I have a dell dimension with the BIoS locked can you help me
    President:
  • 1,851 Answers
Since you mean the bios password, you can do this. Unplug from the power your desktop. Open the case and locate a small round battery on the motherboard that looks like this:
Eject this battery from its place. Push the power switch a few times (without power cable connected). The system will not boot but the capacitors will discharge. Wait for a couple of minutes. Place the battery back to the original place and start up the pc. The password must be gone. A good idea is to check the rest of the settings by entering the bios settings, or even better to load the preset settings (factory defaults) and make any changes as you wish (boot order, time, date etc). In case of not working post me a reply because on some cases a jumper connection setting is also needed (temporary) but since you don't specify your Dell I don't know your case.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Oct 01, 2010
I need password for bios to dell dimension 3100 desktop?
marwan_vaqub,
Dell does not supply bios passwords for Desktop systems. You would have to change the motherboard jumpers to clear the bios password. For help to clear the password please contact Dell Support for system ownership verification and they will then help you resolve clearing bios password.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 10, 2013 | Dell Dimension 3100 PC Desktop
Dell dimension 8400 frozen on BIOS revision A01
you might need to update your bios contact the dell website for a possible update
hope this helps
Jul 06, 2012 | Dell Dimension 8400 PC Desktop
Hello Mr. Expert I have a Dell Dimension 3000 desktop. I upgraded to bios to A03. Is it possible to upgrade to a higher version. Thanks,
Hi!
The A03 is for now the latest version for the BIOS of Dell Dimension 3000
And a tip for you: upgrading bios is only necessary when real issues occure and the computer doesn't work properly.
Please let me know if it helped
Best regards!
Aug 09, 2011 | Dell Dimension 3000 PC Desktop
I have locked myself out of my dimension e521. I
You can contact Dell through their supprot number which is available online and request an administrative override password to unlock the bios.
Mar 23, 2010 | Dell Computers & Internet
Dell Dimension 4700
Try resetting the BIOS, see if the drive re-detects
  1. Boot to BIOS F2
  2. turn on all 3 lock lights (NUMLOCK, CAPSLOCK< SCROLL LOCK)
  3. Press ALT+E, then ALT+F then ALT +B and system will reboot and re-detect drives
  4. If HDD is not detected, reseat data and power cable connections, try again
  5. if still no go, then HDD has likely failed
Mar 21, 2010 | Dell Dimension 4700 PC Desktop
How do turn number lock off on dell dimension 1501
just try pressing is once. :)
if fails download the latest BIOS for your laptop from the dell support site. run the installation after downloading BIOS. it will flashed then will reboot the system. check if the number lock still on.
Oct 13, 2009 | Dell Computers & Internet
Hi there I have a dell keyboard that came with my dell dimension 1100. A small issue is the fact that when the system boots up the default is numbers lock OFF. My preference is numbers lock ON - any chance...
I know Dell's bios is slightly different but on normal PC's the option can be turned on in the Bios settings. It's worth looking in the to see if it applies in Dell's case also
Aug 04, 2009 | Dell Computers & Internet
Dell Dimension 4600 will not reconize cd or dvd drive
  1. ensure the drives are jumpered Cable select.
  2. Boot to the BIOS, turn on Caps Lock, Scroll Lock, Numlock. Then press ALT+E (You should hear one beep) then ALT+F (You should hear one beep) if you have no floppy disk drive, turn off the Floppy Drive and the diskette controller the ALT+B to save and reboot.
Mar 01, 2009 | Dell Dimension 4600 PC Desktop
Dell Dimension 8200 Processor
hi, i also hav a dimensions 8200 which i recently uprgaded to a 2.8gh, but i discovered there were two versions of this system one which supports a 400FSB and the other 533FSB, these can determine the speed of ur cpu. Like you, I havent been able to unlock my clock speeds in the bios but i think you should be able to get more from ur new cpu by updating ur bios version to A09. check the dell site for more info on how to do this.
Apr 25, 2008 | Dell Dimension 8200 PC Desktop
Replacing Dell Dimension 4600 Internal DVD Drive
1. make sure the connections are tight.
2. restart ur system..on dell logo press f2 key..
3. once in the bios screen...press num lock caps lock and scroll lock..make sure all 3 are on
4. press alt and e together
5 press alt and f together
6. press esc
7. select save changes and exit
ur system will restart...it should make the dvd rw get detected
Jan 31, 2008 | Dell DVD-ROM for Dimension (6t903)...
Computers & Internet Logo
David Payne
David Payne
