Question about LG Washing Machines
I have LG Intello wash 6.5kg(WF-T7516GN),My proble is,the valve connected to water tap is leaking highly, where can i get another one to stop water leaking???
SOURCE: LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Posted on Sep 02, 2008
SOURCE: lg intello wash wd 8013f
The front panel is flasing when i press play
Posted on Sep 16, 2008
  • 83 Answers
SOURCE: Dead LG WF-T8016TP washing machine
Is there any other appliance plugged in the same power point, and does it work?
Otherwise, plug another appliance in it to test that the power point is actually working.
If it is not, possibly a fuse has blown or breaker switched off in your meter box outside.
Let me know
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
SOURCE: LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Posted on May 22, 2011
LG Top loader WF-T7016PP Won't take in cold water? Help please
turn tap on at the wall
check that the water in solenoid is operational
check that the stop washer in the tap is allowing water in to the machine
check that the water level is set correctly
call a technician does water flow if hot water is selected
Jul 10, 2016 | LG Washing Machines
Error message - PE.... on lg intello washer. my washer is full of clothes and water.it won`t get to the cycle for rinsing .I press on auto-off , then start-pause . the light for water-level does not go on...
Is there a lot of water inside like more than normal? That is a pressure sensor error. Check pressure hose inside the washer. It is a small hose about 5/16" diameter connected to the tub and pressure switch. If there's a hole in it the air scape and the pressure switch will not turn off the water. The control board detects the problem and stop will show error code.
Nov 21, 2017 | Washing Machines
I have a LG WF-T753A washing machine. The hot water is not working, but has in the past - cold water is fine. When it goes to fill up with Hot only, a slight hum, and then it stops, but no water. Have...
Check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
May 04, 2011 | LG WFT1071TP Top Load Washer
My LG 7kg frontloader intellowasher WD8013F is leaking from underneath and no water is going into the washing machine. Please help?
i removed the filter off the front of my lg intello washer to clean and now it keeps leaking water from the filter what have i done ?
Jul 12, 2010 | LG Washing Machines
Intello washer leaking water from detergent drawer. model no. WM10402F would like to know if a part needs to be replaced or would anew machine be better. the water only leaks when water comes into the...
Are you sure it is coming from the detergent drawer? It could be from your inlet water valves. They are very easy to see. Two screws on the rear of the machine will let you slide the top back and expose the componets.
Dec 29, 2009 | LG WM-2277HW Front Load Washer
I have an LG washing machine model WF-T755A After washing completed, if water not turned off at taps, the unit slowly fills up with water. The last time causing it to overflow and flood the floor
Water inlet valve is not sealing off 100%. Replace inlet valve (the part where the hose attached to the machine). didn't find that exact model listed so couldn't give you a part number. Usually LG's have a separate valve for the cold and the hot. If you turn off one valve where hoses connect to household plumbing you should be able to figure out if it is the hot or cold. (most often it is the cold) Leave both valves off when not using washer until fixed. (note: usually on LG washers, if you have unit connected to power and the door closed, if it fills with water as your machine did, the water level switch will trip and automatically pump the water out, even if washer is not in use and the power is "off".)
Aug 31, 2008 | LG Washing Machines
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
128 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
