Question about Lenovo IdeaPad S10-1211U Netbook
Intrnet explorer not working - Lenovo IdeaPad S10-1211U Netbook
    President:
  • 1,216 Answers
U should have told the problem more broadly.
because i don't know the type of error
Click the Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
See if your Internet connection settings are being detected. You can set Microsoft Windows to examine your network and automatically discover network connection settings (if your network administrator has enabled this setting).
Click the Tools menu, and then click Internet Options.
On the Connections tab, click LAN Settings.
Select Automatically detect settings, and then click OK.
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the Back button to try another link.
Cannot find server or DNS Error.
C:\WINDOWS\system\shdoclc.dll/dnserror.htm
Whenever u get this it's almost always an IP address problem. Try renewing your ip address.
1. Click the Start menu button on the Windows taskbar.
2. Click Run... on this menu.
3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
http://compnetworking.about.com/cs/w...in1/ht/ht_.htm
See it this doesn't fix your problem.
Posted on Oct 01, 2010
Wirless setup
try these drivers
http://laptop-problem.blogspot.in/2012/01/acer-aspire-5315-windows-xp-driver.html
Nov 12, 2013 | Microsoft Windows Vista Home Premium with...
How to uninstalexplorer.exe
You can't uninstall it, but you can disable it in Windows Features.
If it is not working, just download Chrome and use it, because you might have corrupted your PC.
Mar 26, 2013 | Microsoft Internet Explorer 8
I need a WPA for 2Wire 450. I don't have it
Hi.
You can temporarily hardwire your computer to the router (connect via ethernet),
Open internet explorer and go to the GUI (graphic user interface), key in the default gateway (192.168.1.254) in the address bar, then press enter (the address bar is the long white bar at the top part of intrnet explorer that says "address" in front.)
This will give you access to your router. go to the network tab, then wireless settings. You'll see several options for your 2wire's wireless function including resetting it.
Note: resetting the router should be your last resort
Jun 04, 2011 | Computers & Internet
When I click on the Internet Options on the Tools bar, IE8 will open up the link but it quickly closes. I cannot access it.
right click on the toolbar and put a tick in menu bar, then just click on tools/intrnet options
Jul 16, 2010 | Microsoft Internet Explorer 8
Internet explorer properties does not start
Go into your control panel, Click on add and remove programs. At the left side of that screen is your add and remove window components tab. click on that. For intrnet explorer to open from the start up the box next to internet explorer must be checked. If unchecked , just check the box next to it and click next. It should work properly after that.
If face still problem then remove internet explorer and install again.
I hope this helps you.
Mar 17, 2010 | Microsoft Computers & Internet
Toolbar for file,view, tools is missing
try going into your internet options and then under advance and reste ie too defaults see if it gets it going
May 10, 2009 | Microsoft Windows XP Home Edition
Constant ''loading'' spinning thing in the top right of mail scr
just Reinstalled ur IE(intrnet explore)
installed new version IE 8
this software available in www.4shared.com
download and installed....
Thank u
TENNISON J
Mar 24, 2009 | Computers & Internet
Can't turn on wireless switch
Go to the start menu and look for network then click it to see if there is any networks connected if not try to connect your intrnet again if not along where the on button is(not on screen) there is a couple of buttons press the one for the intrnet and it should work if not then i am stuck sorry well good luck anyway
Dec 27, 2008 | Acer Aspire 5100 Notebook
Ever time i try to get on intrnet explorer map quest come up and i cant get rid of it
In Internet Explorer click on Tools, Internet Options and change the homepage to any page you want.
If you found this information useful please vote.
Thank You
Apr 18, 2008 | Computers & Internet
Lenovo IdeaPad S10-1211U Netbook Logo
168 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
