Question about AMD Computers & Internet
I am having AMD Athlon(tm) 2400+, MMX, 3DNow, ~2.0GHz processer and the System Model is A7V266-MX. And i want drivers for this.
    New Friend:
    Problem Solver:
  • 5 Answers
For motherboard
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=10&m=A7V266-C&os=17&hashedid=n/a
For processor
http://www.other3dlands.com/index.php?download_driver=69215&dec2013=1
Posted on May 29, 2014
4 Suggested Answers
hmerchant110
  • 7191 Answers
SOURCE: we have compaq presario sr 1000 series amd athlon
Need to know the correct model number.
Click here to select your model number:
http://h20180.www2.hp.com/apps/Lookup?h_pagetype=s-001&h_client=S-A-R311-1&h_page=hpcom&submit.y=5&submit.x=5&lang=en&cc=ca&y=9&x=0&h_lang=en&h_cc=ca&h_query=presario+sr+1000&x=0&y=0
Posted on Jun 26, 2009
WhiteFox4
  • 641 Answers
SOURCE: I have an old Time computer(2001), System
at the boot up, look for a Function key (F2, F6, or del, etc.) to get into BIOS. then you should see in the bottom of the BIOS screen another function key that restores default values. then save and exit.
Posted on Jan 15, 2010
  • 149 Answers
SOURCE: my pc details-amd semprom 3200+,mmx,3DNOW,1.8GHZ. MY
You must purchase a Wi-Fi adapter (possibly a USB Wi-Fi adapter) & follow the the adapter's installation instructions followed by inputting the modem's SSID & passphrase (if there is one). The SSID will probably show up in a list of available networks. Just follow the adapter's instructions. Refer to the modem's instructions for logon information (i.e., SSID, encryption type (if any), passphrase (if any), WPS PIN # (if any), etc.).
Posted on Apr 11, 2011
I need audio drivers for AMD Semprom 2600+,MMX,3DNow,~1.6GHz
There are no audio drivers for a microprocessor, you need audio driversfor motherboard. Kindly let me know the motherboard manufacturer and model number.
May 02, 2011 | AMD Sempron 2400+, 1.667 GHz (sda2400box)...
My system is also making a beep sound while booting up?( the time period of beep sound is time take to read beep)i think 1 sec What might be the problem.. Even after scanning entire system and deleting the...
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
the grrr is the sound its not getting enough power
test your PSU power supply unit or replace it if the fan is not working the PSU is faulty
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Feb 01, 2011 | ASUS M2N-MX Motherboard
My comuter is: AMD Athlon(tm) XP 2200+, MMX, 3DNow, 1.8GHz I need a sound card driver for this computer
If you could give the make and model-not OS and processor,I'll send you the driver or a link to download it.
Mar 09, 2010 | Computers & Internet
Low speed
Time of this report: 2/9/2010, 11:40:13
Machine name: PC-C662274E7060
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: Italian (Regional Setting: Italian)
System Manufacturer: I.C.S. SpA
System Model: Olivetti MK800
BIOS: Award Modular BIOS v6.00PG
Processor: AMD Athlon(tm) Processor, MMX, 3DNow, ~840MHz
Memory: 192MB RAM
Page File: 212MB used, 158MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
Feb 09, 2010 | Intel Pentium 4 1.7G, 1.7 GHz...
A7V266E/AA MB CPU
The Ol' Asus A7V266-E?
1.The fastest Front Side Bus setting is 266MHz
2.Uses Socket 462 AMD processors
3.Uses Athlon, Athlon XP, and Duron AMD processors.
I would stick with an AMD Athlon XP. Fastest one? Hmmm, I believe that would be the AMD Athlon XP 2600+
The one that operates at 2133MHz with a FSB of 266MHz. Part number AXDA2600DKV3C
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors#Athlon_XP_.22Thoroughbred_A.2FB.22_.28Model_8.2C_130_nm.29
Here is the Motherboard Manual for your Asus A7V266-E, (It's a PDF file download. Let it download all the way before looking through it)
http://www.motherboards.org/files/manuals/1/a7v266e-100.pdf
If the above direct link does not work for you, then go here,
http://www.motherboards.org/mobot/manuals/ASUS/A7V266-E/ (Click on -> Download <- all the way to the right of -> File:a7v266e-100.pdfVersion:--Release Date:--)
Go to Page 19, Item 2. NO POWER connected to computer, make sure the SYSCLK (System Clock) DIP switches are set to 133MHz.
1, 2, 3, and 4 are set to the OFF position for 133MHz.
All you will see is the ON. The switches go to the opposite side as shown in Item 2.
I'm sure they are set there however, as your 1900+ you have in right now, uses a 266MHz FSB.
I should explain.
AMD processors are Double-Pumped. Therefore the 133MHz setting will become 266MHz for the processor. (Intel processors are Quad-Pumped.
They are both the same Core, (Thoroughbred A/B, Model 8, 130nm), so a BIOS update shouldn't be necessary.
Jul 07, 2009 | ASUS A7V266-E (A7V266-E AA/PA/WOR)...
Caut un driver audio pt intel pentium 3 500mhz procesor deci va rog sa ma ajutati sa gasesc
Memory: 192MB RAM
ma puteti ajuta cu un driver audio va rog mult
Mar 08, 2009 | Intel Pentium 3 , 450 MHz Pentium III...
Computers & Internet Logo
71 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
