My wife just noticed one of the cooktop elements was warm, but it was not on and had not been on all day. She did use the oven this day. I noticed there is what appears to be a vent tube that goes from the oven underneath this cooktop element. The range is about 8 years old. We have had it for a little over a year. We (She) never noticed this situation before. Is this normal or does this vent need replacing? This is a self-cleaning oven, would this be a safety vent?
I've unplugged the element. The heat seems to be coming from a vent in the oven that comes up underneath the right, rear heating element. My question: "Is the heat from the vent normal; or is this a safety vent for the self-cleaning oven that has become defective?"
Thank you! SmittyI've unplugged the element. The heat seems to be coming from a vent in the oven that comes up underneath the right, rear heating element. My question: "Is the heat from the vent normal; or is this a safety vent for the self-cleaning oven that has become defective?"
Thank you!
Smitty
We are noticing the heat after each time the oven is used. We have not used the self-cleaning cycle recently.
Thanks! SmittyThanks for your reply.
Thanks!
Smitty
You can't post conmments that contain an email address.
The venting on your appliance is used as describe here.
It could a latch that is not opening or closing properly if you are getting excessive heat when the self cleaning is operating.The venting on your appliance is used as describe here.
We are very sorry to hear this Jedpaquette. Unfortunately we are not able to provide technical assistance. If you would like for us to schedule service for you then please email us your name, phone number, address, the model and serial number and the website you were contacted on (Fixya.com) to [email protected].
Open the door and just under the front lip of the top there are a few screws that secure it to the body. Then you have to pull the maintop towards you. Its secured by two clips at the back.
These type of elements are often known as dual elements. They usually have two separate coils. More than likely the center coil has failed. They cannot be repaired and, in the case with your range, cannot be replaced separately. You will need to replace the entire element. Searspartsdirect.com carries parts for your range. Just type in your model number and locate item numbers 5301 and 5302 under the "Cooktop" heading. I do not know which front element your are talking about, but there is a price difference. No, thay aren't interchangeable. They have different wattage ratings. You will need to determine which one it is that you're having problems with. Replacing a single element is not difficult. It can be accomplished easily by following these instructions:
1. Unplug the range before servicing. Even with the unit turned off, there are potentially dangerous voltages present on the wiring harness.
2. Open the oven door and locate the two screws that hold the cooktop in place under the front edge. CAUTION: Do not put any weight on the oven door. You can cause damage to the door springs. Once you remove the screws to the cooktop, close the oven door.
3. With the screws removed, the cooktop will lift up.
4. Use something to prop up the cooktop, or a second person to assist, and carefully remove the mounting bracket to the two front elements. They are assembled together on the same bracket piece.
5. Gently lay the entire assembly on top of the oven box, leaving the cooktop propped up. Disconnect the wires to the affected element and unscrew the mounting clips. NOTE: There are numbered mounting holes on the element, pay attention to which numbers the clips are screwed into.
6. Remove old element. Install mounting clips to new element and reconnect wires. Install new element in mounting bracket and carefully lift back into place on the cooktop and install. NOTE: Use caution when handling the elements, they are extremely fragile. DO NOT touch the ceramic material, or electric coils with your bare hands. Oil transfer form your hands can cause potential hot spots, leading to premature failure of the element.
7. Lower cooktop and secure back in place.
The repair procedures are pretty straight forward. If you have any questions, please let me know. I hope this helps you.
You may want to re-seat the right two cooking elements, in case there is poor electrical contact. When you have them removed, clean the contacts with denatured 91% alcohol and a Q-tip. The removal procedure follows. First, unplug the range. LIFT–UP PORCELAIN COOKTOP To lift: When cool, grasp the cooktop front
edge. Gently lift up until the two support rods
snap into place. To lower: Hold the cooktop front edge and
carefully push back on each support rod to
release. Then lower the top into place. COIL ELEMENTS
➢When an element is on, it will cycle on
and off to maintain the heat setting.
➢Coil elements are self-cleaning. Do not
immerse in water. To remove: When cool, raise element. Carefully pull out and away from receptacle. Check them for damage. They do wear out. To replace: Insert element terminals into receptacle. Guide the element into place. Press down on the outer edge of element until it sits level on drip bowl. COIL ELEMENT SURFACE ➢ On Canadian models, the two front elements will not operate during self-clean.To prevent the risk of electric shock or fire, never line drip bowls with aluminum foil.
If that does work, you may have a faulty control panel. In that case, call Maytag at the number below.
Maytag Customer Service
533 Benson Road
Benton Harbor,MI 49022
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Thank you!
Smitty
Thanks!
Smitty
