Question about Asrock P4i65G Motherboard
Good Morning, Running Windows XP Pro. I Have A P4i6g Motherboard. I Had 2 Each 512 mb ram (pair) and upgraded to 2 each 1gb ram (Pair). Installed ram and Tried Started Computer But It Will Not BootUp. Can't even get to my cmos. Can You Please Help Me? Your Response Will Highly Be Appreciated! Aloha! hawaiianrudedog@roadrunner.com
  • Asrock Master
  • 27,725 Answers
Make sure your updated RAM have a secure seating and are compatible with your motherboard also the RAM should be of the same brand/type for some motherboards even test the leads that are attached to your hard drive from your motherboard IDE/SATA including electrical extensions or just replace them probably faulty while youre at it test all leads attached to dvd/cd/3.1/2" drives one bad/faulty lead can cause a computer lots of problems
hope this helps
Posted on Oct 01, 2010
I have an asus m2n mx (windsor) motherboard and an amd athlon x2 3600+ processor . . . i have a pair of 667mhz 512MB (total 1GB) ram and a pair of 800mhz 1GB (total 2GB). . grand total(3 GB) . . My problem...
The manual for your motherboard states:
For dual-channel memory configuration (2), you may:
• install identical DIMMs in all four sockets OR
• install an identical DIMM pair in DIMM_A1 and DIMM_B1 (yellow
sockets) and another identical DIMM pair in DIMM_A2 and
DIMM_B2 (black sockets)
* Always use identical DDR2 DIMM pairs for dual-channel model. For
optimum compatibility, we recommend that you obtain memory modules
from the same vendor.
Sep 11, 2011 | ASUS M2N-MX Motherboard
I have msi motherboard p4nsli with 1 stick 2gb memory but in booting the memory shows only 512 mb instead of 2gb,..what seems to be the problem & a posible solution for this? Thank you.
Your MSI motherboard may use Interleave RAM. This means you need to insert 1Gb RAM modules in each pair of memory slots.
If your motherboard has 4 memory slots and they are color coded in pairs, then this motherboard uses Interleave RAM. Insert 1Gb RAM modules into the menory slots that have the same color.
May 07, 2011 | Computers & Internet
Hi I have Foxcoon P4M8007MB Motherbaord which has 1Gb memory (2 X 512 MB DDR2 installed) I have just bought 1Gb Kingston Value memory KVR533D2N4/1G X 2 Modules to upgrade to 2Gb ram but windows Ultimate...
Check out mo bo specs - you may have exceeded mo bo capacity. Or try a different memory stick - all memory are not created the same - some will work in one machine and not another. Experiment if you are within specs.
Sep 18, 2017 | Foxconn P4M800P7MA-RS2 Motherboard
Acer aspire m5100, AMD Athlon 64bit x2 dual core processor 5000+ 2.60Ghz. Win Vista Business 64bit. When i upgrade and put more than 3GB of ram into the machine, it turns off the lan and my display driver...
Acer official site says:-
Up to 4 GB DDR2 533/667/800 MHz SDRAM
(dual-channel support on four DIMMs)
Try these bus speeds and for dual-channel support read this article :-
Dual-channel architecture requires a dual-channel-capable motherboard and two or more DDR, DDR2 SDRAM, or DDR3 SDRAM memory modules. The memory modules are installed into matching banks, which are usually color coded on the motherboard. These separate channels allow each memory module access to the memory controller, increasing throughput bandwidth. It is not required that identical modules be used, but this is often recommended for best dual-channel operation. It is possible to use a single-sided module of 512 MB and a double-sided module of 512 MB in dual-channel configuration, but how fast and stable it is depends on the memory controller.
If the motherboard has two pairs of differently colored DIMM sockets (the colors indicate which bank they belong to, bank 0 or bank 1), then one can place a matched pair of memory modules in bank 0, but a different-capacity pair of modules in bank 1, as long as they are of the same speed. Using this scheme, a pair of 1 GB memory modules in bank 0 and a pair of matched 512 MB modules in bank 1 would be acceptable for dual-channel operation.
Modules rated at different speeds can be run in dual-channel mode, although the motherboard will then run all memory modules at the speed of the slowest module. Some motherboards, however, have compatibility issues with certain brands or models of memory when attempting to use them in dual-channel mode. For this reason, it is generally advised to use identical pairs of memory modules, which is why most memory manufacturers now sell "kits" of matched-pair DIMMs. Several motherboard manufacturers only support configurations where a "matched pair" of modules are used. A matching pair needs to match in.
Good luck
Rate the solution if got help
Dec 06, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
Hp Compaq dx2200 MT RAM Problems
Firstly, you have to know that you can upgrade RAM as Double or Half of your pre-installed RAM. For example, like your pre-installed RAM is 256 MB, you can only upgrade RAM of capacity 128 MB or 512 MB. Secondly, check your previous installed RAM's speed that is shown in Ghz. You can only upgrade RAM to its similar speed, otherwise you get slow performance of PC.
Jul 18, 2010 | HP Compaq dx2000 Microtower PC Desktop
Upgrade to 3GB in laptop?
yes you can install 1GB in one slot and 2GB in other slot. but you have to make sure that the RAMs must have the same BUS speed.
Please make rating to my answer
Sep 05, 2009 | Gigabyte GA-8PE667 Ultra Motherboard
I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Aug 05, 2009 | ASUS K8V-MX Motherboard
Graphic card for GA-8IPE1000 series
HI there.
There are loads of makers of memory and graphics cards out there to choose from.
For the ram i would recommend Corsair or Kingston, you can get this ram as a matching pair so the both run at the same speed, the best ram to get is DDR 400.
As for the graphics card, i recommend ATI radeon X1650 Pro 512MB graphics card.
These upgrades will make your machine purr like a kitten with an excellent gaming experience.
Good luck and thanks for choosing FixYa!!
May 27, 2009 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
Can i run ati radeon x1650 512 on asus k8N motherboard
Yes you can run the AGP version of the Radeon 1650 pro on your system. It is always best & recommended to upgrade memory in pairs. You could upgrade to `gb by purchasing a 1 gb kit which would be 512 x 2. That way you have a matching pair of RAM modules. As for a cpu upgrade you can go to the Asus website and see what cpu's are supported by your motherboard. Hope this helps & please remember to rate my answer. Thanks.
Jan 24, 2009 | ATI RADEON X1650 Graphic Card
Asrock P4i65G Motherboard Logo
241 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
