connect your sound card to your receiver, the question would be what connections are available.
Looking at your receiver's owners manual it does appear that you should have 3 digital inputs (2 optical, and 1 coaxial), so if your sound card has digital outputs it maybe best to use these. If your sound card does not, you should be able to invest in a "Y" audio cable that would go from a basic mini plug connection to a dual rca connector. You could then connect the cable to a line out (sugjested) or speaker out and then connect the rca side to a separate source (dvd, Dtv/Cbl, Dvr, CD, MD/Cd-R)
On a side note you might want to make sure some of your system sounds are deactivated unless you want to hear beeps, and bells while your using your receiver.
Enjoy.
Jon
Go Ahead. Use Us.
Posted on Jun 12, 2008
Hi,how do I connect up two 5.1 surround sytems to my PC Pavilion m9451ch I know all I need is a 3.5mm RCA jack into the amplifier and connect them up with the outlets on my computer this is OK for one but...
First, you need a sound-card in your computer that is capable of '5.1' operation.
Second, you need a receiver/amplifier that accepts '5.1' input.
This is usually achieved by a "optical digital" output on the computer's sound-card,
an "optical digital' connection cable, and an "optical digital" input on the amplifier.
May 09, 2011 | HP Computers & Internet
I can get picture with hdmi connected but no sound. Do i have to connect the optical digital audio cable from PC to TV to get sound? Actually the video and sound go to stereo receiver first, video passes...
If your video card supports audio over hdmi in that case you need to find the s/pdif port on you motherboard and the port on your video card (usually right next to and sli or xfire bridge) then you can send the sound thru the hdmi. if not you will have to connect your optical audio cable or a 3.5mm audio out to rca left and right out to your receiver for audio. what video card and mother board are you using? if you know this i can tell you exactly where the ports are for the spdif cable to video card and mobo.
Mar 15, 2011 | Computers & Internet
Sound won't play through Onkyo TX-SR605 when using HDMI
The chances are that you have selected an incorrect sound setting or not switched it on, for the HDMI you are using. With Onkyo receivers each connection will have it own settings for video and sound. You just need to look in the manual as to how to select the settings.
May 08, 2017 | Onkyo TX-SR605 Receiver
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
Can i connect my bose 5.1 speaker system to my pc directly without using a separate stereo receiver? my pc has a 5.1 hifi with optical sound card and an 800w psu.
no it can not. the sound card in your computer has no power behind it, only a signal. the acoustimass needs power from an amp. you can connect your computer to a home theater reciever and get what you are trying to do, with a simple 3.5 to rca cable.
Jul 15, 2009 | Bose Acoustimass 6 III System
I have a onkyo 706 reciever and I can't get any TV sound
Component (i.e. TV) should be connected to plug labeled IN (signal IN receiver).
Jul 15, 2009 | Onkyo TX-SR606 Receiver
No sound after plugging in HDMI cable to computer.
I think this is dependant on your graphics card in your PC. Most PC's with HDMI ports are purely for video not audio, check with your PC manufacturer/graphics card manufacturer to see if it supports audio from the HDMI port.
You may just have to link the audio from the audio output port on the PC to the reciever for audio and HDMI for video.
Jul 07, 2009 | Onkyo TX-SR606 Receiver
Yamaha sourround sound reciever HTR 5920- not working
Can you remove connection between the receiver and TV and then try ? If it still turns hums and turns off, then try disconnecting all the speakers and power it on. If it still turns off, then you have a bad receiver...Let me know..
Mar 20, 2009 | Yamaha 5.1-Ch. Surround Sound Home Theater...
XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
Mar 09, 2009 | Yamaha HTR-6130 Receiver
Digital/Optical Question
It's a pain in the butt getting the system set up to use the TOSlink from your PC.
Try this:
1. Hit the DVD button.
2. Use MODE/SET to get to DVD/OPT
3. Turn DSP off.
4. Use the TEST/SETUP button to make sure your speakers all work
5. Screw with your sound card!
Oct 14, 2006 | KLH R5100 Receiver
Yamaha RX-V361 Home Theater Receiver Logo
77 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
