Question about Amana Heating & Cooling
Goodman model ckj48-1ab outside fan runs in reverse
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 141 Answers
Check to see if you have a reversible fan motor it would have a set of four wires usually cumming out of the side of the motor on the top ......away from the wires that power the motor .if you see them turn the high voltage power off to the outside unit! turn off the t-stat and then just un plug the insulated plugs and swap them around they can only be plugged in two different ways..... once you swap them the motor should turn the opposite way ,if you don't have a reversible motor ,or it still turns backwards check the capicitor it may be bad
Posted on Oct 01, 2010
Goodman AC outside fan to compressor is spinning backwards, how do I fix it?
Reverse the wires on the capacitor, probably brown and purple. Labeled Fan & C
Sep 28, 2016 | Goodman Heating & Cooling
I have a Goodman model # CK30-10.. The fan on the outside unit runs sometimes. I notice when I first turn the unit on, the fan will run 5 to 10 minutes and then shutoff. Is this a capacitor or relay?
Not a relay. It is probably the capacitor. Also may be that the motor bearings are dry and the motor will need to be replaced. Its always less expensive to try the capacitor. Certainly work safe when it comes to run capacitors!
Jun 25, 2015 | Goodman Heating & Cooling
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
We have a Goodman AC Unit and the pipe continues to freeze.
either the inside coil is dirty or system is overcharged.
May 14, 2014 | Goodman CLQ36AR49 Air Conditioner
Goodman ck30-1l, outside fan trun on doesn't speed up and stops, what is wrong any ideas?
Your most likely issue is a bad run capacitor. It a small silver can that is usually located in the controls area of your condenser. If the fan has been replaced it could be mounted somewhere around the fan. It helps motors run and when they fail they will run half speed,
Jul 08, 2012 | Goodman CKL49AR49 Air Conditioner
Fan on outside unit spins counter clockwise pulling air in instead of forcefully blowing air out as it should. This fan doesnot look reversible, could this be the wrong fan or is there a way to reverse it?...
air should be coming out of the top. It will work either way. If your fan is reversible it will have a sticker on the side explaining how to reverse it and it will have exttra wires plugged into each other right at the motor. good luck
Jul 28, 2010 | Goodman CLQ36AR49 Air Conditioner
Outside unit not running, inside unit is running, but blowin heat. Goodman unit MODEL CK-J60-1
eletrick furnace? then it is a stuck heat sequencer(relay) the first stage heat sequencer also runs the fan in heating
Jun 26, 2010 | Goodman CKL60AR60 Air Conditioner
Goodman A/C won't cool
Fan motor or capacitor has gone out. Running the unit with the motor not running can cause damage to your compressor
May 01, 2010 | Goodman CKL24AR24 Air Conditioner
Fan on the outside unit is not running
Fan motor is dry or going bad try to lubricate it and see if that frees it up. If not you will need to get a new fan motor.
Oct 09, 2009 | Goodman CKL36AR36 Air Conditioner
Heating & Cooling Logo
155 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
