Question about Brother Sewing Machines
My brother sewing machine, My Star 15, is skipping stitches and tension is not very good.ANY SUGGESTIONS THANKS
  • Brother Master
  • 7,365 Answers
Check needle to see if it's damaged-roll on flat surface to see if it roll correctly
adjust top & bottom tension according to operation manual
Posted on Oct 01, 2010
Skipped stitches
Skipped stitches could result from several different origins. First, easiest, and least expensive thing, try a brand new needle. However, if it is failing to pick up the bobbin thread all together, then it is probably out of time (search for sewing machine timing or take it for service).
Here are other suggestions for intermittent skipping:
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Basic Maintenance Tension Skipped Stitches
http://www.sewingreviews.org/what-to-do-when-your-machine-starts-skipping-stitches
Jan 03, 2017 | Sewing Machines
Skipping stitches
Skipped stitches
1. A bent or dull needle
2. The wrong needle for your fabric
knit fabrics require a jersey or ballpoint tip. Most wovens do well with a universal tip, and specialty fibers, like leather or metallic, usually require specific needles.
3. Incorrect machine threading
4. Unbalanced needle thread tension
Start by making relatively small changes and run a test stitch to evaluate the impact. If you need to adjust the tension dial using woven cotton fabric with good quality all-purpose thread and a new needle
5.check the needle is inserted correctly. The needle needs to be pushed as far up the needle shaft as possible. It's easy to insert the needle half way, clamp it down and think it is inserted correctly.
the flat part of the needle should be positioned towards the back. If the needle is not inserted correctly, it will not be able to pull up the bobbin thread and will cause skipped stitches.
6. If the suggestions don't help then it is time for a tune-up.
May 17, 2016 | Singer Sewing Machines
Skipping stitches
Skipped stitches
Nov 19, 2013 | Singer 7256 Fashion Mate Sewing Machine
How can I tighten the bobbin tension?
try adjusting the top thread tension
here are some link for a manual
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125_EN_272.PDF
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125i_EN_1628.PDF
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Mar 01, 2013 | Brother LS-2125 Mechanical Sewing Machine
Brother XL3030 SEWING MACHINE ..STRAIGHT STITCH LOOKS GOOD ON TOP OF FABRIC, BUT BOTTOM STITCHES ARE SKIPPING AND LOOPS FORM IN PLACES..YOU CAN PULL THE THREAD RIGHT THROUGH AND UNRAVEL ALL STITCHING! I...
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 19, 2011 | Brother XL-3030 Electronic Sewing Machine
Sewing Machines Logo
489 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
