"Windows is recovered from an unexpected shutdown "I am getting this window again and again.I have formatted my pc ,i have also reset the RAM and have changed RAM to its second slot but still i am having the same problem.Please help I am having a MSI motherboard .Model of my motherboard is MS-7507(v1.X)Mainboard
  • 27,725 Answers
Fist clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
then test your power supply unit PSU
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive one bad lead will cause a computer to shut down
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
then click start?run type?cmd then type?chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
you have to keep?a computer very clean & free of dust ?and? give it regular?maintanance
?hope this helps
Posted on Oct 01, 2010
  • yanish_3008 May 12, 2011
    i dont think thats gonna hellp..am having the same prob..checked all connections and cleaned up the case...still no change..in fact windows doenot boot giving a blue screen or just shutting down by itself..
  • Brian Sullivan
    Brian Sullivan May 12, 2011
    First replace the leads from your motherboard to hard drive
    the leads from your “((motherboard to your hard drive))” make sure they have a secure connection and are not faulty or just replace them they could be faulty
    make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
    another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system imformation all of your computers imformation will be there try uninstalling a few unnecessary programs then download a registry cleanerhttp://download.cnet.com/ccleaner/
    hope this helps
Recover lost windows hard drive data
Stellar Phoenix Windows Data Recovery recover deleted data from the Windows Recycle Bin, restore lost data, even if the partition is formatted or deleted, restore data from a corrupted hard drive, virus infection, unexpected system shutdown or software failure. It supports IDE, SATA, SCSI, USB hard disk, memory card, USB flash drive, CD/DVD, Blue-Ray Disk and iPod.
Jul 04, 2013 | Computers & Internet
How to fix unexpected shutdown due to Blue screen problem of Pavilion HDX9494NR
See if the Check disk utility will solve your problem. To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Mar 31, 2012 | HP Pavilion HDX9494NR Notebook PC
Windows has recovered from an unexpected shoutdown
That is a common message that most of us see at one time or another, the cause could be a bad download, device driver issue, or a glitch in windows, or windows did not shutdown properly.
Mar 21, 2012 | ASUS Computers & Internet
Windows has recoverd from an unexpected shutdown
This can be caused by an improper shutdown, a download, or just a glitch in the windows operational system, In most cases it recovers without a hitch.
Jul 02, 2011 | Microsoft Computers & Internet
"Windows is recovered from an unexpected shutdown "I am getting this window again and again.I have formatted my pc ,i have also reset the RAM and have changed RAM to its second slot but still i am having...
I have no idea what the Manufacturer/Model of your system is. Please inform me of as many details reguarding your system that you can, so I can properly address your issue. ok?
Oct 01, 2010 | Computers & Internet
Voster a860 unexpected shutdown problem
Did you tryed to remove RAM-MEMORY?If not so do it..
Or see if power suply stops working
Jan 07, 2010 | Dell Vostro A860 Notebook
Computer has lots of unexpected shutdowns.
it might be caused by virus, windows gone corrupt, needs new installtion with an updated virus cleaner.
Sep 26, 2009 | Microsoft Windows XP Professional for PC
Windows has recovered from an unexpected shutdown (Blue Screen)
When exactly do you get the error, I'm assuming you get this once Windows starts? These errors are most often caused by buggy or corrupt drivers. One that comes to mind is Norton. Does this unit go into Safe mode? If it does I would then go into msconfig. On the general screen there is a diagnostic startup. This loads only Windows most basic drivers and nothing else. If the machine works now then the BSOD is from a driver. If it doesn't boot then the first thing I would change are the memory sticks.
Mar 25, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
