Question about Fuji Ea203b 150a Circuit Breaker
We are using EA 203 B BB-3 GEC 200 AMP BREAKER WOULD YOU PL TELL ME WHICH ONE IS COMPATABLE
Keeps tripping circuit breaker
There must be a fairly major issue with your microwave to trip a 20 amp breaker. I would recommend taking it to your local repair shop or replacing it.
Mar 19, 2014 | Oster OGB81101 1.1-Cubic Foot Microwave...
I recently had new service installed. 200 amp load center at the top of my stairs, and a QOM2E2200NRB 200 amp enclosed breaker next to the meter socket. Idiot electrician bonded the neutral in the load...
Problem is not clear.
You have 200 Amp cut off by meter, with 3 wires from meter box:
2 Hot wires and a ground.
http://waterheatertimer.org/See-inside-main-breaker-box.html
You have 200 amp service panel.
Does the ground wire enter service panel from cut off box?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 24, 2013 | Electrical Supplies
Crouse - Hines Murry Style MP or MD 200 Amp Main Breaker Difficult to Reset
A 200 amp circuit breaker has a large spring to assist in rapid opening and closing a load of this size to minimize damaging arcing every time is it operated under electrical load
The larger the circuit breaker is and the more poles (1, 2 or 3) that are being opened / closed; the more force it will require to operate - both by hand or when tripping. Compare the tension or force you need to apply to a similar sized circuit breaker at Home Depot, etc.
The troubling issue about this for me is the fact that the 200 amp service disconnect / main is tripping. This is an indication of an overloaded panel / circuit. I usually see individual circuits that trip in a panel - but often find the that main breaker has only 20% - 60% of its rating on it at any given time. If you're tripping a 200 amp service disconnect / main breaker repeatedly - something has got to give - and eventually the circuit breaker will fail. That may be where you are now with this breaker. You may be in need of a service upgrade (if it is the service disconnect) as clearly, you have out grown the 200 amp size one you currently have or need add a new sub-panel to ease the load that this 200 amp main is trying to supply now.
Either way, you should call a reputable electrical contractor to have your service / sub-panel evaluated very soon. Good luck!
Feb 21, 2013 | Bryant /murray Bj2200 Main Circuit Breaker...
I have a new furnace and the breaker keeps tripping (20/30). It is a bryant westinghouse box. I think 200 amphes
1) You got a FIRE truck coming.
2) Wire is too small.
Problem is NOT circuit breaker.
3) Both 240Volt appliances on same breaker is a hazard, especially if space available in 200 amp service panel for more breakers.
4) Usually each 240V appliance has separate breaker.
5) Circuit breaker trips because of High heat on the wire.
If wire gets hot, it will start a fire inside the wall.
Electric code requires wire-size match breaker-size.
6) If you put larger amp breaker on same wire that is getting hot, then wire will get hotter.
Result: FIRE truck middle of night with folks jumping out window in glass-cut bare run across yard.
7) Each appliance has volts and watt rating on label.
EVERY appliance has label.
8) For example stove might be rated 8000 watts and 240Volt.
8000 watts divided by 240 volts = 33.3 amps
Stove would require 40 amp breaker and 8 gauge wire.
9) How to figure it out:
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-install-a-subpanel.html
10) Do same calculation for new furnace.
12000 watt furnace divided by 240 volts = 50 amps.
Use 60 amp breaker and 6 gauge wire.
11) Summary: fixya wants you to be safe, and buy stuff showing in the ads.
Use a bigger breaker ONLY when bigger wire is also installed.
Call furnace installer, the installer should know to check safe wiring before installing.
Nov 04, 2012 | Bryant Westinghouse Bqc Quad Circuit...
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
70 amp stabloc panel, using 8/3 to panel from 40 amp main breaker at 200 amp panel. white wire to white, black to black? red wire to ? thanks
Depending on what type of wire you have, 8/3 is not large enough for a 70A breaker. Is this a 240V circuit? or 120V If you are using 8/3 is it 8/3 WG that is 3 insulated conductors (red,black,white) along with bare ground? If so then you'd use the black and red for the two "hot" conductors, and the white for the "neutral" conductor. If it is just two insulated conductors, with ground (white, black and ground) then yes black to breaker and white to neutral bar. The amperage rating will vary on the wire depending on wire type. For example 8/3 is in NM? usually that rating will not be enough for 70A. In fact even #6 copper conductors in conduit is not quite large enough for 70A.
Nov 23, 2010 | Federal Industries Circuit Breaker -...
15A breaker tripping; Is this the right size breaker for the unit?
The breaker is sized according to the size of the wire used in the circuit. The breakers task is to protect the wire from an over current.
The allowed sizes are
#14 wire .... 15 amp breaker
#12 wire ..... 20 amp breaker
#10 wire .. 30 amp breaker
To check if the oven and circuit are compatable .. run an extension for the oven to an outlet outside the kitchen and see if it holds.
Please Vote !!
Mar 08, 2010 | Hotpoint RVM1435 Microwave Oven
Lremote control codes (a/v reciever)
Howdy,
1. Move slide switch at top of Reomote to A/V
2. Press& hold POWER BUTTON on REMOTE
3. Enter CODE #, & then release Power Button
4. Point remote at A/V & press power button; If works, remote is programed, if not try again
Here are the code numbers ( page 74 of owners manual.
Mitsubishi . .. .. .. . 010, 011, 012, 013, 014,015
Admiral . .. .. .. .. . 220
Aiwa. .. .. .. .. .. . 225, 226
Denon . .. .. .. .. . 234, 235, 236
Fisher . .. .. .. .. . 204
Gerrard. .. .. .. .. . 213
Harman Kardon . .. . 215
Jensen . .. .. .. .. . 223
JVC . .. .. .. .. .. . 232, 233
Kenwood . .. .. .. . 200, 208
Magnavox . .. .. .. . 227, 228
Marantz . .. .. .. . 224
Mclintosh . .. .. .. . 216
Nakamichi . .. .. .. . 206, 217
Onkyo . .. .. .. .. . 209, 214, 240
Optimus . .. .. .. . 203, 227, 231, 230
Panasonic . .. .. .. . 219, 218, 221
Philips . .. .. .. .. . 223
Pioneer . .. .. .. .. . 205, 207
Quasar . .. .. .. .. . 219, 218, 221
RCA. .. .. .. .. .. . 203, 205, 227, 231,230
Sansui . .. .. .. .. . 203, 211, 239
Sharp . .. .. .. .. . 234, 237
Sony . .. .. .. .. . 222
Sound-sigh . .. .. . 238
TEAC . .. .. .. .. . 212, 213, 210, 211
Technics . .. .. .. . 221, 218, 219
Victor . .. .. .. .. . 232, 233
Yamaha. .. .. .. .. . 201, 202
Thanks for using FIXYA, BIG IRISH.
Jan 04, 2010 | Mitsubishi WS-55909 55" Rear Projection...
Fuji Ea203b 150a Circuit Breaker Logo
200 people viewed this question
Top Fuji Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Fuji Electrical Supply Expert? Answer questions, earn points and help others
