Question about Kodak EasyShare M380 Digital Camera
My Kodak easyshare m380 isn't working properly...I turn it on, and it will turn on, but the moment the lens pops out, it pops right back in and the camera shuts off....I've tried replacing the battery but it doesn't help....and I don't have a warranty on it anymore...is there anything I can do to fix it? Or could I get someone else to fix it for a reasonable price...? Please help!!
    Brigadier General:
  • 3,006 Answers
Your camera has a lens error. This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the manufacturer's service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Posted on Oct 01, 2010
dlundmark
  • 797 Answers
SOURCE: Same problem, i.e. purple display, except Kodak EasyShare M753 camera. Out of warranty - can I fix it myself?
Reset all.
In the menu. Then try it.
May be a ccd problem, contact Kodak, if it continues. They may fix this for free, not sure, but worth a try.
Posted on Aug 04, 2008
  • 11967 Answers
SOURCE: my m380 wont load pictures to the computer it cant detect device.
Use a card reader instead of your camera.
Posted on Jan 03, 2010
  • 102366 Answers
SOURCE: im having trouble uploading my
You might want to consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Jan 20, 2011
  • 45 Answers
SOURCE: My kodak easyshare M320 isn't
I believe your camera has a specific battery and battery charger? You may need to purchase a new one. Even rechargeable batteries need to be replaced after awhile. Try purchasing a new kit (battery and battery charger) and see if that works!
Something like this:
http://www.amazon.com/Kodak-M320-Digital-Camera-Accessory/dp/B004J5C2JO
Hope this helps!
Posted on Jul 26, 2011
inlarry4
  • 98 Answers
SOURCE: How to make Windows7 recognize
The easiest solution is a cheap $5 card reader available online or from a local walmart. If you don't want to do that, you can check the olympus website's download section to see if they've issued new software or driver's for your model and Window's 7.
Posted on Sep 09, 2011
Camera can turn on a moment than shut down
1) clean the contacts battery very well
2) using wrong battery type, use alkaline only
3) batteries inside with polarities wrong
4) batteries with insufficiente voltage, insert GOOD BATTERIES
5) see the memory card is inserted in securely closed.
Try it.Otherwise if the problem persist , problem with power supply +Syscom circuit associated., go to the repair shop for fix it.
God bless you
Sep 22, 2012 | Kodak EasyShare M380 Digital Camera
My Kodak M380 - when I turn it on, the lens' windows is not fully opened. only halfside is open. Is there something broken? I've tried to turn it on and off couple times, but it stayed the sa
Unfortunately not much
You can take it to the shop but they will charge you outrages price
Try banging it softly against the bottom part of your palm where the bone is
Hope that helps
Feb 06, 2012 | Kodak EasyShare M380 Digital Camera
Kodak Easyshare M380 says internal memory full, but cannot see any pictures. I would download them to the computer but can't see them.
Turn the camera off..remove the memory card...turn the camera back on and you should be able to see the pics on the internal memory. To download them, you must first go into the menu and find "copy" which gives you the option to copy the internal memory to a memory card.
Oct 23, 2011 | Kodak EasyShare M380 Digital Camera
I have a kodak m380 and my camera says internal memory full how to i switch it so that it saves pictures on the memory card instead
With no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. After that, insert your card and it should work properly.
Jul 22, 2011 | Kodak EasyShare M380 Digital Camera
I am looking for a reliable, easy site to download the extended user manual for my Kodak Easyshare M380 digital camera... The one that came with it only says to go to the Kodak website, and it is like...
How about downloading it from the manufacturer's web site at http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00988/M380_xUG_GLB_en.pdf and printing it yourself?
Feb 13, 2010 | Kodak EasyShare M380 Digital Camera
Kodak m380 wont read sdhc card
Hi
There can be a few reasons for this.
First ensure that the little lock protect switch on the card itself is not in the lock position - see image below.
Next ensure that the camera is capable of handling the size of card you are using (Maximum supported card size is 32 GB for the M380).
Finally have a look at my FixYa Tip on this subject as this is troubleshoots a common source or card read failures on these cameras. (See link below). If you find this solution helpful please do take a moment to rate it and thanks for using FixYa.
http://www.fixya.com/support/r3688103-camera_will_not_read_or_transfer
Dec 22, 2009 | Kodak EasyShare M380 Digital Camera
The lens on my m380 is stuck open and it will not turn on
This s common with these cameras. You can try holding power button or remove battery, hold power button while putting batteries back in.
Lastly, the firmware may need to be updated and Kodak will repair it for $50 or you may get lucky enought to find update on the web
Sep 30, 2009 | Kodak EasyShare M380 Digital Camera
Kodak EasyShare Z700 Digital
you have a problem with your lens alignment try to turn it lightly and push it or tap it..
May 15, 2008 | Kodak EasyShare Z700 Digital Camera
Kodak EasyShare M380 Digital Camera Logo
380 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
