Question about Uniden Cordless Phone
Uniden cordless dct646-4 phone
You can call out on any phone in the house but any incoming calls do not ring the phone,i hooked a regular land line phone and the incoming calls ring the traditional phone but not he cordless ones, what do you think lighting strike maybe? mark
  • 1 more comment
  • db59 May 28, 2008
    ring volume is up settings look ok
  • db59 May 28, 2008
    none of my uniden cordlessphones will ring wnen some one calls volume is turned up
  • Anonymous Mar 25, 2014
    Phone is not receiving calls, I can make calls but not nobody can call me
  • 298 Answers
You can try this.
press the up or down volume key while on standby mode and select off, low and high.
Posted on May 28, 2008
    Genius:
  • 2,035 Answers
Try to set it factory mode and use if this fails then the ringer speaker is defective ,if its within warranty get it replaced or get it serviced it will fix the issue .
or use this link to download the owner's manual.
http://www.uniden.com/search/searchresults.cfm?searchstuff=dct646&image2.x=10&image2.y=12
good luck............
  • 3,037 Answers
Try removing the battery for a few minutes to reset the phones, also unplug the base, let me know if this works or not and I would be glad to give you other suggestions
  • Uniden Master
  • 13,433 Answers
Check the ring volume and settings? There not much else I can think of.
Phone rings once, but then stops ringing and I can't answer the call
If you have a landline, most likely you have a short in it. Not enough to kill line, but, when the 90 volts a.c. comes in to ring it jumps short. The short answers the phone.. It doesn't stop out going but can cause static. Check the line at the box outside. if bad there call your phone company, if good there, trouble is in house
Oct 03, 2017 | Uniden DECT 6.0 Cordless Telephone...
I have a Uniden cordless unit hooked in 4 lines. Incoming calls ring briefly for about 1 second and go out! You can talk if you pick up but not sure why no normal rings. There is no problem calling out....
When someone calls you and your phone behaves this way, does the caller get disconnected? The phone may be causing this, but it may also be due to trouble in the telephone line itself. The trouble is caused by defective wiring, a partial short circuit. When you pick up your phone to call out, the voltage on the phone line is low and it works normally. When you get an incoming call, a high voltage is sent to ring the phone. Because of the partial short, the phone company's equipment thinks you've answered the call as soon as the ringing starts. But you haven't picked up the phone, so the phone company's equipment thinks you've hung up and disconnects the call. The result is that short burst of ringing.
Disconnect the cordless phone base unit from the line and try another phone. If you still have the trouble this confirms the line is at fault. You'll need to contact your phone service provider for service. If it's in the outside wiring, they're responsible for repair. If the problem is in your home wiring, you may need to pay them unless you have a wiring maintenance plan.
If the problem goes away when the cordless base is disconnected, then it's time for a new phone.
Jul 16, 2011 | Uniden Cordless Phone
Phone is not ringing
Unplug your Uniden Cordless Phone and plug in a regular un-powered phone. If it rings your cordless base station is bad and you will need a new one if it does not ring then there is a problem on your phone line and you need to contact your phone company. Note, the phone company will charge you for repairs inside your house.
Apr 11, 2011 | Uniden Cordless Phone
I connected an elite 9035 to charge the handsets but also connect the phone line at the same time which i later realized was not as the instruction manual recommended. i am not able to make (no dialing...
Unplug your Phone and plug in a regular un-powered phone. If it rings your cordless base station is bad and you will need a new one if it does not ring then there is a problem on your phone line and you need to contact your phone company. Note, the phone company will charge you for repairs inside your house.
Sep 15, 2010 | Uniden Cordless Phone
Buzzing on the phone line with incoming calls on a uniden CORDLESS phone - Model # XC310
Sep 03, 2010 | Uniden Cordless Phone
Our incoming calls are not ringing?
wen i receive incoming calls there is no ring or message alert
Dec 10, 2009 | Uniden Cordless Phone
Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Apr 29, 2009 | Uniden DECT 6.0 Cordless Telephone...
Uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Jan 20, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
203 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
