Question about LG Cell Phones
I have an LG cell phone sku 64675 and need to know the model number so I can get a charger for it. The battery is dead so I cannot check the phone.
Sounds like a LG CG225 black.
Manual here: www.lg.com/us/mobile-phones/pdf/CG225_UG_E.pdf
Posted on Oct 11, 2012
    New Friend:
I have a lg phone that needs a battery sku65000 but I don't know the name the phone
Posted on Mar 05, 2016
chris252
  • 84 Answers
SOURCE: wet cell phone
no if you did all that to it and still did ent work i think it is a goner sorry
Posted on Apr 01, 2008
SOURCE: Can't find Sony Ericsson W580i cell phone IMEI #
if it will on then then use the buttons *#06#.This  will show up ur imei no. otherwise take ur bill and see whether it is written or not.The  shopkeeper must have to write the no. on the bill
Posted on May 18, 2009
alexdcd
  • 17 Answers
SOURCE: REMOVING CELL PHONE NUMBER OUT OF A OLD CELL PHONE
Look around for a reset button on the phone and use that to clear the phone, If Not find the 'Restore to factory defaults' option within the menus.
Kind Regards,ACD
Posted on Mar 14, 2008
  • 94 Answers
SOURCE: Low Battery, Connected car charger, now is dead
May be the battery won't have charge, keep 1 or 2 hrs continues charges, and if it is not working then you have to replace the battery set full.
Posted on Jul 04, 2009
SOURCE: LG Dare & LG ENV2 BOTH DEAD
i was talking on my phone yesterday and i just shut off. i plugged it in and it has a full battery but every time i turn it on it only gets to the "registering apps" it shuts off. what is wrong with my phone?
Posted on Nov 01, 2009
How to find the serial number Phone is dead
Hello, open the back of the phone and take the battery out and the number are there. Sounds like the battery or the charger isn't working or bad.
Nov 18, 2015 | LG 800g TripMinutes Touch Screen tracfone...
My LG cell phone won't charge?
You coulid have a bad battery in the phone. You may be able to borrow a battery from another lg phone that you know charges and then test if it charges with your charger. Also you might be able to take your battery and try it in another lg phone on a charger and see if it charges.
Aug 29, 2014 | LG Cell Phones
Code for unlock lg cu720 imei number is 011332001112261
Hi, you can unlock it with the following service that provides factory unlock codes for your phone model: http://www.fastgsm.com/en/lg/lg/cu720-shine/unlock-code-usim-locked
Dec 13, 2012 | LG Shine CU720 Cellular Phone
LG AT&t SKU codes
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 01, 2012 | AT&T LG CU515 Cell Phone - Black
My lg serial number 910kpny037983 the battery ran out of charge. why won't it turn on when its on the charger?
Hi, When your phone doesn't come on, might be caused by the battery.you can test battery on another phone to be sure that the battery is still Ok,or needs replacement..
I think that will solve the problem of the phone.
Second,a phone can go dead because of applications with Virus. Which we need to be flashed to recover the phone back to normal.
Hope that helps.
Sep 23, 2010 | LG Cell Phones
Im trying to charger my lg voyager on my computer through a usb charger but the screen wont turn on!?
WON'T TURN ON
Hi,when a phone does not come on, it is either the battery of the phone is dead,
might need to be charge or replaced with another battery.
you can use another battery to test if it is the battery the fault.
The other thing to check is if the phone memory is weak and may need to be restored
back the phone memory.
will need to be flashed.
if too weak to power up the phone all application you downloaded on the phone has
VIRUS and has affected the phone memory.
First Charge the battery for longer hours before using another battery to confirm
if the battery cell is the problem.
If not battery, in think you will have to flash the phone memory for it to come back to life.
You can use the link below to know about how to flash the phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
(unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Aug 07, 2010 | LG VOYAGER VX10000 Cellular Phone
Need to calibrate touch screen for alltel touch screen phone.
I need to know the model of your alltel phone. Its under the battery. its usually the numbers and a letter.Or if you know the name of your phone that helps too.
Jun 10, 2010 | BargainCell USB Data Cable + Rapid Car...
LG Rumor phone charger receptor broke, how do I get the information in the dead unchangeable phone out of it to new phone?I see that this was a problem as the new Rumor phone has a USB port for the...
get a desktop charger and use it to charge the battery of your LG Rumor that its charger receptor broke.
Once the battery is full, you can then turn on the phone and get the information needed on the phone.
Check the link below, in order to have an idea of what a desktop looks like.
http://www.chinawholesalegift.com/Mobile-Phone-Gifts-and-Accessories/Emergency-Mobile-Charger/Desktop-Charger-103153420.htm
Good luck.
Apr 29, 2010 | LG RUMOR Cellular Phone
How to find IMEI number of LG(RD3500)CDMA phone?
*#06# forl all mobile phones worldwide
Nov 05, 2009 | Cell Phones
Cell Phones Logo
537 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
