Question about JVC Gumy Ear Bud Headphone - Peppermint Blue
My left head phone isn't playing music anymore, what should I do?
    President:
  • 1,851 Answers
Usually the problem is a cut at one of the copper cables. Try moving the cables at bothe ends (jack and earphone end) to locate the end that has the problem. In case it's the jack's side, you can easily change this end with another jack (complete jack and part of the cable from another headphones) by connecting the cables. The best solution is to change the jack with another one and solder the cables but since these cables are very thin, it isn't so easy. In case the problem is at the earphone side, you have to open the earphone and reconnect it at the cable again removing the part of the cable that is cut, but since the cables are too thin isn't so easy.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Oct 01, 2010
SOURCE:
Dialer headphone xp
either the heqphones are dead
or the connector not properly inserted
check it out !
Apr 24, 2014 | LG Cell Phones
The music won't play through the head phones
Did u make sure it was a cd or and MP3 player download web site cuz that wil help! Or maybe it's ur head phones or ur MP3 player lol
Apr 20, 2013 | Audio Players & Recorders
Both sides of my headphones are outputting sound however music that is supposed to be left isn't outputted at all. That is, if a song has instruments playing on the left side of the track, it won&
Are you using the 1/4 inch adapter- if so- make sure the mini plug is fully seated- you should feel 2 detents as you push the plug into the adapter- if you do not, you may be bridging the tip and ring colar with one channel and because it is not seated fully, it is not contacting the other channel at all.
Also make sure the plug for the headphones is fully seated into whatever device you are listening to. you should feel the 2 detents each time.
Apr 01, 2012 | Music
Keypad's 7&* not working
This picture repair guide may help to diagnose and repair on nokia X2 mobile phone handset.
Just follow the instructions stated on the picture itself.
Keypads key configuration by Rows and Columns
Row 0 = soft left, left, soft right, right
Row 1 = send, up, , down, camera
Row 2 = 1, 2, 3, select,
Row 3 = 4, 5, 6, volume up
Row 4 = 7, 8, 9, voume down
Row 5 = * , 0, #
Row 6 = music play, music forward, music rewind
Column 0 = soft left, send, 1, 4, 7, *, music play
Column 1 = left, up, 2, 5, 8, 0, music forward
Column 2 = soft right, 3, 6, 9, #, music rewind, camera
Column 3 = right, down, select, volume up, volume down,
Jan 05, 2012 | Nokia 5700 Cellular Phone
Hey, I have a problem with my soundsystem Logytech Z4 and I would like to know if you can help me? The following problem occurs: The black control panel, where I can adjust the volume and bass has a...
Sounds like (no pun intended) the amplifier circuit in the speaker is bad. When you use the headphone the amplifier is not used - only the preamp. It will need repair.
Nov 25, 2010 | Logitech Z4 Speakers
Mp3 is not playing stereo
You don't have to play stereo on your phones, once you plug your ear/head phone just go ahead and play your music, there's nothing like mono / stereo. It is only radio that has that kind of options. But if your head phone is not working properly, you can change it.
Apr 10, 2009 | Nokia 3230
Music plays through speaker when receiving messages
its tha connection from your head set to ur fone move it around till u hear it beep in ur head set then it shud play in ur head set hope dis helps
Mar 22, 2009 | Nokia N79 Cellular Phone
JVC Gumy Ear Bud Headphone - Peppermint Blue Logo
629 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
