Question about LG Washing Machines
My washing machine model no is WF-T8019QL. Inside drum hitting to the out side wall and making noise.
  • LG Master
  • 17,130 Answers
Possible failure of the Suspension of the drum mountings,
failure/fault of the motor drives, possible friction or fault in the drive to produce a centrifugal action thereby agitating the drum.
fault of the motor, belt , pulley.
Excess load of water, reduce water level to low and try.
Posted on Oct 01, 2010
Iv'e got a LG Top loader.WF-T755A. When it spins the drum shakes violently and move the washing machine around . It also makes a loud noise while doing it. What is wrong please?
The load is off balance. Instead of being evenly spread out along the drum, your laundry is bunched up on one side. Try smaller loads to allow the clothes to move more freely in the water.
Feb 11, 2017 | LG Washing Machines
My wash machine drum keep banging on side walls when spinning causing very loud noise and vibration
What kind of make and model washer do you have?
Your drum is off balance.
Is this happening with all loads or awkward heavy loads?
If the load is too big or heavy you have to stop the machine and adjust the load.
Can not give more info without knowing more.
Nov 25, 2015 | Washing Machines
Wf-t8019ql. I'm confused how to solve this problem d3 error
try unplugging this device for 30 seconds then plug it back in to see if its a security code if this does not help call your local lowes or professional repair shop about the code I am not familiar with the brand new digital washing and drying machines only the old timers with analog's merry christmas
Dec 26, 2014 | Washing Machines
Washer makes a buzzing noise when it tries to spin
Hello. Loud noises coming from a Washing Machines are most often caused by looseobjects inside the unit or by a broken dryer belt. The Washing Machines beltallows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually Washing Machines cracking and thensnapping. This will cause a loud noise within the unit. Repair and fix thedryer belt of a Washing Machines to get rid of loud noises. Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt 1 Stop the Washing Machines and look inside the dryer's drum for any looseobjects such as coins, pens or anything else that may have been in a pocket ofclothing. Remove the object and restart the dyer to determine if the noise hasstopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power tothe unit. 3 Remove the lint trap from the lint compartment on the top of the dryer. 4 Remove the screws that hold the top panel in place. Pull the panel off toaccess the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check theWashing Machines belt. A belt that is worn, cracked, split or broken will causeloud noises. 6 Slide the old belt off of the drum and pull it out to remove it. Take noteon how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines andslip the new belt over the drum. Locate the position of the old belt and slipthe new belt following the old belt's position ensuring the grooved side of thebelt faces down. Push the idler pulley towards the motor to allow you to slipand loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drumcounterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use . Thanks.
Sep 13, 2011 | GE Energy Star WCVH6260F Front Load Washer
Hot point WF451 Issue. I want change the door rubber between the door and drum. How do I do this? Also the machine is making a noise on fast spin as if there is something in the drum catching. I have...
Hi for changing the door seal check out the video section on www.selfix-uk.co.uk there are a few videos on the wf including bearing change which also covers the door seal as well. As far as the noise in your machine it could be almost any thing...if it's a scrapping noise it may be a bra wire caught between the drum and container, if its a tapping noise it may just be loose wires hitting on the cabinet or you may have a coin between the drum and container if it's a loud rattle, you could also have something in the pump housing...it's hard to diagnose noises without actually hearing them sorry
Jan 23, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Mashine make noise and vibrating a lot
Hi, your washing machine makes noises because all the clothes and other materials are not balanced evenly--one side is heavier than the other--causing the drum to hit the sides of the washer wall.
Sep 29, 2010 | Ariston Technologies Ariston AWD12 Front...
LG Washing Machine front loading, Model Fuzzy Logic 8.5KG,
If it has a belt remove this then turn drum by hand to see if noise is still present if it is then sounds like some thing caught in between drun inner and outer you may need engineer....Pull plug out 1st...
Mar 22, 2010 | Washing Machines
Noise from drum
This is difficult to work out as there are so many different symptoms. Here are my thoughts -
Dust from carbon rushes is black. Grey dust usually comes from a loose concrete weight. Loose tub weights are rare on this model but they cause a loud knocking noise which is often worse when the washing machine is revving up to spin and dying down from a spin (suspension problems are also often worse at this safe too). It's not normally a metallic sound though.
If the noise is coming from the motor banging against the sides of the machine then it will make the machine move when it happens. The whole machine may jump or move to one side. The motor often thumps the side of the washing machine on Hotpoint washers where the motor is fitted at the top of the tub and over to the right hand side. This is a daft place to fit a motor and only .I think they've eventually stopped now though.
It is normal to be able to push the drum to the side so that the motor hits the casing. If the suspension has gone, the tub should be twisted and leaning to one side more than the other or it just could be very loose. It's difficult to check suspension if you don't know how it should feel.
If the noise is coming from the inner drum hitting the heating element or throwing an object like a £1 coin (trapped between the inner drum and the outer tub) around, then the washing machine will be stable but the noise would still be a horrible metallic knocking. This is one cause I suspect.
Thank you for contacting Fixya.com
Aug 30, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
Loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
Apr 26, 2009 | Washing Machines
Washing Machines Logo
291 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
