Question about Canon PIXMA iP1600 Printer
Paper not spooling
i have been using the same paper in my printer for some time now however the printer is no longer spooling the paper into my printer. it wrinkles the paper but does not pull it in
can you help
thanks
    Master:
  • 638 Answers
There is a mis-alignment in the paper feeder, get it realigned by the technician, or just service ur printer.nothing to worry.
Posted on Jun 04, 2008
Clear paper jam pcr t2000
It\'s very unusual for the paper to jam as this machine uses a clam shell type of printer. Just raise the printer arm and remove the paper roll. Clear any paper from the print head and roller etc. Tear any wrinkled paper from the roll and then refit the roll with the shiny side of the paper towards you. Lay the paper in the printer and close the printer arm down onto the paper. If you are setting the journal side, wind some paper onto the takeup spool after it exits the printer and sit the spool into place.
If anyone needs a Casio PCR-T2000 manual, one of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T2000_users_and_programming_manual.html
Jul 08, 2014 | Casio Parts Cash Register PC Desktop
Canon IR C2880i wrinkling paper
The printer gears with pull and move paper forward are not working properly.The gears are worn out or either dried out.See if minor gear oiling is helping.
Apr 19, 2013 | Office Equipment & Supplies
Document feed takes more than one page at a time
please follow these steps to solve your problem:
1.Fan the papers before loading them in printer tray.
2. Dont use papers that has lot of wrinkles
3. Dont insert your papers too long into your printer. Just load them with optimal distance.
4. After the papers were loaded, adjust the paper hold knob present on either side of the paper such that it holds the paper firmly on both sides.
Now your printer will take one paper at a time for printing.
I hope this is helpful to you. Please provide your rating and comments for the solution provided.
thanks
Mar 08, 2010 | Office Equipment & Supplies
My printer wrinkled the paper when it is out
Try using fresh paper from a new ****. If still wrinkles might be an issue with your fuser. The fuser is the part that heats the toner onto the paper and if the paper contains too much moisture content (from improper storage methods), this can cause wrinkling effect as well.
Try printing with different types of paper and from manual tray to isolate problem. If it occurs all the time, most likely bad paper or bad fuser.
Jan 16, 2010 | HP LaserJet 4200 Printer
After paper jamming in printer paper now wrinkles
there still may be a piece stuck somewhere in the unit. Remove printer cover and check inside to see if there is anything at all still in there
Jul 29, 2009 | HP Officejet 5610 All-In-One InkJet...
Z4MPlus Ribbon wrinkles causing lines diagonally across label.
Could be down to tension on the ribbon roller/spool. Check to see if you have pulled out the end part of the spool (black bit) that should ensure there is back tension on the ribbon.
Mar 27, 2009 | Zebra Z4M Printer
Left corner of paper wrinkles when printing
I know several reasons, and they are all related to an obstruction of some sort..whether it be a small piece of paper along the paper path, to something slightly bent, or broken...impossible to say for sure
Feb 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
CLJ8550n poor print quality and wrinkled paper
this is usually not caused by the paper tray. this problem is usually caused by the fuser assembly. check your paper path. dead cycle the printer, shut the printer down before the paper enters the fusing area, check for wrinkles. remove all paper, print again, check the output, wrinkles, replace the fuser.
Feb 03, 2009 | HP Color LaserJet 8550n Printer
Paper jamed or wrinkled
Dear
this is the problem of hot roller replace it paper jam problem will be resolved.
Nov 25, 2008 | Samsung ML2251N Laser Printer
Canon PIXMA iP1600 Printer Logo
57 people viewed this question
old marine
old marine
