Question about Beverage-Air Kegerator - Beer Keg Cooler Refrigerators DD48 2 Keg Space Saver by Beverage Air
I have a Beer Miester kegarator and it had been setting for awhile. I plugged it in and it ran and cooled for a day. then it quit cooling. I unpluggged it , then plugged in back in and it made a static sound trying to run. feel the compressor and it was hot.
    Champion:
  • 210 Answers
Sounds like a relay has burned out and you may be low on R134A
Posted on May 12, 2013
3 Suggested Answers
marka19
  • 1430 Answers
SOURCE: My compressor cooling fan quit- the compressor
The problem is most likely the condensor fan motor is starting to fail. This is easy to check, First remove the back cover and when the compressor is running you should have voltage going to the fan motor if you do the fan motor needs replacing if not then the main board would be at fault here is a link that should help http://appliancehelponline.com/refercondenserfan.html
Posted on Jun 23, 2010
heatman101
  • 43501 Answers
SOURCE: no cooling. fan was running
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 06, 2010
My avanti kegarator not cooling good. Added freon, now warmer than before. Any suggestions?
Most compressors are picky about the amount of freon (and certainly the type of freon. After verifying the type of freon, rent a pressure gauge and check that the right pressure is in the low an high side. That should also help you diagnose if it is a bad compressor.
Jun 06, 2014 | Avanti Refrigerators
I have a 1997 acura cl 3.0 everytime i turn off my car the cooling fan stays on for quite awhile
The cooling fan is controlled by a heat sensor and operates independently of the motor. When you turn off your Acura, the cooling fan continues to run until the sensor determines the tempurature has decreased enough to turn off the fan
Dec 24, 2012 | 1998 Acura CL
Beer is not chilling and the display keeps blinking
Let me know what you find out. I un plug the thermastate and it stops blinking. If I plug back in. It starts blinking again. Regardless with or with out it plugged in the unit will
not cool below 66 degree's. I think there isosomething wrong with
the cooling agent or the thermastat
Aug 08, 2010 | Krups BeerTender B95 Beverage Dispenser
The bulb will come onthen off for three time then nothingnow i have plug cable into ant. Port i can get sound off cable box on any show playing but no picture. Then when move to cable plug in i get no...
First make sure that your cooling fan is running to keep the bulb cool. If not it's likely that you will need to replace that. If it is running it may be as simple as a failing bulb. If it has been in there for quite awhile or since new try replacing it. Those are the most common fixes for that set. I suspect one of them will fix your defect.
Zashiban
Jun 23, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
I have a 10 year old Whirlpool Commercial 19.6 cu.ft. upright freezer. No. EV200N . It just stopped working. The inside light is on... temp on the normal setting.... Doesn't cool... most of the food had...
Hi Pete,
I will take you up on the beer if we get this going.
If the fan is running and not cooling there is one thing that would be repairable other than that it is not worth it.
Go to the back of the freezer and at the bottom is the compressor (looks like a bowling ball, kinda anyway). Unplug the freezer, on the side of the compressor is a small black cover with wires going into it. Pry off this cover and you will see a couple of parts, these are the overload protector and relay.
Take a picture with your phone or digital camera so you know how they hook up then pull them off, they are tight but will pull straight off. If the relay rattles the part is bad, that simple. If not I will have to buy you a beer as you will most likely need a new freezer
May 09, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Heater quit working 2001 Hyundai Elantra. Checked
If the heater is blowing cold air, it could be your thermostat. They cost $20-50 at an auto parts store. Also, after the car has been ran for awhile does it come up and stay at normal operating temperature? Is your coolant level normal? If the car is high in mileage and the cooling system has never beeen flushed, it may just need flushed.
Sep 15, 2009 | Hyundai Elantra Cars & Trucks
TRUCK 1991 TOYOTA: REPLACED FUEL PUMP,DISTRBUTOR CAMSHAFT MODULE PLUGS,EVERYTHING EXCEPT COIL! TRUCK RAN FINE APROX 200MILES BACK TO SAME PROBLEM JUST TURNS OFF LET IT SET APROX. HALF HOUR WILL START AND...
i seen this trouble with a dodge pickup .the brain would over heat and shut the motor down.after it cooled down it ran just fine. first i would locate the brain.when it shuts down i would cool it down with a air hose or a can of freez .then try to start it.if this is not the problem let me know,
May 17, 2009 | 1991 Toyota Pickup
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Refrigerators Logo
148 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
