Question about JVC DR-MV1SU DVD Recorder/VCR
DVD ERROR Disks tried in recorder==Sony 120 Min,4.7GB/Go=1x-16x DVD+R Sony 80 Min=700MB==1X-48X===CD-R I get a DISK ERROR---on the above. Why ? Thank You.
  • 1 more comment
  • Al 124 May 26, 2008
    Thank you BobbyR1234===No code==only Disk Error.
    Al 124
  • sarita1004 Apr 14, 2009
    I am trying to dub VHS to DVD on a JVS recorder. I had no problems in the past using DVD-R blank dvds however I recently purchased DVD+R without thinking and I keep getting the message "Disc Error" when I attempt to do anything. This happened with multiple discs and on 2 different VHS-DVD decks. Is there a setting I can adjust so that it will dub onto a DVD+R?
  •  Bobby
    Bobby May 11, 2010
    Does the disk error give a number or some form of code?
  • 173 Answers
Does the dvd player do this with all your disks or just one in specific? Check the disks for scratches, you can clean them by taking a small amount of regular disk soap on your finger and add just a bit of water> run your finger over the disk until it is nice and soapy and then rinse the disk off really well>dry with a soft, non abrasive cloth and try to put the disk back in or you can go and buy a disk cleaner at walmart. If this does not work you will need to clean your optical lens inside your dvd player. To do this you take the screws out of the outer covering and lift it off> make sure you unplug the dvd player> open the dvd tray either manually or pushing the eject button before unplugging>look inside the inner casing and you will see a small lens looking device in the center (this is the optical reader lens)>take a cu tip and put a small amount of alcohol on it and gently wipe off the lens in a circular fashion>repeat this process until the cu tip comes out clean and there is no dirt on it>wait 3-4 minutes to let the alcohol evaporate before plugging back in and secure the outer cover back on and plug the dvd back in and see it that helped. If this does not, get back to me as we can explore further options.
Posted on May 26, 2008
Why is there an error message: Space Not Enough when trying to copy DVD?
There is some space reserved for dvd information, error information etc. So solution is make the file archive by right click on file ->proprties-> click archive. After that use winrar and compress.
Aug 22, 2013 | EZ Dupe Computers & Internet
MY PC has sony DVD-ROM DDU1615 that I can't record my videos onto a dvd
you cant burn a disk with a dvd rom
you will need both a dvd rw unit and a dvd rw disk to burn any video to a disk if you have both of these the burning program might not support video burning or you might not have selected the right option there are lots of free burning software programs that can burn videos to a disk you might have to burn it as an ISO image
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
hope this helps
Jul 21, 2011 | Sony DDU-1615 / 16x DVD-ROM / 48x CD-ROM /...
Burner not recognising blank dvd-r disks error reports disk not compatible or unreadable ? Kodak DVD-R 16X 4.7GB 120 mins
Check the manufacturer's web-site:
for the latest 'firmware" (software that runs inside the DVD-burner) for the DVD-burner. The newest firmware should recognize more & newer media.
Jun 24, 2010 | Dell (M6790) DVD RW Burner
I have a LG GE20 DVD Rewriter Is a DVD+RW disc a format that is editable and suitable for this unit?
The LG G20 DVD Rewriter is an advanced external burner that supports 'editable' Rewritable DVD+RW disk.
As a generic comment, not all writable/rewritable media are made equal and problem with branded & unbranded disks are not uncommon, so stick to brands that work for you for your specific unit!
The following is the advertised support for your unit, hope it helps:
Reading Rate DVD-R/-RW/-ROM 16x/13x/16x/16xSL/12xDL max. DVD-RAM 2x, 3x-5x, 6x-12x DVD-Video (CSS) 4,8x max. (Single/Dual Layer) DVD+R/+RW 16x/13x max./ 12xDL max. CD-R/RW/ROM 48x/40x/48x max. CD-DA (DAE) 40x max. Burning Speed DVD-R 2x, 4x CLV, 8xZCLV, 16x PCAV, 20X CAV DVD-RW 1x, 2x, 4x, 6x CLV DVD-RAM 2x, 3x ZCLV, 3x - 5x PCAV, 12x PCAV DVD+R 2.4x, 4x, 8x, 12x, 16x PCAV, 20X CAV DVD+R Double Layer 2.4x, 4x, 10x, 12x ZCLV DVD-R Dual Layer 2x, 4x, 6x CLV, 10x, 12x ZCLV DVD+RW 2.4x, 4x, 6x, 8x ZCLV CD-R 4x, 8x CLV, 16x, 24x, 32x, 40x, 48x ZCLV CD-RW 4x, 8x, 10x CLV, 16x CLV, 24x, 32x ZCLV
Dec 28, 2009 | Computers & Internet
Errors burning to 1x to 16x DVD-R
I have had much luck recording on off brand 16X discs as follows:
1) Record a "dummy" program on the hard drive, need only about 15 or 20 seconds.
2) Put a blank disk in drive, and COPY that dummy program to disk. Do not finalize.
3) After a minute or so, window will come up and say "Cannot
complete copy."
4) Now while above window on screen, click HOME MENU, COPY, New program list, Select your movie/program to copy, go ahead and finalize, and START.
5) Think you'll find this is successful, however there might be some brands of blank disks that won't work.
6)Let me know if it works for ya. JGIDUSKO@CFL.RR.COM
Jul 04, 2008 | Pioneer DVR533HS DVD Recorder with 80GB...
Dvd do not record
The unit is saying that its an "Un-format disc" problem. Is this the only error code you are getting? Also, what types of DVDs are being used? As in, DVD-R DVD-RW DVD+R DVD-RW and what speeds? 1x 2x 4x 8x 16x?
Apr 04, 2008 | Emerson EWR20V4 DVD Recorder/VCR
DVD Recording
One of the above posts also states that this recorder will not record at above 8x speeds -- sigh. i, too, have like a stack of 100 16x DVDs. Not good, but at today's prices we just gotta go out and see if we can find the slower one.
Have a great day! :)
Nov 20, 2007 | Sony RDR-VX500 DVD Recorder/VCR
Play Back
Some DVD players can't read -R & -RW disks. When you finalize make sure it is in Video mode not VR mode so the recorded disk will be able to work in most other DVD players. Also some DVD players only read recorded disks rated up to 1x, 4x, 8x, 16x, or a combination of these speeds.
Nov 13, 2007 | Emerson EWR10D4 DVD Recorder
Emmerson DVD/VCR EWR20V5
if yoy dont hav firm ware up date you cant fix the machine. the machine if working will on work on 4x. like i said if the machine is not working you maybe able to fix it with the firm ware up date that lets it record on 8x only, now if some of the people out ther has the firm wade update disk, they could shareit with all the people who dont, i had one but its been 2 years sence i used it, i will look for it and make it available for all
Jan 08, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Emerson DVd with Video Cassette Recorder EWR20V5
Try using 8x and lower DVDs and -R ones; try cleaning with CD cleaning disk and then try recording a few min again. If that doesn't help try unplugging and waiting about 30min then put in disk that was previously recorded and go to last item and play it to end (if 2hr long skip to last skip and then play until it finishes) - now try just recording a few min using the manual DVD record button and see if error comes up again - usually this unplugging somehow resets everything. Hope this helps ya'll.
Oct 25, 2006 | Emerson EWR20V4 DVD Recorder/VCR
JVC DR-MV1SU DVD Recorder/VCR Logo
193 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
