Question about KitchenAid K45SS Classic Stand Mixer
Will not run - KitchenAid K45SS Classic Stand Mixer
  • KitchenAid Master
  • 17,130 Answers
Will need to check if the motor is working the power to the switch and then to the motor.
Look for a reset switch on the underside which could have reset, this can happen if there is an overload on the mixer.
If the motor is not working check if the brushes are contacting, if not clean and set.
Posted on Oct 01, 2010
STAND MIXER SPINS FOR A SECOND OR SO THEN STOPS
can you clarify a little more, it is either a gear problem or an electric problem, are there any other symptoms? Like sound noises, grinding fast speed when it does run for those few seconds or really slow. if it is running fine while it does run then it is more likely a speed plat or phase control board. please let us know
Sep 13, 2012 | Food Mixers
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
Runs wide open then quits
Looking at the parts list:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208204551.pdf
find item 9. It is a hall effect sensor which measures the speed of the motor and feeds back that info to the controller - if it is open or shorted the motor will not be controlled and will either not run at all or run wide open.
Mar 24, 2010 | KitchenAid KV25G0X Stand Mixer
Mixer quit, was running fine,
probably worn out carbon brush or a break in the wire near the plug
Feb 20, 2010 | KitchenAid Food Mixers
Sometimes mixer runs when turned on, sometimes not
Sound electrical to me.... what kind of mixer ?
May 27, 2008 | Food Mixers
Motor replacement for A200
If the motor runs and when under a load the planetary stops its not the motor.You either have a sheared key or broken gear in the transmission.
Mar 22, 2008 | Hobart A200 Stand Mixer
Motor runs only at slow speed, higher speed buttons still run at slow
The company handles these as Blendtec now. The web site is at http://www.blendtec.com/default.aspx Maybe this will help:
Customer service and sales are available from 8:00 am to 5:30 pm (MST) M-F.
Phone
Toll Free: 800-253-6383
Local: 801-222-0888
Fax: 801-805-8585
Jan 10, 2007 | K-Tec Kitchenetics K2 Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
203 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
