Automatic start windows installer "The path '1' cannot be found. Verify that you have access to this location and try again, or try to find the installation package 'ISUS.msi' in a folder from which you can intall the product Update Manager.
  • 88 Answers
SOURCE: it show windows name roxio
If you have the Roxio disk , insert the disk in the cd-dvd drive -point the browse location to the drive letter for your cd-dvd drive and click OK.....it should update the msi source packages and correct the issue. I assume this is requesting the original source packages and location. Possibly due to some corrupt or missing files. Will need more details on the message. If that does not work you may need to uninstall and re-install roxio. If it came pre-installed on your pc go to the manufacturer web site and update or download and install roxio from there. Hope this helps....
Posted on May 11, 2011
ginko
  • 19396 Answers
SOURCE: update manager on startup appears.
This seems to be result of an interrupted software setup. you should do system restore to s\a date before having the problem.
Posted on Mar 08, 2008
injkiran
  • 249 Answers
SOURCE: this usually happens when i try to install a file(usually .msi)
may be your not loading original one or reloading the same
Posted on Dec 14, 2009
hansola
  • 279 Answers
SOURCE: my computer says CD-ROM is not available Path '1'
Type DEVICE MANAGER in your windows search area
This will show all your computer's hardware and peripherals
Is your CD drive listed?
No-power or other problem
Yes-driver issue?
right click on the cd drive and select PROPERTIES
first tab GENERAL shows if device is working properly or not
click DRIVER tab and select UPDATE DRIVER
You may have to restart.
Please reply if this does not remedy your error.
And always specify what version windows you use.
Hope this helps.
Posted on Mar 15, 2010
  • 2340 Answers
SOURCE: We are continually getting an error message saying
If you are using "Vista or Win 7", right-click the "setup" installer and install as "Administrator".
Hope it helps.
Posted on Jul 26, 2010
I currently have an issue with scanning to my PC, on the printer detailed Below
I suspect half a file may be missing.
Try reinstalling the printer software.
Mar 06, 2017 | HEWLETT-PACKARD Photosmart C4485 , Copier...
The Windows Search service stopped working on my Win 7 machine. Said indexing was not turned on. I used event viewer and found the following error message: The Windows Search Service has failed to...
1) Insert your flash drive
2) From the Start Button, type "services.msc" in the "Search programs and files" box
If prompted for Admin Access, answer yes
3) Scroll down to the "Windows Search" service, select it, and click Stop.
4) From the Start Button, type "regedit"
5) Browse to [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Search]
6) Verify that the values DataDirectory and DefaultDataDirectory are set to %ProgramData%\Microsoft\Search\Data\
7) Remove the flash drive
8) Reboot (or restart the Windows Search service)
Jul 26, 2011 | Microsoft Computers & Internet
Citrix Access Essentials problem. Users can log into Web Interface but cannot launch programs. When I try to run the Quick Start the following error message appears: The licensing task counld not be...
Try one of these 2 things
1) Uninstall and reinstall Citrix licensing
2) Verify the path to the licensing server is correct (this is located in the licence console, if i remember correctly, the info is in the left hand pane at the bottom of console)
Oct 15, 2010 | Citrix Computers & Internet
It doesnt want to start it says what im describeing.
From http://support.microsoft.com/kb/194679:
Cause:
This behavior can occur if the Windows\System folder is missing or renamed, or if the PATH line in the Autoexec.bat file is missing or does not include the Windows\System folder.
To resolve this behavior, use the appropriate method:
Method 1 loadTOCNode(2, 'resolution');
  1. At the command prompt, type: dir vmm32.vxd /s If the Vmm32.vxd file is not found, you must install Windows 95 or Windows 98 again. If the Vmm32.vxd file is found, note the folder in which it is located, and then continue with step 2.
  2. At the command prompt, type the following commands, pressing ENTER after each command cd windows
    ren folder system
    where folder is the folder you noted in step 1.
  3. Restart your computer.
Method 2 loadTOCNode(2, 'resolution'); Using a text editor (such as Notepad), edit the Autoexec.bat file and add or modify the PATH line so that it includes the Windows\System folder. For example, add the following line to your Autoexec.bat file: path=c:\windows\system
Hope this helps,
-LL
Mar 16, 2010 | Toshiba Satellite 2060CDS Notebook
My computer says CD-ROM is not available Path '1' cannot be found verify you have access to this location and try again find instalationumms1 in folder and install
Yes-driver issue?
Hope this helps.
Mar 12, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
1304 error when trying to install microsoft office student 2007
To resolve this behavior, use the following methods.
Method
: Re-Register the Windows Installer
To re-register the Windows Installer, verify the location of the Msiexec.exe file on your hard disk and in the Windows Registry, and then re-register the Windows Installer. To do so:
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
Verify the location of the Msiexec.exe file on your hard disk. To do so:
Click Start, and then click Search.
Click All files and folders.
In the File name box, type msiexec.exe, and then click Search.
In the search results, make a note of the location of the Msiexec.exe file.
The location of the Msiexec.exe file should be similar to the following example, where Drive is the drive where Windows is installed, and %Windir% is the folder where Windows is installed:
Drive:\%Windir%\System32
An example of this is C:\Windows\System32.
Note In Microsoft Windows 98-based computers, the Msiexec.exe file is located in the Drive:\%Windir%\System folder.
On the File menu, click Close.
Verify the location of the Msiexec.exe file in the Windows Registry. To do so:
Click Start, and then click Run.
In the Open box, type regedit, and then click OK.
Locate, and then click the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\MSIServer
In the right pane, double-click ImagePath.
In the Edit String dialog box, make sure that the string in the Value data box contains the correct path of the Msiexec.exe file on your hard disk that you determined earlier in step 1.
For example, if the Msiexec.exe file is located in the Drive:\Windows\System32 folder on your hard disk, the correct path of the Msiexec.exe file in the Value data box is the following path, where Drive is the drive where Windows is installed:
Drive:\Windows\System32\Msiexec.exe /V
If the Value data box does not contain the correct path, make the appropriate changes to correct the path, and then click OK.
Quit Registry Editor.
Start your computer in safe mode, and then register the Msiexec.exe file. To do so:
Shut down, and then restart your computer.
Press F8 after you receive the following message:
Please select the operating system to start
On the Windows Advanced Option menu, use the arrow keys to select Safe Mode, and then press ENTER.
If you use a dual-boot or multiple-boot computer, select the appropriate operating system from the list that is displayed, and then press ENTER.
Log on to the computer.
In the Open box, type the following line, and then click OK:
msiexec /regserver
Shut down, and then restart your computer in standard mode.
If the issue persists and you still receive the error message that is described earlier in the "Symptoms" section, follow the steps in Method 2.
Method 2: Reinstall the Windows Installer
To reinstall the Windows Installer, rename the damaged Windows Installer files, and then reinstall the Windows Installer. To do so:
In the Open box, type cmd, and then click OK.
At the command prompt, type the following line, and then press ENTER, where Drive is the drive where Windows is installed and where %Windir% is the folder where Windows is installed:
attrib -r -s -h drive:\%Windir%\system32\dllcache
For example, type
attrib -r -s -h c:\windows\\system32\dllcache
At the command prompt, type exit, and then press ENTER.
Update the Windows Installer files on your hard disk to the latest version. __________________
Feb 22, 2010 | Microsoft Office Professional 2007 Full...
Everytime i right click on desktop like recycle can or anythingelse it brings up a windows installer screen .it says the feature you trying to use is on a network resourcethat is unavailable. under that it...
> I don't have anti-virus on PC, I never need one.
Yes, you do. Even a simple Google-search can expose your computer to a computer-virus, if you click one of the "hits".
Install the _free_ anti-virus software from Microsoft: http://www.microsoft.com/security_essentials
Also, use "Add/Remove Programs" to "uninstall" that 'RPS' software.
Nov 01, 2009 | Averatec 6200 Notebook
Connecting the printer to a bluetooth note book
Installing the Printer in Windows Vista Using Bluetooth
Step one: Install the software
Install the software so that the appropriate choices can be made during the installation to resolve the issue.
1. Insert the printer software CD in the CD-ROM drive of the computer. The software installation starts automatically.
Tips & Tricks: If the software installation does not start automatically, click the Start icon. In the Start Search text box located above the Start icon, type D:\setup.exe, where D is the letter of the CD-ROM drive, and then press Enter.
2. On the User Account Control window, click Continue.
3. Follow the instructions that display on the screen to install the software.
Tips & Tricks: If the User Account Control window displays during the installation, click Continue.
4. When prompted to choose the connection type, select directly to this computer using a USB cable and then click Next.
5. On the Connect Your Device Now window, select If you are unable to connect your device now, click this box and then click Next to finish installing the software. You can connect your device later.
6. Click Next.
7. Follow the instructions that display on the screen to complete the software installation.
Step two: Install the Bluetooth dongle
1. Insert a Bluetooth dongle in an available Universal Serial Bus (USB) port on the computer. Windows Vista automatically installs the driver for the dongle.
2. If the printer does not have built-in Bluetooth support, insert a second Bluetooth dongle in the Bluetooth dongle port of the printer after the drivers for the first dongle are installed. (If its an HP bt300 or bt450 then the drivers can be Downloaded for the same from hp.com similarly as we download the drivers for the printers)
Tips & Tricks: This step is not necessary for devices that have built-in Bluetooth support.
3. In the System Tray, right-click on the Bluetooth icon and then click Add a Bluetooth Device . The Add Bluetooth Device Wizard opens.
4. Select the My device is set up and ready to be found check box and then click Next .
5. Click the name of the printer.
Tips & Tricks: If the name of the printer is not displayed, verify that the printer is turned on and then click Search Again . After the name of the printer is not displayed, click the name of the printer and then click Next .
6. On the Do you need a passkey to your device? dialog box, select the appropriate check box and then click Next .
7. On the Completing the Add Bluetooth Device Wizard screen, click Finish .
8. On the Found New Hardware window, click Don’t show this message again for this device .
Tips & Tricks: Multiple Found New Hardware windows might display. Click Don’t show this message again for this device each time the window displays.
9. On the User Account Control window, click Continue.
10. Click Finish.
Step three: Update the printer drivers
1. Click the Start icon, right-click Computer, and then click Properties.
2. Click the Device Manager tab.
3. Click the + sign next to other devices to expand the list.
4. Under Other devices, right-click the name of the printer and then click Update Driver Software.
5. Click Browse my computer for driver software.
6. Click let me pick from the list of device drivers on my computer and then click next.
7. Under Common hardware types, click Printers and then click Next .
8. Under Manufacturer, click HP.
9. Under Printers, click the name of the printer and then click Next.
10. On the Update Driver Warning window, click Yes. Windows Vista installs the driver for the selected printer.
11. On the Windows has successfully updated your driver software window, click Close.
12. Verify that the drivers are installed correctly.
a. Click the Start icon.
b. Click Control Panel.
c. Under Hardware and Sound, click Printers.
d. Right-click the name of the printer.
e. Click Properties.
f. Click the General tab.
g. Click Print Test Page.
13. If the test page prints successfully, the printer is installed correctly.
Tips & Tricks: If the test page did not print, verify that the correct printer was selected .
Oct 06, 2008 | HP Photosmart C6180 All-In-One InkJet...
Fedora Add Software Error
Try using Yum instead of the graphical add/remove thing. If yum can't automatically find the repository then edit this location :
/etc/yum.repos.d/
the command line option to install is :
#yum install your_desired_package
Hope this will help
Sep 17, 2008 | fedora Linux Operating System
Computers & Internet Logo
672 people viewed this question
David Payne
David Payne
