Question about Panasonic CT-36HX41 36" TV
Panasonic-36" Pana Black Tube - channels are continuely changing
I accidently spilled water on the buttons on the front of the TV. There doesn't seem to be a problem with the power button. But if I put the Power Button on; the channels are continuely changing automatically. How can I get it to stop so I can set it on channel 3.
  • anabear May 26, 2008
    Thanks, That was very helpful. We also used crc electronic cleaner.
    Thanks again,
    anabear
  • 2,326 Answers
I would suggest to let the water dry or you can use a hair dryer to blow air through the buttons, you could also open the back cover to blow air towards the front panel to dry it faster.
The spilled water is acting as a conductor, that is why the channels are changing on their own.
Good Luck.
Posted on May 26, 2008
My daughter seemed to spill some pickle juice on the front of my sanyo flat screen tv it ran into the bottom where the power and channel changing buttons are now it is wigging out and changing channels and...
Spill a small amount of warm water and let it run down to wash out the pickle juice. Of course do this without the power cord connected. Let the tv dry long enough to be sure the water has evaporated before re applying power. Just might work.
Jan 03, 2014 | Televison & Video
My Sanyo AVM-3651g 36" TV keeps showing the
On the remote that came with your TV, press the Display button, which is directly below the Volume Up button. Pressing it once displays the channel number and time, pressing it twice displays the channel number continuously, you must have accidently pressed the Display button twice. Just press it once more to remove the display.
Sep 02, 2011 | Sanyo Televison & Video
I accidently pressed the channel button on my remote instead of the volume button. I now have no picture or sound. I tried returning to the previous channel but it keeps saying " channel not...
Not familiar with your model, but the problem sounds generic. I am guessing your set is hooked to a cable tv box, and that is where you need to change channels. I also guess that when you changed channels on your TV you probably moved from channel 3 to either channel 2 or 4 and the cable tv box is not sending to those channels so you lose picture and sound. Now, more guessing, you try to put the channel back to 3 on your TV, but still nothing happens. OK, if close so far, there are a couple of things to try. First, be really sure you are actually going back to the same channel you started with. Assuming you don't actually have the signal coming in on an auxiliary line-in and that you had it coming in on a channel, you may need to reset the presets on the television so that it recognizes the one important channel the cable tv box is sending out -- just follow your television menu to select or set channels. There is one more possible easy problem ... I have seen this one happen, after getting the channel correct and reset, if it still doesn't work, you mght need to turn the set off and wait one minute, then turn it back on WHILE the cable box is ON. This can cause the set to RE-Latch onto the cable box signal. It really doesn't sound like something is truly broken or needs replacement, sounds more like a user error. If your set is still under warranty, just call the Panasonic hotline (find it in Google, and they may be able to walk you through exact instructions for your model). Hope this helps.
Aug 29, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
Programming
using the menu button on sthe tv; go to setup, select cable, then select autoprogram and let it search for your channels.
May 09, 2008 | Televison & Video
Sony tv problem
If you are connecting the dish receiver to the standard antenna jack (F connector) on the TV, then the TV must be in TV mode and tuned to channel 3. If you accidently change to another channel then you will get the "no signal" message. If this is the case then simply put the TV back on channel 3. If you are using the RCA jacks (red, white yellow) to connect the dish receiver to the TV, then the TV must be in the VIDEO mode to work properly. If you accidently put the TV in the TV mode, you will get the "no signal" message. If this is the case then simply press the TV/VIDEO button.
Sep 18, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Menu wont work, continuos channel search
Usually, this means that something has spilled into the front of the set and has contaminated the pushbuttons. If one of the channel pushbuttons has fluid in it, the set will just sit there searching for channels and will not respond to any other commands. The computer thinks you are pushing the channel button and responds accordingly. When you push another button the computer does nothing because it thinks that you are pressing 2 buttons at the same time. The board should be cleaned and any contaminated pushbuttons replaced by a qualified tech.
Aug 23, 2007 | RCA F36715 36" TV
TV Won't Power Down; Change Channels; Change Volume; etc
sounds like maybe the remote contol is at fault.Do the front panel buttons work?
May 29, 2007 | Panasonic CT-32G9 32" TV
This sucker will not turn on.
Check the buttons on the TV set and make sure they make a small detent like click to them, as sometimes these buttons will stick and cause the entire set not to work. Good Luck
Mar 25, 2007 | Panasonic CT-36HL43 36" TV
Panasonic CT-36HX41 36" TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
