Question about Canon ImageCLASS MF4370dn Laser All-in-One Printer
There is a problem with canon mf4360 printer that printing is taking huge margin in left side then right side cut lump sum 10-15mm how can i correct it plz give me solution
osram
  • 20 Answers
SOURCE: left side margin is fading out right side margin is printing correctly
First try to align the printer head either with software or at the printer control panel. If that one couldn't solve the problem then you may have the encoder strip dirty at left side. It is not easy to access the encoder strip, sent it to workshop.
Posted on May 12, 2008
Scott Ellin
  • 558 Answers
SOURCE: Left side of page cut off printing from Outlook 2003
Have you try to Copy paste the content of Outlook to Word and then try to print.
As Outlook have lesser option to set for printing. And may not possess all the features to print it correctly.
Let me know if I can assist you further.
Regards
Ellin
Posted on Sep 26, 2008
  • 168 Answers
SOURCE: printing problem on Canon IR3200
this is a common prob.. most of my users know wahat programs shift images and they adjust it accordingly... you may want to try some different drivers you may be using a pcl driver try a ps driver load accouple drivers up you can try the different ones go to imagerunner.com by the way if you have a print server on the back of the copier you should use the imagepass C1 or C2 driver
Posted on Dec 11, 2008
  • 212 Answers
SOURCE: when printing the document info is cut off on the left hand side op the paper
printer tiflon is damage please contact the shop kapeer and repair tefon paper
Posted on Apr 13, 2012
SOURCE: Canon MF4360-4390 Printer/Scanner/Fax We are
I am not able to send faxes/memory is full and I don't know how to reset
Posted on Jul 02, 2013
Brother MFCJ870DW Cuts Off/Chops Off/Truncates Left Side Return Address By About Half An Inch On #10 Com Envelope, Suddenly Started Happening
Check carefully that you have specified it to use the # 10 and that the format does not include a wide margin. If that fails, try printing the Return address 'right justified' and see what happens.
Feb 01, 2014 | Office Equipment & Supplies
When printing the document info is cut off on the left hand side op the paper
Apr 13, 2012 | Canon LBP6000 Laser Printer
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
I need to print some cards with my printer, is it possible to reduct margin to zero? I have created the document without margins, but the printer cuts part of te documents... thank you for your help!
This is normal. Practically all printers have a 'non-printable area' which forms a border at the top and bottom and left and right hand sides of the page. Whilst your software may allow you to work with a zero margin, your printer is physically incapable of printing in the non-printable area and will simply cut-off any text or images that overflow into this region.
The best solution is to reduce the number of cards on your page so that you can bring the text back within the printable area of the page. Then print with normal or wide margins and trim the excess from your cards.
Mar 19, 2010 | Canon PIXMA MP210 InkJet Printer
A few letters are cut off on left side
it could be a software problem. Please make sure that in the software where your printing originated, the paper size is set exactly as compared to the actual paper you use for printing. Example, if you are printing using an A4 paper, make sure that the document is laid out using the A4 setup with correct margins not exceeding the paper's printable area.
Nov 10, 2009 | Canon PIXMA MP470 All-in-One Printer
Always prints more to left than established margin
Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
Hope this helps. Bud
Jan 08, 2009 | Lexmark Optra T610 Laser Printer
Regards
Ellin
Sep 24, 2008 | Canon PIXMA iP90 Mobile Printer
Left side margin is fading out right side margin is printing correctly
May 12, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Right Margin Does Not Print
This one work for me...on top left of the page click on file then click print. A box print with option opens...... click options then select or put a check on left bottom box that says print all linked documents....good luck!
2nd option or
Last option and 100% will print the entire page even allows you to select what you want to print inside the page. Its called webcollect and here is the link.......http://www.web-collect.co.uk/
Mar 21, 2008 | Canon PIXMA MP470 All-in-One Printer
Canon ImageCLASS MF4370dn Laser All-in-One Printer Logo
437 people viewed this question
old marine
old marine
