Question about GE Profile 22.2 Cu. Ft. Bottom-Mount Refrigerator - Stainless-Steel
Both Refrigerator and Freezer take many hours to reach their set temperatures. The Freezer almost never quite reaches the set temperature. I have cleaned around all door seals. Problem persists.
  • GE Master
  • 1,711 Answers
Posted on Oct 01, 2010
Whirlpool S20b American style f/f. The fridge is very cold and some foods are freezing.
Suggest lowering the refrigerator set point to a lower number such as 3. There is usually an indication of normal setting on the adjustments. Wait 24 hours and check the refrigerator compartment again. Use a thermometer to record the temperatures. The meat compartment will be normal just below freezing. If no success then read the following.
One reason that this occurs is that the unit is working near continuously to reach the freezer temperature. Another words the unit is not capable or cooling the freezer to the prescribed temperature. The result is the excess cooling eventually reaches the refrigerator section causing the refrigerator to freeze. The unit will if this is the case run nearly continuously. This situation is counter intuitive. Freezer not reaching set point, excessive cooling over cools refrigerator therefore refrigerator freezes.
The cause is either the freezer door/seal is not closing or sealing the freezer compartment or the compressor or defrost cycle is not functioning properly.
Check the freezer door seal using a strip of paper. Check to see if air is flowing from the vents in the freezer. Using a thermometer check the temperature of the freezer. Listen for and record if the compressor is running or not.
The normal freezer temperature is around '0' Fahrenheit. If no or little air is flowing from freezer air vents look for ice on the back wall. If ice is present it is likely the auto defrost cycle is not working. Attempt to defrost by hand which requires several hours with everything removed.
Check that lint and dust has not blocked the coils under the unit and that the lower fan is running. Usually warm air exits from the machine grill in the front. Remove the grill and check for air flow and debris buildup. Vacuum if necessary.
And unfortunately if the compressor runs continuously and no air blockage underneath would indicate that the cooling capacity is reduced requiring a major service or replacement.
Hope this helps?
Oct 17, 2016 | Whirlpool Refrigerators
We had a new Samsung RS267TDWP side-by-side frig delivered earlier today. The refrigerator side is cooling off nicely, the freezer side is not. Should we expect the freezer sideto begin cooling when the...
It takes approx. 24 hours for a freezer to reach optimal temperature and to stabilize, only because in a 24 hour period the machine will shut off about three times for it's defrost cycle, but like you listed, freezing temperature will be reached in about 6 hours.
Aug 29, 2012 | Refrigerators
How long for a 20 cf freezer to get to appropiate temperature?
As in most refrigerator and freezer units, the manufacturer and technical guides will state up to 24-48 hours to reach appropriate temperature. It also depends on the room temperature and humidity around the unit.
Jul 31, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Refrigerator need to be program after installing CNTRL =ELEC P/N WPL w10310240 model # G15FSAXVYOO S/N KW4406211 I' am losing everything in my (FRIDGE) did'nt find anything with part relative...
The temperatures are set when it leaves the factory (0 Deg F Freezer & 38 Deg F Fridge) and it should be left for 24 hours after installation before putting any food inside to allow it reach these temperatures.
Once the unit has been connected for 24 hours then the temperature can be changed by 1 Deg at a time but should be left again for 24 hours between each change to allow the temperature to stabilize.
The only thing I can sugest you try if you've already got food n it is to activate the Fast Cool which will run for 2 Hours.
Jul 08, 2011 | Whirlpool ED2FHSS Side by Side...
Freezer is freezing about 25 degree,but the ref. will not get below 40 degree.
It's quite normal if freezing is not reach on 40 degree, it's already high temperature. Remember the lower the temperature setting the higher the freezing of refrigerator, the higher the setting the lesser the freezing.
It's simple as that friend. Good luck!
Jun 12, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
How to set a temperture
By keep your refrigerator or freezer too cold, it unnecessarily wastes electricity. The recommended temperature is 37 to 40 degrees for the fresh food compartment of the refrigerator. The recommended temperature for the freezer compartment is 5 degrees. If you have a separate freezer for long-term food storage, it should kept at 0 to -5 degrees.
The following steps below is how to set the temperature of your refrigerator.
The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food.
Step 2
Place your magnetic thermometer in the refrigerator.
Step 3
Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
Step 4
After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
Step 5
Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Hope this helpout and take care.
Aug 12, 2010 | Refrigerators
I need to learn how to control the tempature setting
The temperature controls are located at the top front of the refrigerator or freezer compartments.
The recommended setting should be correct for normal household refrigerator use. The controls are correctly set when milk or juice is as cold as you like and when ice cream is firm.
Wait 24 hours for your refrigerator to completely cool before adding food. If you add food before the refrigerator has completely cooled, your food may spoil.
NOTE: Adjusting the refrigerator and freezer temperature controls to a colder-than-recommended setting will not cool the compartments any faster.
If the temperature is too warm or too cold in the refrigerator or freezer, first check the air vents to be sure they are not blocked before adjusting the controls.
To turn Off/On:
Style 1 Press the freezer down arrow touch pad until a dash (-) appears in both the refrigerator and freezer displays. Neither compartment will cool.
Style 2 Turn the freezer control to the word Off. Neither compartment will cool when the freezer is set to Off.
Energy Saver option (on some models)
The Energy Saver option turns off the heater which helps to reduce moisture on the door hinge seal. The refrigerator uses more energy when Energy Saver is off.
Press the control to On to save energy when the environment is less humid.
Press the control to Off when the environment is warm and more humid, or if you notice moisture on the door hinge seal.
Adjusting controls
If you need to adjust the temperature in either the refrigerator or freezer compartment.
NOTES:
For Style 1 control, press the up and down arrow touch pads; for Style 2 controls, turn the dial to adjust the temperature.
Except when starting the refrigerator, do not adjust either control more than one setting at a time.
Wait 24 hours between adjustments for the temperature to stabilize.
Hope this guideline will helpout.....
Aug 10, 2010 | Traulsen Reach in Freezer - G22010
Refrigerator stoped working freezer still works
the refrigerator have reached the set temperature? then is ok. it is posible to stop the freezer when that reach the set teperature and the refrigerator work. give more detail if you want get help from sombody.
Feb 21, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Atlas frost refrigerator
Push in the red "Defrost Button" located in the center of the temperature control dial. Defrost cycle will start immediately. NOTE: Turning the temperature control dial to the OFF position is not required. Defrosting usually takes a few hours. When defrosting is complete, the red "Defrost Button" will release automatically. Then the refrigerator will resume normal operation while moving towards the set temperature. NOTE: After defrosting, allow a few hours to reach the set temperature before making any further adjustments.
Dec 30, 2007 | Atlas Refrigerators
GE Profile 22.2 Cu. Ft. Bottom-Mount Refrigerator - Stainless-Steel Logo
151 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
