Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
I have a PDW9280 GE Profile that is not draining. No obstructions in filters. No air gap as far as I can tell. Does not look like drain pipe is crimped. Any other ideas before I call a plumber? Also, where's best place to find an honest, affordable plumber, if there is one... : ^ )
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: GE DISHWASHER PROFILE PDW9280 WILL NOT DRAIN LAST
Hi.
Check that the drain hose is set at the correct height, as specified in the manual. Otherwise machine will not drain correctly.
Check that drain lines are clear.
Check Part # 328 VALVE FLAPPER, and Part # 505 SUMP INLET , Sump filter and parts (see diagram).
If there is no problem with parts above, and pump is new, then the control module must be tested reading volts at pump. For safety reasons the test is better done by a technician.
Posted on Apr 27, 2011
Dishwasher won't drain. I made sure the sink drain were clear I don't have a Air Gap. Is there a way to check the drain inside the disherwasher. It started a couple days ago
I would check for obstruction in the drain hose.Take the drain hose off the garbage disposer hold it as low as you can over a pan or bucket and see if the dishwasher will drain centrifugally.If it does I would assume the pump is bad or disconnected.Possibly a utensil jamming it.
May 07, 2011 | GE 24 in. Profile PDW7800 Built-in...
GE Profile not draining.
Yes! Check outlet Solenoid valve and associated circuits.
Apr 12, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
GE Profile built in dishwasher is not draining. Is there an easy fix?
check filter in unit. if good check your air gap in sink
Feb 11, 2010 | GE Dishwashers
My GE Profile top load washer won't hold water
Your drain line is too low or has a blocked air gap. Take the drain line out of the drain. Hold it up high and turn the washer on to fill. If it fills and begins agitation,repair the drain line problem.
Sep 08, 2009 | GE Washing Machines
DW will not drain
If the dishwasher is not completely draining, your dishes probably aren't as clean as they could be either.
Most dishwashers have a filter screen to keep solid food from getting into the pump. This could be stopped up. Also look for kinks in the drain hose.
Aug 21, 2009 | GE 24 in. Profile PDW7880G Built-in...
Washer does not drain, and leaves water in the
hi..The drain is clogged.check the strainer at the
bottom of your unit.Always rinse your dishes of food
before putting them in the washer.
check this out..
thank u..
kindly rate my response..
Jun 09, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Dishwasher model PDW8200J03BB stopped draining. Removed the drain pump, checked with Voltmeter and there is resistance on ohms X10 of about 3. The flap is in place so water isn't shooting back into the...
clear the line from the air gap to the drain,, if the rest is clear the only thing it can be is the propellers on the pump, i which case you will need to change the pump
Jun 06, 2009 | GE 25 in. Profile PDW8200J Built-in...
GE DISWASHER - PDW7300J00WW- WATER STANDING IN BASE OF UNIT - WATER DOESN'T DRAIN. CHECKED HOSE TO DISPOSAL AND TO UNIT IT IS FREE OF OBSTRUCTIONS? wHAT NEXT?
Check the following to address this issue--
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jun 03, 2009 | GE 24 in. Profile PDW7800 Built-in...
I have had no problems with my GE dishwasher for the last 3 years. All of a sudden, when its draining, the water is coming up through the extra knob on the sink. I am not sure what it is called, but it...
The drain line between the air gap (thingie next to the sprayer) and the sewer drain piping. If the sink drains fine, the clog is between the air gap and the point at which it connects to the piping under the sink.
Please take the time to give this solution a fix ya rating.
clarkco
Mar 07, 2009 | GE 24 in. GSD4060JSS Built-in Dishwasher
My ge Profile dishwasher will not drain
HI. check the following areas for fualts.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Replace if defective (note: uncommon problem).....
Feb 08, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
104 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
