Question about Hummingbird Exceed 9 (exmpi550305m0900u) for PC, Unix
All the Xserver display are in use. Exceed can not run without display.
Lg oven not heating after self cleaning. code f9
F9 stands for oven no heating. It will be displayed if oven temperature readout when oven temperature doesn't exceed 150F/66C in less than 5 minutes from set time. I would say you may have a heating element malfunction..
Oct 23, 2016 | LG Kitchen Ranges
How do I get picture back on TV which was working the night before, which is hooked up to HD cable box, thru HDMI?
OS info is always helpful, if say you are running some type of nix, it's likely not getting recognized by xserver or if your running some version of windows your display manager has shut it down because of a resolution mismatch.
May 26, 2014 | Amstron Fujitsu LifeBook E390 Laptop DC...
Every time I do an OS Xserver upgrade, I lose my a...
The most straightforward solution to your problem is not technical. You have hired two professionals (or one professional twice) to research your problem, determine why it is happening, and correct it. That implies that indeed, it CAN be that hard -- certainly harder than a technician halfway across the country with zero knowledge of your configuration and zero access to your server should be expected to diagnose off the cuff. Why don't you contact the professionals who fixed this problem for you before, and ask them what they found? After all, you paid for the solution, so they owe you an explanation. At the very least, even if you don't understand the explanation, you can come back to FixYa and provide their explanation, and I will be happy as an Apple-Certified Macintosh Technician to pursue the problem using that information.
May 12, 2010 | Computers & Internet
Problems with RC engine not running right!
Theres a idle screw located on engine under airfilter, should be small flat head. Clockwise will stop the carb from closing thus not cutting engine of. Also make sure you run car slightly richer than leaner. Hope this helps.
Mar 31, 2010 | Exceed-RC 1/8TH .21 Tectonic Nitro...
Synchmaster 913 The unit displays 'Not Optimum Mode 1280 x 1024 60hz' after being run to approx 1 hour
Hello. That message appears when the video signal from the computer exceeds the monitor's ability to display it. If the sync is set too high(i.e. max sync on the monitor is 60 Hertz at that resolution), you will get that message. Check the video settings in control panel--("appearance and themes" in XP), go to the "advanced" tab and look at the refresh rate. Most computer video cards are able to far exceed a monitor's display ability. Don't exceed 60 Hertz--check the users guide for specs--the lower resolutions can have higher refresh rates(useful in games) Sometimes, a little lower video quality can yield a big performance difference in the display because the screen can update itself faster. (I use a radio control flight simulator pgm that is heavy on video ability).---Hope I was of assistance!---Rick
Sep 22, 2009 | Samsung SyncMaster 913N 19" LCD Monitor
I get bad visual with sis mirage graphic card on my ubuntu 9.04 it doesn't work as it on microsoft windows...Please i need help over here.
Page 3, #27
http://ubuntuforums.org/showthread.php?t=958967&highlight=sis+mirage+graphic+card&page=3
UbuntuForums.org Is the best.
I have run linux on several different hardware and found that HP & IBM are by far the best.
Here is the link for the GDebi Package Installer:
http://launchpadlibrarian.net/20463699/xserver-video-sis671_ubuntu8.10-1_i386.deb
Sep 12, 2009 | Canonical Ltd. Ubuntu
Asus en8500 gt1 gb can run battle station pacific
Minimum System Requirements are as follows: clear.gif DirectX : clear.gif 9.0c clear.gif Hard Drive Space : clear.gif 8 GB Free clear.gif Operating System : clear.gif Windows XP/Vista clear.gif Processor : clear.gif Pentium 4 @ 3 GHz clear.gif RAM : clear.gif 1 GB (2 GB for Vista) clear.gif Yes, it should run the game without problems if the rest of your pc specifications meet or exceed requirements.
Aug 22, 2009 | ASUS Computers & Internet
Can find drivers for intel 945 vga in ubuntu
Sir please add the following lines to your /etc/apt/sources.list:
deb http://ppa.launchpad.net/siretart/ppa/ubuntu jaunty main
deb-src http://ppa.launchpad.net/siretart/ppa/ubuntu jaunty mainImport the appropriate GPG key:
sudo apt-key adv --recv-keys --keyserver keyserver.ubuntu.com 0xce90d8983e731f79Install the driver:
sudo apt-get update
sudo apt-get install xserver-xorg-video-intel-2.4Now you should be set. Restart X by running "sudo /etc/init.d/gdm restart" in a terminal and see if the graphics performance from intrepid is restored.
thanx and i hope this helps
Please rate this solution
Jul 17, 2009 | ValuSoft Ubuntu Linux for PC, Mac, Linux
Exceed not working on office network
Well, first, what is your internet connection bandwidth?
Most of the vpns drop the connections when the speed is not good enough, and that means your application won't work fine.
Also, when you use WiFi you can transmit upto 54megabits per second only (the wired network speed is 100MBPS), unless you have wifi N.
Anyway, first I would check the internet speed/bandwidth, test with a faster one, and if everything goes fine, then you know what the problem was :D.
Mar 05, 2009 | Hummingbird Exceed 10.0
Display issues
pls run setup or reinstall
Sep 20, 2007 | Hummingbird Exceed 10.0
Hummingbird Exceed 9 (exmpi550305m0900u) for PC, Unix Logo
2,683 people viewed this question
Top Hummingbird Computers & Internet Experts
Les Morrison
Les Morrison
Andrew Taylor
Andrew Taylor
Are you a Hummingbird Computer and Internet Expert? Answer questions, earn points and help others
